Full Version: XBMC Tuxbox Enigma Stream Client (Enigma / Enigma2 Based Dreambox & Dbox2)
After a fresh xbmc install and changing the settings after my liking, i cannot connect to the tuxbox client anymore
23:16:23 M: 53137408 NOTICE: -----------------------------------------------------------------------
23:16:23 M: 53116928 NOTICE: Starting XBoxMediaCenter. Built on Jan 16 2007
23:16:23 M: 53116928 NOTICE: Q is mapped to: Harddisk0\Partition1\appz\xbmc
23:16:23 M: 53116928 NOTICE: Log File is located: Q:\xbmc.log
23:16:23 M: 53116928 NOTICE: -----------------------------------------------------------------------
23:16:23 M: 53116928 NOTICE: Setup DirectX
23:16:23 M: 53092352 NOTICE: load settings...
23:16:23 M: 53092352 NOTICE: loading T:\guisettings.xml
23:16:23 M: 52965376 NOTICE: Getting hardware information now...
23:16:23 M: 52965376 NOTICE: Checking resolution 10
23:16:23 M: 52965376 NOTICE: Setting autoresolution mode 6
23:16:23 M: 52944896 NOTICE: Checking resolution 10
23:16:23 M: 52944896 NOTICE: Setting autoresolution mode 6
23:16:23 M: 52944896 NOTICE: Per AV pack settings are on
23:16:23 M: 52944896 NOTICE: Standard found : loading T:\avpacksettings.xml
23:16:23 M: 52944896 NOTICE: Getting hardware information now...
23:16:23 M: 52924416 NOTICE: Checking resolution 10
23:16:23 M: 52924416 NOTICE: Setting autoresolution mode 6
23:16:23 M: 53039104 NOTICE: q:\userdata\sources.xml
23:16:25 M: 47386624 NOTICE: Checking the Date!
23:16:25 M: 47386624 NOTICE: start dvd mediatype detection
23:16:25 M: 46862336 NOTICE: initializing playlistplayer
23:16:25 M: 46862336 NOTICE: DONE initializing playlistplayer
23:16:25 M: 46862336 NOTICE: load default skin:[Project Mayhem III]
23:16:26 M: 44761088 WARNING: use dashboard
23:16:26 M: 44761088 NOTICE: initialize done
23:16:26 M: 44761088 NOTICE: Running the application...
23:16:26 M: 44347392 NOTICE: start timeserver client
23:16:26 M: 43823104 NOTICE: XBFileZilla: Starting...
23:16:25 M: 36503552 NOTICE: XBFileZilla: Started
23:16:34 M: 39018496 ERROR: CGUIMediaWindow::GetDirectory(tuxbox://root:[email protected]/)
you may want to post a debug log Smile
oh yeah sorrySmile
voila
[CODE]00:27:30 M: 38461440 DEBUG: CGUIMediaWindow::GetDirectory (tuxbox://root:[email protected]/)
00:27:30 M: 38461440 DEBUG: ParentPath = []
00:27:30 M: 38461440 ERROR: CGUIMediaWindow::GetDirectory(tuxbox://root:[email protected]/) failed
00:27:30 M: 38461440 DEBUG: CGUIMediaWindow::GetDirectory ()
00:27:30 M: 38461440 DEBUG: CVirtualPathDirectory::GetTypeAndBookmark(virtualpath://video/Videos) = [video],[Videos]
00:27:30 M: 38461440 DEBUG: CURL::CURL - Url has no protocol Videos, empty CURL created[/CODE
Might get myself a DM500C does the 'C' also have freeview conectivity via rf not only cable?
Hello Gemini,
That feature is excellent, I tested it yesterday with:
-xbox v1.3 & TSOP
-xbox 1.5 xenium
- and PLI garnet
it's working fine.
I tested also file and radio mode by editing "AdvancedSettings.xml".
One question:
When we use "defaultrootmenu" setting in "AdvancedSettings.xml" all the tuxbox source is affected.
Is there a solution to have one tuxbox source for radio, one tuxbox source for TV and one tuxbox source for TV?
Again, thanks for that feature!
Droopx
@droopx
i know what you mean, atm there is nothing planned for a RADIO or TV mode selection. Tuxbox Client is Basicly for TV streaming concepted.. so the switch is for Advanced user.
Maybe i'll add. a PopUp selection for "defaultrootmenu=true" which is then also only for advanced user.. i think this will be better then change every time the xml to switch from RADIO <> TV...
gemini, i see no reason why you cannot allocate yourself a nice little page in network settings for these things. unless you do yourself Smile
Have lots of hang ups on all coded channels,all channels free to air works great.
Runs on a 7020 with Pli Garnet
X-Box ver1.1 DuoX2 wired LAN
Please, I need your help guys. All of the sudden I cant connect anymore to the dreambox. The adress is correct and is reachable using the PC to connect to the enigma web interface and streaming with dreamview? What could be the problemHuhHuh
But I can stream the channels saved in a playlist. It's just the tuxbox client that wont connect anymore
Hakan Wrote:Have lots of hang ups on all coded channels,all channels free to air works great.
Don't you think it could be a Problem of the Image and or the EMU what you use ?
Kobazz Wrote:But I can stream the channels saved in a playlist. It's just the tuxbox client that wont connect anymore
Could be a protection isse from the TuxBox WebServer.. wait a while then try it again... (Created Items in the playlist has nothing todo with the WebServer)!
Gemini I have this problem since yesterday and I've tried everything i could think of to get it working. Went through my whole network..settings etc.. rebooted the dreambox 10 times. Checked my dreambox settings. And I don't know what it could be. The only thing I could think of is my Sagem Livebox adsl Modem/router which the dreambox is connected to. The modem has flashed a new firmware automatically. I've done all the portforwarding. So that should also not be the problem i think. Maybe flashing the dreambox again and resetting it would help.
When it starts for neutrino or give it big problems?
