Can I run a vpn on my android box, so far I have tried 10 and it says it wont work on my device
HMA works fine on my Ouya
I tried that it wont work on my box, getting rid of it now and sticking to cable and downloading, trouble free bliss from now on
Check to see if your VPN provider has an Android client you can use. Also you can enter the VPN details in Android settings under the VPN section
