A 13 years old Sony TV?. Whaaat?. And have 24P mode?. Hum...strange but ok!
You repeat again and again about the EDID HDMI Checksum Failure, BUT, I have another thread of you that YOU SAY:
Quote:I've recently purchased a Amlogic S805 equipped ODROID-C1 and am pretty confused.
If the Android (4.4.2) GUI interface is set to 24Hz and I startup Kodi, any H264 / 23.976fps movies I play have a small video hiccup every 40 seconds or so due to the lack of perfect 23.976 video sync with my 24p TV. This is already a well known Android issue.
Well, what´s the point here?. I don´t get it. Ok, different Android version, but same AMLOGIC chip company. And you have these annoying jumps EVERY 40 SECONDS, like me and others.
I have just purchased a Minix NEO U1, then I see if the sttutering continues, or not. With the same equipment, HDMI cable and so on.
The only issue is that we did not get any log except file sample from actpower, and unfortunately we are NOT able to reproduce issue which he is facing with playback of this file at 23.976.
We tested at LG, Phillips, Panasonic and Samsung TV sets.
Hardware acceleration is turned on in Android and OpenELEC at Core as well.
(2015-12-17, 17:05)actpower Wrote: [ -> ]A 13 years old Sony TV?. Whaaat?. And have 24P mode?. Hum...strange but ok!
actpower, usually if You are looking for help regarding your issue on Kodi Forum, it would be nice if you can provide kodi.log which can be obtained by several ways:
Android
/sdcard/Android/data/org.xbmc.kodi/files/.kodi/temp/kodi.log
Connect by FTP to WeTek Core and download it to PC.
OpenELEC
Connect by SSH and run this command:
cat /storage/.kodi/temp/kodi.log | pastebinit
You can also send dmesg log as well.
Oh, there is a LOG?. Ok, I will locate it and upload it here, I hope that helps!
I was going to suggest that stuff be done on the WeTek forum. The most appropriate place as this is not at all a Kodi issue.
Yes, actpower You can post log at WeTek Forum
Ok, I attach the log of the last play...
Well...I do not found any button to attach, paste here:
15:03:49 T:18446744072443578368 NOTICE: special://profile/ is mapped to: special://masterprofile/
15:03:49 T:18446744072443578368 NOTICE: -----------------------------------------------------------------------
15:03:49 T:18446744072443578368 NOTICE: Starting Kodi (16.0-BETA4 Git:2015-12-13-a724f29). Platform: Android ARM 32-bit
15:03:49 T:18446744072443578368 NOTICE: Using Release Kodi x32 build
15:03:49 T:18446744072443578368 NOTICE: Kodi compiled Dec 13 2015 by GCC 4.8.0 for Android ARM 32-bit API level 17 (API level 17)
15:03:49 T:18446744072443578368 NOTICE: Running on WeTek Core with Android 5.1.1 API level 22, kernel: Linux ARM 32-bit version 3.10.33
15:03:49 T:18446744072443578368 NOTICE: FFmpeg version: 2.8.3-kodi-2.8.3-Jarvis-beta3
15:03:49 T:18446744072443578368 NOTICE: Host CPU: ARMv7 Processor rev 1 (v7l), 4 cores available
15:03:49 T:18446744072443578368 NOTICE: Product: wetekcore, Device: wetekcore, Board: n200C - Manufacturer: WeTek, Brand: WeTek, Model: Core, Hardware: amlogic
15:03:49 T:18446744072443578368 NOTICE: External storage path = /storage/emulated/0; status = ok
15:03:49 T:18446744072443578368 NOTICE: ARM Features: Neon enabled
15:03:49 T:18446744072443578368 NOTICE: special://xbmc/ is mapped to: /data/data/org.xbmc.kodi/cache/apk/assets
15:03:49 T:18446744072443578368 NOTICE: special://xbmcbin/ is mapped to: /data/data/org.xbmc.kodi/cache/apk/assets
15:03:49 T:18446744072443578368 NOTICE: special://masterprofile/ is mapped to: /storage/emulated/0/Android/data/org.xbmc.kodi/files/.kodi/userdata
15:03:49 T:18446744072443578368 NOTICE: special://home/ is mapped to: /storage/emulated/0/Android/data/org.xbmc.kodi/files/.kodi
15:03:49 T:18446744072443578368 NOTICE: special://temp/ is mapped to: /storage/emulated/0/Android/data/org.xbmc.kodi/files/.kodi/temp
15:03:49 T:18446744072443578368 NOTICE: The executable running is: /system/bin/app_process32
15:03:49 T:18446744072443578368 NOTICE: Local hostname: localhost
15:03:49 T:18446744072443578368 NOTICE: Log File is located: /storage/emulated/0/Android/data/org.xbmc.kodi/files/.kodi/temp/kodi.log
15:03:49 T:18446744072443578368 NOTICE: load settings...
