Pages: 1 2 3 4 5 6 7 8 9 10
hey i really love your skin but I have a problem, I cant find the option to change the color palette? where is it? I use the helix 14.2 version
thanks in advance for your answers
It is on the sideblade in most windows. Go to Videos for example and then pull open the left sideblade. You should see the option there.
Hey by the way love your skin on my Raspberry Pi 2 .Thanks a lot
Hey!
I am searching for a Way to make the menu where we have the Play,Stop etc. button, which is in the video player, bigger (Buttons).
Is there a Way to achieve that? Font.xml i already looked at, there is nothing.
cheers
is there any way to have kodec video information in the video player?
It only appear something like
thanks
(2016-01-06, 10:02)SynthLover Wrote: [ -> ]Great skin, very clean and modern and easy on the eyes. However I have one small problem, i.e., all my HEVC videos are showing a "?" on their video codec info.
I have tried other skins and they dont have this problem so I guess it must be a skin issue.
i got the same problem in any video streaming
(2017-02-07, 14:01)sotokai Wrote: [ -> ]i got the same problem in any video streaming
Do other skins provide the codec flag for the streams you are referring to?
(2017-02-07, 14:12)Bumpaneer Wrote: [ -> ] (2017-02-07, 14:01)sotokai Wrote: [ -> ]i got the same problem in any video streaming
yes.
always used Confluence and got the video, audio and subtitles info.
If you need prints let me know
thanks
now i've tested with different add-ons.
In other insted of the "$INFO[VideoPlayer.Genre]" appear the url adress
But never the Codec, audio, video or language information.
Seems it is not a available feature in this skin?
Screenshots would help. I can then try and add the information you are looking for.
On Confluence
On Unity
Thanks, I'll take a look.
(2017-02-07, 16:54)Bumpaneer Wrote: [ -> ]Thanks, I'll take a look.
thank you for all the work.
So the title is shown correctly on the red bar that has been cropped out of the Unity screenshot, right? You are just looking for the flagging information to be shown, and maybe hide the URL by default until you press the info key?
(2017-02-07, 23:41)Bumpaneer Wrote: [ -> ]So the title is shown correctly on the red bar that has been cropped out of the Unity screenshot, right? You are just looking for the flagging information to be shown, and maybe hide the URL by default until you press the info key?
yes
I think the URL is much less important than the video, audio, language, subtitles information.
For example, for someone who use subtitles, it is really important to know the video/audio information so can choose the correct release subtitles.
