(2015-10-21, 23:39)Janaboy Wrote: [ -> ]23.94Hz is normal? Before not remember to this refresh-rate
Not normal... should be 23.976, or show rounded up 23.98.
(2015-10-22, 01:32)hdmkv Wrote: [ -> ]Not normal... should be 23.976, or show rounded up 23.98.
I have only seen 23.99 on my Epson projector. Lumagen shows 24.000 and I know that Lumagen is dead-on. I have checked Lumagen's numbers against a Quantum Data 980 protocol analyzer.
(2015-10-21, 11:02)mirror88 Wrote: [ -> ]about Optimization 23.976
We chose the other way.
We use an algorithm try to change the video's time sequence and framerate to suit 24HZ output.
so the output is still 24HZ.Because a lot of TV does not support 23.976
You can try to play a FPS test video.You'll find a clear improvement.
But it also has some problems,such as Audio SYNC.we are checking
Say what!?!?!? What TVs are you talking about?
Some TV's might support 1080p24.000 as well, but the video on Blu-rays is 24/1.001Hz (aka 23.976). All formats in the US market are drop frame. 60/1.001 & 24/1.001. 50Hz in Europe is 50.000Hz.
Some early Blu-ray players got this wrong and output 24.000Hz while they were decoding at 24/1.001 and had a repeated frame every ~42 seconds.
My Samsung plasma (US model) will accept and sync to 24/1.001, 24.000, 50.000, 60/1.001 and 60.000. However, none of that changes that the content on the disc the makes its way into files is drop frame ( /1.001) and should be played back as such.
We sloved the out of Audio sync issus today.
And we are checking the kodi UI oversize when play 3D framepacking
Mirror88 i would love to have your comment on the artefacts issue !!!!!!!!!!!!!!
Is the chip overclocked?
IS it cause of the heat in the device?
Any comment please
Can not install any add-ons in kodi (fw 1.0.18)
(2015-10-22, 10:41)tienlequoc Wrote: [ -> ]Can not install any add-ons in kodi (fw 1.0.18)
You do realise 1.0.18 wasn't a proper build it was used just to see if 3D frame packing was working.
mirror88, can you also enable the 3D menu in Zidoo Kodi OSD. Right now, none of the options there seem to work.
(2015-10-22, 10:27)Skank Wrote: [ -> ]Mirror88 i would love to have your comment on the artefacts issue !!!!!!!!!!!!!!
Any comment please
Is it occurs after SEEK when play 3D MVC?
If yes,We found after SEEK will be lost SPS and PPS frames.
There is no good solution.
It only happens after SEEK instant when play 3D MVC
We'll release a beta version tomorrow
Solved Audio out of SYNC
Solved KODI OSD oversize when play 3D MVC
Hey Guys!
Have some things what i not really understand..i'm not programmer or prof in this video decoding things..
But why just not simple to maket it this refreshrate thing?
For me look simple: If the player sense on the movie the 23.976 then change the resolution to that, if the tv talk back (i'm think over HDMI can this, or i think wrong?), if can't change to 23.976, than change to 24p, if no 24p, then to defeault (50hz or 60hz which in the adrnoid default setting).
Why not just simple like i wrote?
So: if movie 23.976 -> If can -> 23.976 -> if not -> 24.000 -> if not -> 50.000 or 60.000
And the next.. 24 -> 24 -> if not -> 50 or 60..
Other things:
I have still 1.0.15 but i tried today some browsing and playing youtube..browsing is ok, but youtube is little but lagging and the audio is out of sync. This out of sync is same problem as in Kodi?
Thanks..
(2015-10-22, 14:10)mirror88 Wrote: [ -> ]We'll release a beta version tomorrow
Glad to see you guys on top of fixing issues. I'll complete my review on p.16 once at least audio sync is fixed.
I know getting 23.976 perfect isn't an easy one, but please keep at it
(2015-10-22, 14:07)mirror88 Wrote: [ -> ] (2015-10-22, 10:27)Skank Wrote: [ -> ]Mirror88 i would love to have your comment on the artefacts issue !!!!!!!!!!!!!!
Any comment please
Artefacts happen in all places
Not only after seek
it happens with a normal mkv too
i posted mediainfo of one example; its on zidoo forum too
several people confirmed seeing artefacts in video/tvshows/3d iso
http://forum.zidoo.tv/index.php?threads/...cture.576/
http://forum.zidoo.tv/index.php?threads/...-0-18.579/
(2015-10-22, 14:16)hdmkv Wrote: [ -> ] (2015-10-22, 14:10)mirror88 Wrote: [ -> ]We'll release a beta version tomorrow
I know getting 23.976 perfect isn't an easy one, but please keep at it .
Any kind of way, are in order to better watch the film
When we solved the audio out of SYNC,You can try again to play a FPS test video.You'll find a clear improvement.
