(2015-10-06, 06:13)mirror88 Wrote: [ -> ] (2015-10-06, 02:04)hdmkv Wrote: [ -> ]Quote:$1000 is a hell of a deal..
I was wrong... it's for the SC-85. For the SC-95, it's $1,600. Too much!
Dude, test 3D ISO on Zidoo X6... playing in full, proper frame-packed 3D?
Now Completed the two way 1080P decoding, but because of the reasons for HDMI EDID. The custom KODI does not send 3D signals to the tv. So it looks like SBS, we're in the check this problem.You can change your TV's 3D model to left/right temporary
3D frame-packed was the main reason why this media player was attractive.
When is this going to get fix?
(2015-10-06, 10:27)movie78 Wrote: [ -> ]3D frame-packed was the main reason why this media player was attractive.
Like mirror88 said the next firmware is on 09 october and doesn't include the 3D fix.
Ive read somewhere the Zidoo Team will try to release a new firmware
every month fixing bugs or adding new funcionalities..
(2015-10-06, 06:34)mirror88 Wrote: [ -> ]We will release a beta custom kodi version on Oct. 9th.
1.Optimize the HDMI adaptation problem when playing 4K 60Hz.
2.Modify the buffer strategy of underlying decoder, and will optimize related code.
3. The optimization of support to HEVC TS streaming
hdmkv How is the picture quality of hd(blu ray) and sd(dvd) content? For those of us not using an avr(just tv speakers) will it decode/downmix hd audio?
Is it possible to output sound from Kodi simultaneously through the HDMI and SPDIF on this device ? I would like to connect it to both my TV and my DAC, and not have to switch the output every time I want to listen through one or the either.
Also, does anyone know if it is possible to use an SD card of 64gb or more ?
(2015-10-06, 12:29)movie78 Wrote: [ -> ] (2015-10-06, 11:20)mirror88 Wrote: [ -> ] (2015-10-06, 10:58)movie78 Wrote: [ -> ]On this page you said that the player support frame-packed 3D
3D
Hi,you can try it in the explorer,about frame-packed play in kodi,It will have an answer in a week
USB NTFS is not recognize by media player
FAT32 works
can u give me more infomations?
X6's explorer and media player support NTFS
(2015-10-06, 11:45)frenchroms Wrote: [ -> ]Is it possible to output sound from Kodi simultaneously through the HDMI and SPDIF on this device ? I would like to connect it to both my TV and my DAC, and not have to switch the output every time I want to listen through one or the either.
Hi,must to switch the output
About SD card 64GB,I haven't tested it, Anyone can try it?
(2015-10-06, 06:13)mirror88 Wrote: [ -> ]Now Completed the two way 1080P decoding, but because of the reasons for HDMI EDID. The custom KODI does not send 3D signals to the tv. So it looks like SBS, we're in the check this problem.You can change your TV's 3D model to left/right temporary
Hi mirror88, proper 3D ISO playback is a huge deal as it's probably the biggest selling point for X6 Pro. Anyway, glad you know the root cause & are working on fixing.
(2015-10-06, 06:20)mirror88 Wrote: [ -> ]And we are checking 23.976 & 59.940 issue,It will have an answer in a week.
For this, are you dependent on a new SDK from Rockchip?
Can you also look into the LPCM issue I noted earlier... 7.1 is passed as 2.0 to AVR.
(2015-10-06, 08:49)langostino Wrote: [ -> ]@hdmkv, and in your opinion. What has it got better quality, zidoo x6 or himedia q5. What's better? What's your favorite?
Can't say yet as I've only done quick video tests. Part of movies, concerts, etc. I checked out looked very good. Will do some PQ comparisons with Q5 and RPi2 shortly.
(2015-10-06, 11:18)phillyman75 Wrote: [ -> ]@hdmkv How is the picture quality of hd(blu ray) and sd(dvd) content? For those of us not using an avr(just tv speakers) will it decode/downmix hd audio?
Unless movie78 or someone beats me to it, will check on this today.
I know that the X6 Pro is similar to the HiMedia H8, but still it has some advantages/disadvantages over it... isn't better to add X6 Pro to the table?!
(2015-10-06, 06:16)mirror88 Wrote: [ -> ] (2015-10-06, 04:00)movie78 Wrote: [ -> ]Logitect Harmony One Testing with Zidoo X6
Logitech Harmony One remote works {Just needs to map remote in MyHarmony as Zidoo>X9}
Kodi Context menu works
Exit and Returns works
The remote is pretty snappy and very responsive.
We will create a new device "zidoo x6" in logitech harmony soon,It will be a full functions control,such astop,subtitle,audio,page up,page down.
How do you create that device from logitech harmony??
(2015-10-06, 02:26)hdmkv Wrote: [ -> ]Using Zidoo's pre-installed, custom Kodi 15.1... that's the whole idea. Hopefully mirror88 can advise.
I still don't understand, does the X6 Pro uses a custom Kodi version or can use the one that is on Play Store ?!
If it can use the version that is on Play Store, can passthrough HD Audio files ?!?! Or this only works using the custom kodi version?!
By the way, best places to buy this, specially in Europe preferably... ?!