15:03:49 T:18446744072443578368 DEBUG: CSettings: loaded settings definition from special://xbmc/system/settings/settings.xml
15:03:49 T:18446744072443578368 WARNING: CSettingInt: unknown options filler "audiocdactions" of "audiocds.autoaction"
15:03:49 T:18446744072443578368 DEBUG: CSettings: loaded settings definition from special://xbmc/system/settings/android.xml
15:03:49 T:18446744072443578368 DEBUG: AESinkAUDIOTRACK - 44100 supported
15:03:49 T:18446744072443578368 DEBUG: AESinkAUDIOTRACK - 48000 supported
15:03:49 T:18446744072443578368 DEBUG: AESinkAUDIOTRACK - 96000 supported
15:03:49 T:18446744072443578368 NOTICE: Found 1 Lists of Devices
15:03:49 T:18446744072443578368 NOTICE: Enumerated AUDIOTRACK devices:
15:03:49 T:18446744072443578368 NOTICE: Device 1
15:03:49 T:18446744072443578368 NOTICE: m_deviceName : AudioTrack
15:03:49 T:18446744072443578368 NOTICE: m_displayName : android
15:03:49 T:18446744072443578368 NOTICE: m_displayNameExtra: audiotrack
15:03:49 T:18446744072443578368 NOTICE: m_deviceType : AE_DEVTYPE_HDMI
15:03:49 T:18446744072443578368 NOTICE: m_channels : FL,FR,FC,LFE,BL,BR,SL,SR
15:03:49 T:18446744072443578368 NOTICE: m_sampleRates : 48000,44100,48000,96000
15:03:49 T:18446744072443578368 NOTICE: m_dataFormats : AE_FMT_S16LE,AE_FMT_AC3,AE_FMT_DTS
15:03:49 T:18446744072443578368 NOTICE: No settings file to load (special://xbmc/system/advancedsettings.xml)
15:03:49 T:18446744072443578368 NOTICE: No settings file to load (special://masterprofile/advancedsettings.xml)
15:03:49 T:18446744072443578368 NOTICE: Default DVD Player: dvdplayer
15:03:49 T:18446744072443578368 NOTICE: Default Video Player: dvdplayer
15:03:49 T:18446744072443578368 NOTICE: Default Audio Player: paplayer
15:03:49 T:18446744072443578368 NOTICE: Disabled debug logging due to GUI setting. Level 0.
15:03:49 T:18446744072443578368 NOTICE: Log level changed to "LOG_LEVEL_NORMAL"
15:03:49 T:18446744072443578368 NOTICE: CMediaSourceSettings: loading media sources from special://masterprofile/sources.xml
15:03:49 T:18446744072443578368 NOTICE: Loading player core factory settings from special://xbmc/system/playercorefactory.xml.
15:03:49 T:18446744072443578368 NOTICE: Loaded playercorefactory configuration
15:03:49 T:18446744072443578368 NOTICE: Loading player core factory settings from special://masterprofile/playercorefactory.xml.
15:03:49 T:18446744072443578368 NOTICE: special://masterprofile/playercorefactory.xml does not exist. Skipping.
15:03:49 T:18446744072443578368 NOTICE: Running database version Addons20
15:03:49 T:18446744072443578368 NOTICE: ADDONS: Using repository repository.xbmc.org
15:03:50 T:18446744072443578368 NOTICE: virtual bool CWinSystemEGL::InitWindowSystem(): Using EGL Implementation: amlandroid
15:03:50 T:18446744072443578368 NOTICE: Current resolution: 1920x1080 @ 60.00 - Full Screen
15:03:50 T:18446744072443578368 NOTICE: Previous line repeats 1 times.
