(2015-10-05, 21:53)hdmkv Wrote: [ -> ]Problem is 7.1.2 or 7.1.4 AVR's are crazy expensive right now. And, if buying now, I'd want to get something ATMOS and DTS:X capable. Will wait, especially as so few Blu-rays that have ATMOS/DTS:X.
The Pioneer SC-95 is only $1500 and it can output 7.2.4. ATMOS/DTS:X.
You can spend others money realy well...
(2015-10-05, 22:30)Worlon Wrote: [ -> ]You can spend others money realy well...
I spend more than that on my
(2015-10-06, 00:33)hdmkv Wrote: [ -> ]Okay, none of my 3D ISO's play in 3D... rather full SBS mode. See my post on last page for more tests results.
BTW movie78, Pioneer SC-95 is $1000 at Crutchfield with ATMOS, but w/o DTS:X.
$1000 is a hell of a deal..
DTS:X® format available with firmware upgrade
Quote:$1000 is a hell of a deal..
I was wrong... it's for the SC-85. For the SC-95, it's $1,600. Too much!
Dude, test 3D ISO on Zidoo X6... playing in full, proper frame-packed 3D?
(2015-10-06, 02:04)hdmkv Wrote: [ -> ]Quote:$1000 is a hell of a deal..
Kodi SMB network mapping
working
BD MENU
Not Working
3D.ISO is playback
Not working
3D.ISO plays as SBS when select the option to play 3D
Can't the option to set Kodi to Auto-start on boot-up.
Are you using the original Kodi or did you update to RC3?
Using Zidoo's pre-installed, custom Kodi 15.1... that's the whole idea. Hopefully mirror88 can advise.
(2015-10-06, 02:26)hdmkv Wrote: [ -> ]Using Zidoo's pre-installed, custom Kodi 15.1... that's the whole idea. Hopefully mirror88 can advise.
Good job on your review.
That was quick...
Logitect Harmony One Testing with Zidoo X6
Logitech Harmony One remote works {Just needs to map remote in MyHarmony as Zidoo>X9}
Kodi Context menu works
Exit and Returns works
The remote is pretty snappy and very responsive.
Now Completed the two way 1080P decoding, but because of the reasons for HDMI EDID. The custom KODI does not send 3D signals to the tv. So it looks like SBS, we're in the check this problem.You can change your TV's 3D model to left/right temporary
(2015-10-06, 04:00)movie78 Wrote: [ -> ]Logitect Harmony One Testing with Zidoo X6
We will create a new device "zidoo x6" in logitech harmony soon,It will be a full functions control,such as
top,subtitle,audio,page up,page down.
And we are checking 23.976 & 59.940 issue,It will have an answer in a week.
We will release a beta custom kodi version on Oct. 9th.
1.Optimize the HDMI adaptation problem when playing 4K 60Hz.
2.Modify the buffer strategy of underlying decoder, and will optimize related code.
3. The optimization of support to HEVC TS streaming
hdmkv, and in your opinion. What has it got better quality, zidoo x6 or himedia q5. What's better? What's your favorite?
