is there a way to bypass the home screen at launch and load directly to a view or to the myvideonav.xml
effectively making it the first/home screen at launch
thank you
Settings > Appearance > Skin > Startup Window ?
thank you for the reply.
i was trying to do it with in the skin, did not even think of settings.
(2015-09-08, 07:49)mxlance Wrote: [ -> ]thank you for the reply.
You're welcome. However, it actually offers limited option. If you want to go to a special section of MyVideoNav.xml (ex. movies), then you will have to change the code.
