2015-09-17, 08:45
Hello,
Kodi Version 15.1 with Android specific fix last updated 23rd August 15.
I recently switched TV’s I was using a 49” UHD and am now using a 40” Full HD 1080p.
The front screen showing the android apps is fine and login to Kodi is also ok. The problem is with playback for some reason the screen has shifted to the bottom right and I can’t re-centre it.
I’ve tried clicking on the video reel during playback and centred it that way all this did was fill the screen and not centre the playback.
One the android screen I made sure the resolution was on Auto detect, strangely is say 720 rather than 1080.
I uninstalled Kodi altogether and re-installed the latest version (as mentioned above), again the same problem occurred.
Any help / suggestions would be very much appreciated, I don’t like to be beaten but I’m struggling to find any other options to centre the playback in Kodi.
Thanks in advance.
Thanks in advance.
