2015-09-11, 17:39
I'm sure there's been discussion of this somewhere, but I'm not turning up anything substantial in google or Kodi forum searches. I've encountered a problem with the Mimic skin when performing any function that calls up the on-screen keyboard. I get a popup window that says:
"ADD-ON REQUIRED
To use this feature you must download an addon:
Extendedinfo.Script
Would you like to download this addon?"
it asks Yes or No
If I say no, the dialogue goes away but returns the next time the on-screen keyboard appears.
If I say yes, the dialogue goes away and locks out the keyboard controls. Nevermind the fact that it doesn’t actually install anything. But at least the dialog stops pestering me -until I reboot, then its back.
It does go away if I manually install extendedinfo, but the script bogs down my raspberry pi2 and taxes my poor bandwidth; so I don't want it in my builds if I have a choice.
I've seen the same problem in Aeon Nox on an earlier build of Isengard. The problem went away there on the latest build, but the dialog will still pop up when using the info key while looking at a movie collection. So maybe not fixed for good in Aeon. I am assuming that there's a shared code-base between Mimic and Nox.
I've seen this in fresh Isengard installs using openelec on Raspberry Pi and with Kodi on Windows, so I doubt that the problem is specific to hardware or distro. I am installing and testing several skins and so far, only Mimic and NOX are affected with this issue. It's a hidden problem on a system with the script already installed, so perhaps many people are not seeing this.
I'm curious about the cause of the issue, is this a simple problem with the skin or is there something nasty creeping into the Kodi core? Any thoughts or information would be appreciated.
"ADD-ON REQUIRED
Extendedinfo.Script
it asks Yes or No
