(2015-10-09, 04:06)mirror88 Wrote: [ -> ] (2015-10-08, 20:21)movie78 Wrote: [ -> ] (2015-10-08, 20:12)Domengo Wrote: [ -> ]On zodoo forum "mirror" say yes! Whats' the true?http://forum.zidoo.tv/index.php?threads/hard-disk.549/
Tks
NTFS USB
Zidoo X6 File Explorer = Not Working
Zidoo Media Player = Working
KODI =
I need to test it KODI again so that i can provide you with an accurate answer.
We tested a lot of NTFS hardware in Explorer without problems
Can you give me more Informations,We will fix it
I have a external 32GB harddrive plug in formatted NTFS and file explorer couldn't find it.
Also try 32GB USB drive NTFS and had the same issue.
(2015-10-08, 21:02)Domengo Wrote: [ -> ]Thank you so much movie
Kodi does find the external NTFS drive.
In Kodi
SETTINGS->
File Manager->
ADD SOURCE->
BROWSE
Then you have locate
MNT and the name of storage drive.
(2015-10-09, 04:07)mirror88 Wrote: [ -> ] (2015-10-08, 16:30)popcornmix Wrote: [ -> ] (2015-10-07, 21:29)movie78 Wrote: [ -> ]You guys used their source code to get RPi2 3D.ISO working.
Is the any implementation ideas that you can provide to them.
The kodi code is all public, but that is merely gui options and plumbing. See here.
They will need something on the kernel/firmware side to implement the framepacked modes.
It's all described in the specs, but it looks like a 1920x2205 resolution HDMI mode, with the right clocks and signalling.
Thanks for your help,We are checking it
Only 3 things to fix for now.
3D.ISO Frame-packing (
High Priority)
23.976 (
High Priority)
NTFS (Not very important to me)
That is it...
(2015-10-08, 08:56)Koying Wrote: [ -> ]2) Full SBS/TAB: The 2 full frames are rendered in software as one frame, producing 1920x2160 or 3840x1080. This combined frame is then passed to the TV which split the frame to produce 3D.
Problem here is that you must have 4K support both on the box and on the TV, and the TV must support this (as an example, my sony TV is 4K but doesn't support Full SBS/TAB)
Are you sure about this? A full TAB 3D video seems to play fine on Minix Z64-Android on a Sony 1080p TV. I just had to select TAB mode for the TV. Minix Z64-A has max. 1080p output.
Here is a Kodi debug log:
http://xbmclogs.com/pos0ikipy
Here is the mediainfo for the video that I tested:
http://pastebin.com/ue21XmNc
What I don't know is whether Kodi is downscaling the video to Half TAB or not. I couldn't find anything to that effect in the debug log.
(2015-10-09, 04:31)movie78 Wrote: [ -> ] (2015-10-09, 04:06)mirror88 Wrote: [ -> ] (2015-10-08, 20:21)movie78 Wrote: [ -> ]NTFS USB
KODI =
Can you try to exit the Explorer and launch it again when plus the USB drive,
It's a refresh issus,We'll slove it in next version.
(2015-10-09, 04:36)movie78 Wrote: [ -> ]Kodi does find the external NTFS drive.
In Kodi SETTINGS->File Manager->ADD SOURCE->BROWSE
Then you have locate MNT and the name of storage drive.
So pleasure for this good notice...and fix promise by movie....
Thank you
(2015-10-09, 04:44)movie78 Wrote: [ -> ]Only 3 things to fix for now.....
1) 3D.ISO Frame-packing (
High Priority)
2) 23.976 (
High Priority)
3) 7.1 LPCM downmix to 2.0 LPCM (Secondary, but
To do)
4) NTFS (Secondary, but
To do) Not issue.
IS OK
That is it all?
atmos en dtshd 7.1 unreliable? That scares me !!!!
i thought it worked ok on hdmi passthrough
ant not a word about 3d iso
(2015-10-09, 15:29)Skank Wrote: [ -> ]atmos en dtshd 7.1 unreliable? That scares me !!!!
ATMOS and DTSHD MA = Works..
(2015-10-09, 15:35)movie78 Wrote: [ -> ] (2015-10-09, 15:29)Skank Wrote: [ -> ]atmos en dtshd 7.1 unreliable? That scares me !!!!
but unreliable according to review
(2015-10-09, 15:38)Skank Wrote: [ -> ] (2015-10-09, 15:35)movie78 Wrote: [ -> ] (2015-10-09, 15:29)Skank Wrote: [ -> ]atmos en dtshd 7.1 unreliable? That scares me !!!!
CNXSOFT is not the guy to trust about Audio,I had my argument with him long time ago
(2015-10-09, 15:48)movie78 Wrote: [ -> ] (2015-10-09, 15:38)Skank Wrote: [ -> ] (2015-10-09, 15:35)movie78 Wrote: [ -> ]ATMOS and DTSHD MA = Works..
You must be Mike
As I said in the review, it might be because of timing issue with Onkyo TX-NR636 AV receiver. Zidoo told me other people tested it without issues.
But in the video I shot, you can clearly see I played a video with Dolby Digital 7.1+ with the AV receiver without issues (so config is OK), and switching to a video with TrueHD 7.1 I had no audio at all with the HDMI icon blinking on my AV receiver display. Normally a reboot may fix this.
(2015-10-09, 16:16)cnxsoft Wrote: [ -> ] (2015-10-09, 15:48)movie78 Wrote: [ -> ] (2015-10-09, 15:38)Skank Wrote: [ -> ]but unreliable according to review
You must be Mike
Yes!I'm Mike,you got me
The Dolby TrueHD 7.1 specker test has some problem playing in most media player i have tested.(Chromebox;VidOn box and even the Zidoo X6)
I will test the DTS HD MA 7.1 file that you tested tonight.
I see you doing well with your Audio testing now