15:03:50 T:18446744072443578368 NOTICE: Found resolution 1920 x 1080 for display 0 with 720 x 480 @ 60.000000 Hz
15:03:50 T:18446744072443578368 NOTICE: Found resolution 1920 x 1080 for display 0 with 720 x 576 @ 50.000000 Hz
15:03:50 T:18446744072443578368 NOTICE: Found resolution 1920 x 1080 for display 0 with 1280 x 720 @ 60.000000 Hz
15:03:50 T:18446744072443578368 NOTICE: Found resolution 1920 x 1080 for display 0 with 1920 x 1080i @ 60.000000 Hz
15:03:50 T:18446744072443578368 NOTICE: Found resolution 1920 x 1080 for display 0 with 1920 x 1080 @ 60.000000 Hz
15:03:50 T:18446744072443578368 NOTICE: Found resolution 1920 x 1080 for display 0 with 1280 x 720 @ 50.000000 Hz
15:03:50 T:18446744072443578368 NOTICE: Found resolution 1920 x 1080 for display 0 with 1920 x 1080i @ 50.000000 Hz
15:03:50 T:18446744072443578368 NOTICE: Found resolution 1920 x 1080 for display 0 with 1920 x 1080 @ 50.000000 Hz
15:03:50 T:18446744072443578368 NOTICE: Found resolution 1920 x 1080 for display 0 with 1920 x 1080 @ 24.000000 Hz
15:03:50 T:18446744072443578368 NOTICE: Found ([email protected]) at 20, setting to RES_DESKTOP at 16
15:03:50 T:18446744072443578368 NOTICE: Checking resolution 16
15:03:50 T:18446744072443578368 NOTICE: GL_VENDOR = ARM
15:03:50 T:18446744072443578368 NOTICE: GL_RENDERER = Mali-450 MP
15:03:50 T:18446744072443578368 NOTICE: GL_VERSION = OpenGL ES 2.0
15:03:50 T:18446744072443578368 NOTICE: GL_SHADING_LANGUAGE_VERSION = OpenGL ES GLSL ES 1.00
15:03:50 T:18446744072443578368 NOTICE: GL_EXTENSIONS = GL_EXT_debug_marker GL_OES_texture_npot GL_OES_vertex_array_object GL_OES_compressed_ETC1_RGB8_texture GL_EXT_compressed_ETC1_RGB8_sub_texture GL_OES_standard_derivatives GL_OES_EGL_image GL_OES_depth24 GL_ARM_rgba8 GL_ARM_mali_shader_binary GL_OES_depth_texture GL_OES_packed_depth_stencil GL_EXT_texture_format_BGRA8888 GL_OES_vertex_half_float GL_EXT_blend_minmax GL_OES_EGL_image_external GL_OES_EGL_sync GL_OES_rgb8_rgba8 GL_EXT_multisampled_render_to_texture GL_EXT_discard_framebuffer GL_OES_get_program_binary GL_ARM_mali_program_binary GL_EXT_shader_texture_lod GL_EXT_robustness GL_OES_depth_texture_cube_map GL_KHR_debug GL_ARM_shader_framebuffer_fetch GL_ARM_shader_framebuffer_fetch_depth_stencil GL_OES_mapbuffer
15:03:50 T:18446744072443578368 ERROR: Unable to load libcec.so, reason: (null)
15:03:50 T:18446744072443578368 ERROR: virtual void PERIPHERALS::CPeripherals::Initialise() - failed to initialise bus cec
15:03:50 T:18446744072443578368 NOTICE: Running database version Addons20
15:03:50 T:18446744072443578368 NOTICE: Running database version ViewModes6
15:03:50 T:18446744072443578368 NOTICE: Running database version Textures13
15:03:50 T:18446744072443578368 NOTICE: Attempting to update the database MyMusic56 from version 52 to 56
15:03:51 T:18446744072443578368 NOTICE: Old database found - updating from version 93 to 99
15:03:51 T:18446744072443578368 NOTICE: Attempting to update the database MyVideos99 from version 93 to 99
15:03:52 T:18446744072443578368 NOTICE: Running database version TV29
15:03:52 T:18446744072443578368 NOTICE: Old database found - updating from version 10 to 11
15:03:52 T:18446744072443578368 NOTICE: Attempting to update the database Epg11 from version 10 to 11
15:03:52 T:18446744072443578368 WARNING: CSkinInfo: failed to load skin settings
15:03:56 T:18446744072443578368 WARNING: JSONRPC: Could not parse type "Setting.Details.SettingList"
15:03:56 T:18446744072443578368 NOTICE: ActiveAE DSP - starting
15:03:56 T:18446744072443578368 NOTICE: initialize done
15:03:56 T:18446744072443578368 NOTICE: Running the application...
