2016-05-19, 20:42
(2016-05-19, 20:33)lama0900 Wrote: [ -> ]Thank you!What problems with playback do you have?
At least gui is smooth.
Video playback isn't at all though. But lets wait, as it's experimental
(2016-05-19, 20:42)codesnake Wrote: [ -> ](2016-05-19, 20:33)lama0900 Wrote: [ -> ]Thank you!What problems with playback do you have?
Format profile : [email protected]
Format settings, CABAC : Yes
Format settings, ReFrames : 5 frames
Codec ID : V_MPEG4/ISO/AVC
Duration : 2h 21mn
Bit rate : 10 000 Kbps
Width : 1 920 pixels
Height : 800 pixels
Display aspect ratio : 2.40:1
Frame rate mode : Constant
Frame rate : 23.976 (24000/1001) fps
Format : MPEG Video
Format version : Version 2
Format profile : Main@Main
Codec ID : V_MPEG2
Codec ID/Info : MPEG 1 or 2 Video
Frame rate : 25.000 fps
(2016-05-19, 21:03)zbigzbig20 Wrote: [ -> ]Hi. It is not soo bad but sometimes I have small problems with av synchronization on tvh (wetek play dvbs2 tuner)
General
Complete name : 00101.m2ts
CompleteName_Last : 00101.m2ts
Format : BDAV
Format/Info : Blu-ray Video
File size : 35.3 GiB
Duration : 125ms
Overall bit rate mode : Variable
Overall bit rate : 2 422 Gbps
Maximum Overall bit rate : 35.5 Mbps
Video
Menu ID : 1 (0x1)
Format : AVC
Format/Info : Advanced Video Codec
Format profile : High@L4
Format settings, ReFrames : 3 frames
Codec ID : 27
Duration : 209ms
Bit rate mode : Variable
Bit rate : 10 000 bps
Maximum bit rate : 15.0 Mbps
Height : 1 080 pixels
Display aspect ratio : 16:9
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : MBAFF
Scan type, store method : Interleaved fields
Scan order : Top Field First
Bits/(Pixel*Frame) : 0.000
Stream size : 261 Bytes (0%)
Writing library : x264 core 67 r1128M 682b54d
Encoding settings : cabac=1 / ref=3 / deblock=1:0:0 / analyse=0x3:0x113 / me=hex / subme=5 / psy_rd=0.0:0.0 / mixed_ref=1 / me_range=12 / chroma_me=1 / trellis=0 / 8x8dct=1 / cqm=0 / deadzone=21,11 / chroma_qp_offset=0 / threads=3 / nr=0 / decimate=1 / mbaff=1 / bframes=3 / b_pyramid=0 / b_adapt=1 / b_bias=0 / direct=1 / wpredb=1 / keyint=24 / keyint_min=13 / scenecut=40 / rc=cbr / bitrate=10 / ratetol=1.0 / qcomp=0.50 / qpmin=10 / qpmax=51 / qpstep=4 / vbv_maxrate=15000 / vbv_bufsize=10000 / ip_ratio=1.10 / pb_ratio=1.10 / aq=1:1.00
General
Unique ID :
Complete name : movie.mkv
Format : Matroska
Format version : Version 1
File size : 4.38 GiB
Duration : 1h 47mn
Overall bit rate : 5 801 Kbps
Encoded date : UTC 2007-03-03 08:29:30
Writing application : mkvmerge v1.8.1 ('Little By Little') built on Nov 25 2006 16:14:30
Writing library : libebml v0.7.7 + libmatroska v0.8.0
Video
Format : AVC
Format settings, ReFrames : 8 frames
Duration : 1h 47mn
Bit rate : 5 414 Kbps
Width : 1 280 pixels
Height : 720 pixels
Color space : YUV
Bit depth : 8 bits
Scan type : Progressive
Bits/(Pixel*Frame) : 0.245
Stream size : 4.00 GiB (91%)
Writing library : x264 core 54 svn-623M
Encoding settings : cabac=1 / ref=5 / deblock=1:0:0 / analyse=0x3:0x133 / me=hex / subme=7 / brdo=1 / mixed_ref=1 / me_range=16 / chroma_me=1 / trellis=1 / 8x8dct=1 / cqm=2 / deadzone=21,11 / chroma_qp_offset=0 / threads=2 / nr=0 / decimate=1 / mbaff=0 / bframes=3 / b_pyramid=1 / b_adapt=1 / b_bias=0 / direct=1 / wpredb=1 / bime=1 / keyint=250 / keyint_min=25 / scenecut=40(pre) / rc=2pass / bitrate=5414 / ratetol=1.0 / rceq='blurCplx^(1-qComp)' / qcomp=0.60 / qpmin=10 / qpmax=51 / qpstep=4 / cplxblur=20.0 / qblur=0.5 / ip_ratio=1.40 / pb_ratio=1.30
Language : English
Default : Yes
Forced : No
General
Unique ID : movie2.mkv
Format : Matroska
Format version : Version 4 / Version 2
