(2015-09-21, 23:47)noggin Wrote: [ -> ]That's often requested - but it's a very difficult feature to realise - because so many video files around these days are not in a standard video resolution.
The only real video resolutions that can be output via HDMI for consumer displays are :
720x576i
720x480i
720x576p
720x480p
1280x720
1920x1080
3840x2160
4096x2160
(Sure you can also get VGA, SVGA, WVGA etc. - but they are less standard for consumer video gear)
Those are the main resolutions supported by HDMI (and other standard video interconnects). You will see them supported at 23.976, 24.000, 25, 29.97, 30.00, 50, 59.94, 60.00Hz (and the various 3D variations) - with some formats only supported at some frame rates.
However there are so many more resolutions of file out there - plus the ATSC and DVB resolutions that don't perfectly match these (704x576, 704x480, 544x576, 352x576, 1440x1080 etc. are standard resolutions) and all the cropped resolutions where letterbox or pillar boxed content has had the black content removed and the height or width reduced. You then have to process the content to get it to an HDMI standard resolution.
Doing this properly is a non-trivial task.
And if you want interlaced content output as interlaced and field-mapped it gets even more complex as you have to cope with both top-field and bottom-field first formats. You can get things VERY wrong if you output interlaced content with reverse field-dominance...
quote +1 ,
like auto-switch fps, i think a nice Feature fro kodi can be "Adjusted display Output to match video Resolutions " , person like me have top level AV receiver or TV with high quality video processor for upscaling or enhancement.
but this is off topic
(2015-09-22, 09:04)mirror88 Wrote: [ -> ]anybody can provide a 3d mkv file for us to test?
You can use makeMKV to convert your 3D.ISO to 3D MKV
MAKEMKV
(2015-09-22, 12:31)movie78 Wrote: [ -> ] (2015-09-22, 09:04)mirror88 Wrote: [ -> ]anybody can provide a 3d mkv file for us to test?
MAKEMKV
Thx
(2015-09-21, 18:48)Skank Wrote: [ -> ]Is netflix hd or netflix 4k now supported or not?
Doesn't support currently,Sorry about that
MAKEMKV
Actually the MakeMKV don't convert...it will
extract the exact copy 1:1 from the iso or disk.
mirror
Makemkv Its free for 30days, don't forget to tick the box for 3DMCV..
...and mount the ISO first (using Virtual CloneDrive or similar)
(2015-09-21, 13:14)movie78 Wrote: [ -> ] (2015-09-21, 04:08)mirror88 Wrote: [ -> ]Hi:
it will support 23.976.
Zidoo X6 Pro
23.976 Support
3D ISO support
HD Audio Support
Will you be able to map (password protected) Network drives(NFS ; SMB and UPNP) within Kodi without complication like some Android Media Player?
Hi:
It hase some problem for 23.976,and we are working to fix this problem.
Good luck... hopefully won't require new SDK from Rockchip to support.
(2015-09-22, 14:05)mirror88 Wrote: [ -> ] (2015-09-21, 13:14)movie78 Wrote: [ -> ] (2015-09-21, 04:08)mirror88 Wrote: [ -> ]Hi:
Zidoo X6 Pro
23.976 Support
3D ISO support
HD Audio Support
Hi:
Glad that you found a bug and already working on a solution
I had a chat this morning with geekbuying anyone who ordered before the 20th September should be in the first consignment for dispatch the 1st of October
(2015-09-23, 09:51)goujam Wrote: [ -> ]I had a chat this morning with geekbuying anyone who ordered before the 20th September should be in the first consignment for dispatch the 1st of October
I recieved a mail from them too, and was worried that i wouldnt get it as promised. But if you say the people after the 20th september will get theirs then i got a little luck ( ordered it the 18th)
Im good then.. I also ordered in 18th
Yeah I ordered the 16th next problem will be the import duty. I went with dhl for quicker delivery so will no doubt get the import duty to pay
Just ordered mine today.
Hopefully this box is as good as it looks and doesn't disappoint.
(2015-09-22, 12:46)mirror88 Wrote: [ -> ] (2015-09-21, 18:48)Skank Wrote: [ -> ]Is netflix hd or netflix 4k now supported or not?
Hi, I'm new on this forum but I'm reading you for several days.
About Netflix HD (1080p), I wrote to Zidoo's facebook page, and they said that "Yes, our XPro supports this".
So...where is the truth?
(2015-09-23, 15:28)medulin Wrote: [ -> ]Hi, I'm new on this forum but I'm reading you for several days.
It will not. Netflix HD requires that the box is Google certified (for boxes that run regular Android OS). If the box doesn't have GMS certification, there is no possibility of Netflix HD.