15:03:57 T:18446744072443578368 NOTICE: starting zeroconf publishing
15:03:57 T:18446744072443578368 NOTICE: starting upnp client
15:03:57 T:18446744072012774400 NOTICE: ES: Starting UDP Event server on 0.0.0.0:9777
15:03:57 T:18446744072012774400 NOTICE: UDP: Listening on port 9777
15:03:57 T:18446744072443578368 NOTICE: Current resolution: 1920x1080 @ 60.00 - Full Screen
15:03:57 T:18446744072443578368 NOTICE: GL_VENDOR = ARM
15:03:57 T:18446744072443578368 NOTICE: GL_RENDERER = Mali-450 MP
15:03:57 T:18446744072443578368 NOTICE: GL_VERSION = OpenGL ES 2.0
15:03:57 T:18446744072443578368 NOTICE: GL_SHADING_LANGUAGE_VERSION = OpenGL ES GLSL ES 1.00
15:03:57 T:18446744072443578368 NOTICE: GL_EXTENSIONS = GL_EXT_debug_marker GL_OES_texture_npot GL_OES_vertex_array_object GL_OES_compressed_ETC1_RGB8_texture GL_EXT_compressed_ETC1_RGB8_sub_texture GL_OES_standard_derivatives GL_OES_EGL_image GL_OES_depth24 GL_ARM_rgba8 GL_ARM_mali_shader_binary GL_OES_depth_texture GL_OES_packed_depth_stencil GL_EXT_texture_format_BGRA8888 GL_OES_vertex_half_float GL_EXT_blend_minmax GL_OES_EGL_image_external GL_OES_EGL_sync GL_OES_rgb8_rgba8 GL_EXT_multisampled_render_to_texture GL_EXT_discard_framebuffer GL_OES_get_program_binary GL_ARM_mali_program_binary GL_EXT_shader_texture_lod GL_EXT_robustness GL_OES_depth_texture_cube_map GL_KHR_debug GL_ARM_shader_framebuffer_fetch GL_ARM_shader_framebuffer_fetch_depth_stencil GL_OES_mapbuffer
15:03:57 T:18446744072062337152 NOTICE: NEXTUP SERVICE NOTIFICATION Service -> Starting NextUp Service
15:03:57 T:18446744072062337152 NOTICE: NEXTUP SERVICE NOTIFICATION Service -> ======== START NEXTUP SERVICE NOTIFICATION ========
15:03:57 T:18446744072062337152 NOTICE: NEXTUP SERVICE NOTIFICATION Service -> KODI Version: 16.0-BETA4 Git:2015-12-13-a724f29
15:03:57 T:18446744072062337152 NOTICE: NEXTUP SERVICE NOTIFICATION Service -> NEXTUP SERVICE NOTIFICATION Version: 1.0.14
15:03:57 T:18446744072062339072 NOTICE: script.tv.show.next.aired: ### TV Show - Next Aired starting background proc (6.0.15)
15:03:57 T:18446744072062337152 NOTICE: NEXTUP SERVICE NOTIFICATION Service -> Platform: Linux/RPi
15:03:57 T:18446744072062339072 NOTICE: script.tv.show.next.aired: ### no prior data found
15:03:59 T:18446744072062342912 NOTICE: version 3.1.2 started
15:03:59 T:18446744072062339072 NOTICE: script.tv.show.next.aired: ### starting data update
15:04:01 T:18446744072012775680 ERROR: static bool XFILE::CDirectory::GetDirectory(const CURL&, CFileItemList&, const XFILE::CDirectory::CHints&, bool) - Error getting
15:04:03 T:18446744072062342912 NOTICE: finished
15:04:03 T:18446744072012775680 ERROR: static bool XFILE::CDirectory::GetDirectory(const CURL&, CFileItemList&, const XFILE::CDirectory::CHints&, bool) - Error getting
15:04:57 T:18446744072443578368 ERROR: static bool XFILE::CDirectory::GetDirectory(const CURL&, CFileItemList&, const XFILE::CDirectory::CHints&, bool) - Error getting /storage/emulated/0/Android/data/org.xbmc.kodi/files/.kodi/media/Fonts/
15:04:57 T:18446744072443578368 ERROR: static bool XFILE::CDirectory::GetDirectory(const CURL&, CFileItemList&, const XFILE::CDirectory::CHints&, bool) - Error getting special://home/media/Fonts/
15:05:10 T:18446744072443578368 NOTICE: AML 3D support detected
15:05:37 T:18446744071972482816 ERROR: static bool XFILE::CDirectory::GetDirectory(const CURL&, CFileItemList&, const XFILE::CDirectory::CHints&, bool) - Error getting
15:05:44 T:18446744072443578368 NOTICE: DVDPlayer: Opening: /storage/udisk0/SCROLL_judder_23_976.mp4
