2015-09-13, 18:18
I'm new to KODI, but I am an expert in Home Automation and can integrate literally anything in my home. Everything from my dust collector in my garage to my: doorbell, mail box, Google Voice (via OBi110), lighting, ceiling fans, AV components, security, HVAC and even cell phone GPS location is integrated into a single seamless platform, allowing for a common place for all control logic and scenes (e.g. no logic exists in a separate location such as within Tasker, universal remotes, etc...). Even the voice control discussed below is done in a generic and automatic fashion (e.g. no need to define names of switches, exact phrasing of commands, etc...).
Since I believe in a common platform so that everything in my home can work together, I've also developed an easy to set up home automation module for KODI; it even includes auto library import for all native media content types, two way communication (so events are always kept in sync within the home automation program), allows you to send message such as caller id data to KODI, etc... The home automation platform being used is completely free, but runs on Windows and is called Motorola Premise Home Control. It is a very open platform and end-user friendly, allowing you to mix z-wave with X10 with insteon, IR with Serial control with IP control, but keep the control logic in a common object oriented language and GUI.
Premise can truly automate anything you can think of and even has an SDK in addition to vbscript support (for us non-professional programmers): http://cocoontech.com/forums/page/home-a...premise-r3
I've attached a poll on this thread to see how many would actually download and install, a free Windows based program for home automation
Please vote yes after studying the wiki only if you actually plan to use it.
It would take a lot of time to fully document everything to where a beginner can set things up, and you would still have to be very computer literate (which is why I think it's a great match for KODI users). I developed the module for myself and plan to put a KODI box on the back of every TV, but I want to share my work too as that's what makes KODI great. Again, there would need to be enough interest for the KODI module (e.g. more than a few people downloading and using it), as this would consume a bunch of my free time over the next few months until others are familiar enough with Premise to help support things.
I would follow the KODI module up with more videos on youtube covering topics such as a beginners guide to Premise and Home Automation, how to integrate new IR devices into Premise (using a wizard), and how to use my SpeechParser module. You don't have to be a computer programmer to do the stuff I'm showing (I've done the coding for you!), but you do need to be a self study, and able to use forums and read help files to figure stuff out. The best match is probably someone with an IT, engineering or computer programming background. Below are some videos to see the level of integration I'm talking about, and some things you'll be able to do. Between the videos below and the wiki at the top of this post, hopefully the community can decide if it's worth my time to post and document everything.
Overview of voice commands with KODI and Premise using my SpeechParser module:
More details on my integration of KODI:
(NOTE: video is of nVidia Shield and mixes IR to allow control of native Netflix 4k app), but you'll use the JSON-RPC option within the module to control any version of KODI in recent years.
Additional Questions for the moderator:
Is this the correct place to post home automation software or is the hardware section better? How does it then get added to the listof supplemental tools at the top of this forum?
