Full Version: test all links in page
Ok he is my python program seems to run great
so it goes to a page and will only print the URL that is working now i try this in kodi
but get it will shut down on a phrase error i was wondering how am i to make it to continue ive on error
PHP Code:
import urlparseurlliburllib2reosHTMLParserstatsys,requests,httplib
import xml
.etree.ElementTree as ElementTree
def scan
(url):
opened urllib2.urlopen(url)
htmlSource opened.read()
headers opened.info()
opened.close()
test = ["http"+url for url in re.findall(r'http(.+?)[\n"<]'htmlSource)]
url "http"+url
for url in test:
        try:
requests.get(urltimeout=0.500,allow_redirects=True)
r.reason
if r.reason == 'OK':
                print
url
else:
                print
'no'
exceptpass
scan
('THE SITE HERE'
LOG
                                            Error Type: <class 'requests.exceptions.InvalidURL'>
                                            Error Contents: Failed to parse:@@.@@@.@@@.@@:9090
                                              File "C:\Users\@@@@@@\AppData\Roaming\Kodi\addons\@@@@.@@@@@@.@@@@@\default.py", line 1870, in <module>
                                                TESTLINKS(url)
                                              File "C:\Users\@@@@@@\AppData\Roaming\Kodi\addons\@@@@.@@@@@@.@@@@@\default.py", line 94, in TESTLINKS
                                                r = requests.get(url, timeout=10.500,allow_redirects=True)
                                              File "C:\Users\@@@@@@\AppData\Roaming\Kodi\addons\script.module.requests\lib\requests\api.py", line 69, in get
                                                return request('get', url, params=params, **kwargs)
                                              File "C:\Users\@@@@@@\AppData\Roaming\Kodi\addons\script.module.requests\lib\requests\api.py", line 50, in request
                                                response = session.request(method=method, url=url, **kwargs)
                                              File "C:\Users\@@@@@@\AppData\Roaming\Kodi\addons\script.module.requests\lib\requests\sessions.py", line 451, in request
                                                prep = self.prepare_request(req)
                                              File "C:\Users\@@@@@@\AppData\Roaming\Kodi\addons\script.module.requests\lib\requests\sessions.py", line 382, in prepare_request
                                                hooks=merge_hooks(request.hooks, self.hooks),
                                              File "C:\Users\@@@@@@\AppData\Roaming\Kodi\addons\script.module.requests\lib\requests\models.py", line 304, in prepare
                                                self.prepare_url(url, params)
                                              File "C:\Users\@@@@@@\AppData\Roaming\Kodi\addons\script.module.requests\lib\requests\models.py", line 357, in prepare_url
                                                raise InvalidURL(*e.args)
                                            InvalidURL: Failed to parse: @@.@@@.@@@.@@:9090
                                            15:34:06 T:7424   ERROR: EXCEPTION Thrown (PythonToCppException) : -->Python callback/script returned the following error<--
                                            Error Contents: Failed to parse: 185.75.56.37:8056
                                                TESTLINKS(url)
                                            InvalidURL: Failed to parse: @@@@@@@@@@@@@:8056
KODI SCRIPT
def TESTLINKS(url):
    list = []
    count = 0
    link = OPEN_URL(url)
    dp = xbmcgui.DialogProgress()
    dp.create('Head','Body')
    match=re.compile('#(.+?)\nhttp(.+?)\n', re.DOTALL).findall(link)
    for name,url in match:
                url = "http"+url
                count = count + 01
                r = requests.get(url, timeout=0.500,allow_redirects=True)
                stat = r.reason
                stat2 = stat+' '+name
                dp.update(count,stat2)
                list.append(stat)
                   addDir2(stat2,url,10,'')
    dp.close()
    dialog = xbmcgui.Dialog()
    ret = dialog.select('Choose a playlist', list)
EXCUSE THE CODING WILL TIDY UP
FIX IT put a try and except in
PHP Code:
def TESTLINKS(url):
    list = []
count 0
    link
OPEN_URL(url)
dp xbmcgui.DialogProgress()
match=re.compile('#(.+?)\nhttp(.+?)\n're.DOTALL).findall(link)
    for
name,url in match:
            try:
url "http"+url
                count
count 01
                r
stat r.reason
                stat2
stat+' '+name
                dp
                list.
append(stat)
                if
r.reason == 'OK':
except :
pass
    dp
.close()
dialog xbmcgui.Dialog()
ret dialog.select('RESULTS', list)