15:05:44 T:18446744072443578368 WARNING: CDVDMessageQueue(player)::Put MSGQ_NOT_INITIALIZED
15:05:44 T:18446744072019188608 NOTICE: Creating InputStream
15:05:44 T:18446744072019188608 NOTICE: Creating Demuxer
15:05:44 T:18446744072019188608 NOTICE: Opening stream: 0 source: 256
15:05:44 T:18446744072019188608 NOTICE: Creating video codec with codec id: 28
15:05:44 T:18446744072019188608 NOTICE: Creating video thread
15:05:44 T:18446744072019188608 NOTICE: Opening stream: 1 source: 256
15:05:44 T:18446744071974299776 NOTICE: running thread: video_thread
15:05:44 T:18446744072019188608 NOTICE: Finding audio codec for: 86018
15:05:44 T:18446744072019188608 NOTICE: Creating audio thread
15:05:44 T:18446744071974300416 NOTICE: running thread: CDVDPlayerAudio::Process()
15:05:44 T:18446744071974300416 NOTICE: Creating audio stream (codec id: 86018, channels: 2, sample rate: 48000, no pass-through)
15:05:44 T:18446744071974300416 NOTICE: CDVDPlayerAudio::OutputPacket duplicate 1 packets of duration 21
15:05:44 T:18446744071974299776 NOTICE: fps: 23.976024, pwidth: 1920, pheight: 1080, dwidth: 1920, dheight: 1080
15:05:44 T:18446744071974299776 NOTICE: Display resolution ADJUST : 1920x1080 @ 24.00 - Full Screen (24) (weight: 0.001)
15:05:44 T:18446744072443578368 NOTICE: Using GL_TEXTURE_2D
15:05:44 T:18446744072443578368 NOTICE: GL: Using BYPASS render method
15:05:44 T:18446744072443578368 NOTICE: GL: NPOT texture support detected
15:05:45 T:18446744072443578368 NOTICE: Current resolution: 1920x1080 @ 60.00 - Full Screen
15:05:47 T:18446744071974300416 NOTICE: CDVDPlayerAudio::OutputPacket skipping a packets of duration 21
15:06:44 T:18446744072443578368 NOTICE: Previous line repeats 1 times.
15:06:44 T:18446744072443578368 NOTICE: CDVDPlayer::CloseFile()
15:06:44 T:18446744072443578368 NOTICE: DVDPlayer: waiting for threads to exit
15:06:44 T:18446744072019188608 NOTICE: CDVDPlayer::OnExit()
15:06:44 T:18446744072019188608 NOTICE: Closing stream player 1
15:06:44 T:18446744072019188608 NOTICE: Waiting for audio thread to exit
15:06:44 T:18446744071974300416 NOTICE: thread end: CDVDPlayerAudio::OnExit()
15:06:44 T:18446744072019188608 NOTICE: Closing audio device
15:06:44 T:18446744072019188608 NOTICE: Deleting audio codec
15:06:44 T:18446744072019188608 NOTICE: Closing stream player 2
15:06:44 T:18446744072019188608 NOTICE: waiting for video thread to exit
15:06:44 T:18446744071974299776 NOTICE: thread end: video_thread
15:06:44 T:18446744072019188608 NOTICE: deleting video codec
15:06:44 T:18446744072443578368 NOTICE: DVDPlayer: finished waiting
15:06:44 T:18446744072443578368 NOTICE: Current resolution: 1920x1080 @ 60.00 - Full Screen
15:06:45 T:18446744072443578368 NOTICE: CDVDPlayer::CloseFile()
15:06:45 T:18446744072443578368 NOTICE: DVDPlayer: waiting for threads to exit
15:06:45 T:18446744072443578368 NOTICE: DVDPlayer: finished waiting
15:08:58 T:18446744072062339072 NOTICE: script.tv.show.next.aired: ### no prior data found
15:09:00 T:18446744072062339072 NOTICE: script.tv.show.next.aired: ### starting data update
15:18:58 T:18446744072062339072 NOTICE: script.tv.show.next.aired: ### no prior data found
15:19:00 T:18446744072062339072 NOTICE: script.tv.show.next.aired: ### starting data update
15:33:59 T:18446744072062339072 NOTICE: script.tv.show.next.aired: ### no prior data found
15:34:01 T:18446744072062339072 NOTICE: script.tv.show.next.aired: ### starting data update
Please edit the text above and enclose it with what is written below:
(2015-12-17, 17:31)actpower Wrote: [ -> ]Ok, I attach the log of the last play...
