Full Version: Crash
Hi all,
I am trying to switch from WMC to Kodi. I have the following problem: I am using DVBLink to see DVB-S an DVB-S2 channels. However where I live reception is poor and sometimes I can't tune a channel. If I happen to switch to one of these channels that there is no reception kodi freezes the tv client. I can change channel but nothing happens. I can still use other kodi functions, but not the TV which seems stuck on an endelss loop trying to tune a channel which is not there. When I exit Kodi it crashes in a windows error.
Any thoughts about this?
You could try increasing the timeout value in System- TV-playback-timeout when starting playback. I don't have signal timeouts, so just a guess..
Also, you could try different delay values for a channel switch (same menu)
