Full Version: HD STAR TVheadend
Hi,,,
I'm from Bulgaria.My name is,Svetozar.I have,Satellite Dish 2.40;LNB;Raspberry PI 2 Model B;HD STAR Montage Technology DS3000.In my browser I have installed TVheadend.I have a problem with scanning channels DVB-S Hotbird.All transponders,the Symbol rate is 65535.For example:10719 V 65535;10775 H 65535;12539 H 65535.All transponders is IDLE;FAIL.Please, help my.
Svetozar
(2015-09-11, 23:29)ZaroZaro Wrote: [ -> ]Hi,,,
Svetozar
If your symbol rate is 65535, you should put 65535000 in your mux, also if it's 10775 H you should put 10775000.
Are you using this format?
Regards
Cassio
Hi,,,
thanks for the reply.
It is the response of Branko (OUTERNET).
This thread is quite old, and it's for old image that we no longer support. The new image is not yet ready for Raspberry Pi 2. We are considering providing files for Raspbian for RPi 2 users, but the problem is RPi 2 kernel does not support HDStar, so that has to be addressed separately.
Svetozar