(2015-12-17, 17:34)wrxtasy Wrote: [ -> ]Please edit the text above and enclose it with what is written below:
do not post logs on the forum. use pastebin.com
(2015-12-17, 11:37)actpower Wrote: [ -> ] (2015-12-17, 03:52)hdmkv Wrote: [ -> ][*]23.976 videos play in 23.976; my Epson 5025UB shows 23.97 and I noticed no microstutters... terrific!
Can you please test my 23.976 video to see if there is any jump every 40 secs, aprox?:
https://drive.google.com/file/d/0B4Nc5b_...sp=sharing
You need to watch it carefully, not always can catch the jump, but there is.
I have tested it even with the HDMI cable provided by Wetek directly over HDMI and still have jumps.
Just watched it, can't see any judder here.
hdmkv
it would be no problem at all but since Netflix is not available worldwide I have to discuss about this internally before
I have watched the file in a Bluray Samsung Player attached with the SAME HDMI cable, and the same display, and IT WORKS smoothly. So...Why the Core don´t play 23.976 FPS files smooth?.
(2015-12-17, 14:31)hdmkv Wrote: [ -> ]Re: the Harmony remote talk, I'd encourage WeTek to at least support Harmony One Ultimate/Smart via Bluetooth, and ideally by extending the functionality of the in-built IR via firmware for full functionality (so, Harmony 650, 700, etc. can also be used).
Please see my posts in the following threads regarding this subject:
http://forum.kodi.tv/showthread.php?tid=251780
http://wetekforums.com/vb5/forum/wetek-c...s-keyboard
Basically no answer from Wetek on this subject which is very disappointing. Even if it's negative, at they can give an official answer like "sorry but we have no plans to support this in our firmware". (which for me and maybe others = I'm not buying your box)
Personally I think that 3rd party remote support should be built in, and the 'standard' for this these days seems to be via a logitech harmony profile.
However, in my opinion these type of media boxes really require a combination remote and keyboard combination to work well. We always see the answer 'oh just connect a full size keyboard' however for normal use this is overkill. Mostly we need to be able to type easily, but only short phrases for searches, be that in our kodi library, or inside android apps such as chrome or youtube.
I wish the manufacturers would realise this and provide an off the shelf solution, even if it's an optional more expensive remote.
On my side I chose to go with the Rii i13 remote as a compromise to a full harmony setup (which cost more than a Core or similar box...). This gives me wireless mouse for android, mini keyboard, plus IR learning remote for 8 devices. A good compromise I think for a lot of people that want to control a media box, their TV, and maybe a set top box or DVD player at a modest cost, and all via 1 remote. (people will use CEC, however this seems to work perfect with some devices, not at all with others, and some mess in between for the rest)
However, this wouldn't work with a Wetek Core (without adding a FLIRC) as they appear to offer no support at all for 3rd party IR devices.
It's a pity, and it needs to be considered as part of the overall cost of purchasing any of these type of devices, and the extra cost becomes especially apparent when buying multiple boxes for the whole house.
(2015-12-17, 18:27)actpower Wrote: [ -> ]I have watched the file in a Bluray Samsung Player attached with the SAME HDMI cable, and the same display, and IT WORKS smoothly. So...Why the Core don´t play 23.976 FPS files smooth?.
It does. Just not yours. Your file plays smooth here, as I stated above.
Well, then WHY don´t play smooth here?. If a Bluray Player play this file smooth with the SAME HDMI and Display?. I repeat, again.
What´s your config?