File size : 10.9 GiB
Duration : 2h 28mn
Overall bit rate : 10.6 Mbps
Encoded date : UTC 2016-01-16 17:54:26
Writing application : mkvmerge v8.3.0 ('Over the Horizon') 64bit
Writing library : libebml v1.3.1 + libmatroska v1.4.2
Video
Format : AVC
Duration : 2h 28mn
Bit rate : 9 058 Kbps
Height : 808 pixels
Frame rate : 23.976 fps
Color space : YUV
Bit depth : 8 bits
Bits/(Pixel*Frame) : 0.244
Stream size : 9.36 GiB (86%)
Writing library : x264 core 148 r2638 7599210
Encoding settings : cabac=1 / ref=5 / deblock=1:0:0 / analyse=0x3:0x133 / me=umh / subme=7 / psy=1 / psy_rd=1.00:0.00 / mixed_ref=1 / me_range=16 / chroma_me=1 / trellis=1 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=0 / chroma_qp_offset=-2 / threads=24 / lookahead_threads=4 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / bluray_compat=0 / constrained_intra=0 / bframes=3 / b_pyramid=2 / b_adapt=1 / b_bias=0 / direct=1 / weightb=1 / open_gop=0 / weightp=2 / keyint=250 / keyint_min=23 / scenecut=40 / intra_refresh=0 / rc_lookahead=40 / rc=2pass / mbtree=1 / bitrate=9058 / ratetol=1.0 / qcomp=0.60 / qpmin=0 / qpmax=69 / qpstep=4 / cplxblur=20.0 / qblur=0.5 / ip_ratio=1.40 / aq=1:1.00
Language : English
Default : Yes
Forced : No
General
Complete name : movie3.mp4
Format : MPEG-4
Format profile : Base Media / Version 2
Codec ID : mp42 (mp42/isom/avc1)
File size : 96.6 MiB
Duration : 6mn 53s
Overall bit rate : 1 959 Kbps
Encoded date : UTC 2016-04-05 11:02:23
Tagged date : UTC 2016-04-05 11:03:37
Writing application : DVDFab 9.1.6.6
covr : Unknown kind of value!
Video
Format : AVC
Format profile : Main@L3
Format settings, ReFrames : 1 frame
Codec ID : avc1
Codec ID/Info : Advanced Video Coding
Duration : 6mn 53s
Bit rate : 1 760 Kbps
Width : 720 pixels
Height : 404 pixels
Color space : YUV
Bit depth : 8 bits
Bits/(Pixel*Frame) : 0.242
Stream size : 86.8 MiB (90%)
Writing library : x264 core 142
Encoding settings : cabac=1 / ref=1 / deblock=1:0:0 / analyse=0x1:0x111 / me=umh / subme=6 / psy=0 / mixed_ref=0 / me_range=12 / chroma_me=1 / trellis=0 / 8x8dct=0 / cqm=0 / deadzone=21,11 / fast_pskip=1 / chroma_qp_offset=0 / threads=4 / lookahead_threads=1 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / bluray_compat=0 / constrained_intra=0 / bframes=0 / weightp=0 / keyint=24 / keyint_min=13 / scenecut=40 / intra_refresh=0 / rc=2pass / mbtree=0 / bitrate=1760 / ratetol=1.0 / qcomp=0.60 / qpmin=0 / qpmax=69 / qpstep=4 / cplxblur=20.0 / qblur=0.5 / ip_ratio=1.40 / aq=1:1.00
Tagged date : UTC 2016-04-05 11:03:36
Color range : Limited
Color primaries : BT.601 NTSC
Transfer characteristics : BT.709
Matrix coefficients : BT.601
Menus : 3
(2016-05-19, 21:51)skodilak Wrote: [ -> ]Code:General
Unique ID :
Format : Matroska
Duration : 1h 47mn
Video
Format : AVC
Duration : 1h 47mn
Height : 720 pixels
Color space : YUV
Bit depth : 8 bits
Language : English
Default : Yes
Forced : No
(2016-05-19, 23:20)MrMC Wrote: [ -> ]one word, birds
(2016-05-20, 09:35)lama0900 Wrote: [ -> ](2016-05-19, 23:20)MrMC Wrote: [ -> ]one word, birdsWhat should me tell these three words
(2016-05-20, 09:52)Koying Wrote: [ -> ](2016-05-20, 09:35)lama0900 Wrote: [ -> ](2016-05-19, 23:20)MrMC Wrote: [ -> ]one word, birdsWhat should me tell these three words
http://kodi.wiki/view/Samples#Bitrate_Test_Clips
(2016-05-20, 20:22)lama0900 Wrote: [ -> ]So ok tried 3 samples from:
http://www.demo-world.eu/2d-demo-trailers-hd/
these were:
20th century fox
marvel studios 2013
lionsgate 2013
everything 23.976p
and behaviour is the same as already described with my own mkvs.
