Full Version: Kodi servers
Is there any problem with Kodi servers or it is just my internet problem?
I cannot download most of the kodi's add-ons. Examples are Backup add-on (robwebers), subtitles add-ons (opensubtitles.org, etc) video add-ons (MTV, Arte, etc ). Even from the Kodi's official website I get no response if I try to download an add-on mentioned above.
Thanks in advance.
Ok I have moved to a friend's house (different HAP) and it seems fine. So either is fixed or is my ISP.
I will find out when I will be back.
our servers work fine
There are websites with services that can perform independent checks for you to let you know if a webside is down or if the issue is on your onw end, see example:
http://downforeveryoneorjustme.com
http://www.isup.me
http://www.websitenotworking.com
http://www.isitdownrightnow.com
(2015-09-19, 14:28)RockerC Wrote: [ -> ]There are websites with services that can perform independent checks for you to let you know if a webside is down or if the issue is on your onw end, see example:
http://www.isup.me
Those wouldn't be very helpful at all with our set-up.
After more search about this matter, I have found out that even with different ISP I still see a problem. Some add-ons, randomly I believe, when you click to download them (for example the backup add-on) it brings me to the http://ftp.cc.uoc.gr. But if you try seconds later it gives you this mirrors.nl.leaseweb.net and you can download. Then seconds later again I cannot because is from the above ftp. To summarize every add-on which is on the http://ftp.cc.uoc.gr is not reachable from every ISP I have tried.
So is it a Kodi problem?
(2015-09-21, 08:16)Dreamup Wrote: [ -> ]After more search about this matter, I have found out that even with different ISP I still see a problem. Some add-ons, randomly I believe, when you click to download them (for example the backup add-on) it brings me to the http://ftp.cc.uoc.gr. But if you try seconds later it gives you this mirrors.nl.leaseweb.net and you can download. Then seconds later again I cannot because is from the above ftp. To summarize every add-on which is on the http://ftp.cc.uoc.gr is not reachable from every ISP I have tried.
No it means that a mirror is having issues and our automated system didn't pick up on it - this rarely happens but can happen.
We will contact the mirror and (temporarily) remove them from the rotation until they fix the issue.
I have disabled the University of Crete mirror
thx Smile
Yep it seems good now, I will let you know if the problem persists when I will be back home. Here at work seems fine now.
