2015-09-07, 23:41
Hello,
i have an kodi installation on an raspberry pi 2, it works great but have one issue. I tried many different kodi versions, actual i use the OpenElec Kodi 16 beta builds, because i hope the problem will first be fixed at the beta.
when i use the IPTV Simple Client and switch the channel the kodi deamon often reboots. Sometimes it works sometimes it reboots. The used tv streams are from an AVM fritz Repeater DVB-C and MPEG2 streams. The raspberry has an active mpeg2 licens and it works great when i change the channels not very often.
The Problem was the same at an other kodi distribution and an raspberry pi 1, so i think it is an general problem.
i activated the debug log, but there is nothing which looks strange. Have someone an idea how to fix this ?
Regards,
Martin
Regards,
Martin
