2015-09-10, 13:53
Hi!
I use kodibuntu on a zotac zbox id18 with intel hd graphics on a samsung ue40f6500 led tv.
When i play 720p or 1080p material that should fit the whole screen i have about 1 cm wide black borders on the top and bottom of the screen. For xmpl when playing Material that is presented in 1.78:1. I can fix this switchting Kodi from normal to 16:9 but then my pixelsize is 0.95 instead of 1.00 that it should be.
My TV is connected via HDMI, overscan ist turned off and The Kodi Menu is also shown without any problem in 1080p50 or 1080p60.
The Problem also doesn´t appear with SD Material recorded in 4:3.
The TV is switching to the correct mode when i start playing back.
On My Windows PC with Samsung Monitor connected the problem doensn´t appear.
Does any1 know a possible solution for my problem?
Could it be a driver related problem?
Thx in advance!
b0mb
Thx in advance!
b0mb
