(2015-09-20, 08:22)fritsch Wrote: [ -> ]Please post the log from official 5.95.5 - the log you have attached uses a current WIP method to switch resolutions which is not only broken for you currently.
Edit: And as you are at it, please remove the AVR out of the chain and test only with the TV and OE 5.95.5 - i think the AVR needs a powercycle.
I re-installed 5.95.5 OE6 Beta 5 tonight...
Logs:
Sync Disabled:
http://xbmclogs.com/p4wpqrbsj
Sync Enabled:
http://xbmclogs.com/pi9vcxo6c
Sync Enabled (direct to TV - no AVR):
http://xbmclogs.com/pn4j6yaeq
The last two scenarios result in no HDMI signal.
Here's the pastebinit output of kodi-xrandr...
Sync Disabled:
http://sprunge.us/BZhV
Sync Enabled:
http://sprunge.us/KcWE
Output of xrandr --verbose...
Screen 0: minimum 8 x 8, current 1920 x 1080, maximum 32767 x 32767
DP1 disconnected (normal left inverted right x axis y axis)
Identifier: 0x43
Timestamp: -216601193
Subpixel: unknown
Clones: HDMI1
CRTCs: 0 1 2
Transform: 1.000000 0.000000 0.000000
0.000000 1.000000 0.000000
0.000000 0.000000 1.000000
filter:
Broadcast RGB: Automatic
supported: Automatic, Full, Limited 16:235
audio: auto
supported: force-dvi, off, auto, on
DP2 disconnected (normal left inverted right x axis y axis)
Identifier: 0x44
Subpixel: unknown
Clones: HDMI2
CRTCs: 0 1 2
filter:
audio: auto
HDMI1 disconnected (normal left inverted right x axis y axis)
Identifier: 0x45
Subpixel: unknown
Clones: DP1
CRTCs: 0 1 2
filter:
aspect ratio: Automatic
supported: Automatic, 4:3, 16:9
audio: auto
HDMI2 connected 1920x1080+0+0 (0x49) normal (normal left inverted right x axis y axis) 1660mm x 934mm
Identifier: 0x46
Subpixel: unknown
Gamma: 1.0:1.0:1.0
Brightness: 1.0
Clones: DP2
CRTC: 0
CRTCs: 0 1 2
filter:
EDID:
00ffffffffffff004dd9039401010101
0119010380a65d780a0dc9a057479827
12484c2108008180a9c0714fb3000101
010101010101023a801871382d40582c
45007ca66300001e011d007251d01e20
6e2855007ca66300001e000000fc0053
4f4e5920545620202a30320a000000fd
00303e0f461e000a202020202020013a
02035ef3555d5e5f621f101405130420
2212160307111502060138097f070f7f
071507503e1fc04d0200570601677e01
5f5401835f000079030c004300b83c2f
d08b010203040100073046566676b660
70e200f9e305c301e50e60616566011d
8018711c1620582c25007ca66300009e
000000000000000000000000000000f5
audio: auto
1920x1080 (0x49) 148.500MHz +HSync +VSync *current +preferred
h: width 1920 start 2008 end 2052 total 2200 skew 0 clock 67.50KHz
v: height 1080 start 1084 end 1089 total 1125 clock 60.00Hz
4096x2160 (0xe5) 297.000MHz +HSync +VSync
h: width 4096 start 5116 end 5204 total 5500 skew 0 clock 54.00KHz
v: height 2160 start 2168 end 2178 total 2250 clock 24.00Hz
4096x2160 (0xe6) 296.704MHz +HSync +VSync
h: width 4096 start 5116 end 5204 total 5500 skew 0 clock 53.95KHz
v: height 2160 start 2168 end 2178 total 2250 clock 23.98Hz
3840x2160 (0xe7) 297.000MHz +HSync +VSync
h: width 3840 start 4016 end 4104 total 4400 skew 0 clock 67.50KHz
v: height 2160 start 2168 end 2178 total 2250 clock 30.00Hz
3840x2160 (0xe8) 297.000MHz +HSync +VSync
h: width 3840 start 4896 end 4984 total 5280 skew 0 clock 56.25KHz
v: height 2160 start 2168 end 2178 total 2250 clock 25.00Hz
3840x2160 (0xe9) 297.000MHz +HSync +VSync
h: width 3840 start 5116 end 5204 total 5500 skew 0 clock 54.00KHz
3840x2160 (0xea) 296.704MHz +HSync +VSync
h: width 3840 start 4016 end 4104 total 4400 skew 0 clock 67.43KHz
v: height 2160 start 2168 end 2178 total 2250 clock 29.97Hz
3840x2160 (0xeb) 296.704MHz +HSync +VSync
h: width 3840 start 5116 end 5204 total 5500 skew 0 clock 53.95KHz
1920x1080 (0xec) 148.500MHz +HSync +VSync
h: width 1920 start 2448 end 2492 total 2640 skew 0 clock 56.25KHz
v: height 1080 start 1084 end 1089 total 1125 clock 50.00Hz
1920x1080 (0xed) 148.352MHz +HSync +VSync
h: width 1920 start 2008 end 2052 total 2200 skew 0 clock 67.43KHz
v: height 1080 start 1084 end 1089 total 1125 clock 59.94Hz
1920x1080i (0xee) 74.250MHz +HSync +VSync Interlace
h: width 1920 start 2008 end 2052 total 2200 skew 0 clock 33.75KHz
v: height 1080 start 1084 end 1094 total 1125 clock 60.00Hz
1920x1080i (0xef) 74.250MHz +HSync +VSync Interlace
h: width 1920 start 2448 end 2492 total 2640 skew 0 clock 28.12KHz
v: height 1080 start 1084 end 1094 total 1125 clock 50.00Hz
1920x1080 (0xf0) 74.250MHz +HSync +VSync
v: height 1080 start 1084 end 1089 total 1125 clock 30.00Hz
1920x1080 (0xf1) 74.250MHz +HSync +VSync
h: width 1920 start 2558 end 2602 total 2750 skew 0 clock 27.00KHz
v: height 1080 start 1084 end 1089 total 1125 clock 24.00Hz
1920x1080i (0xf2) 74.176MHz +HSync +VSync Interlace
h: width 1920 start 2008 end 2052 total 2200 skew 0 clock 33.72KHz
v: height 1080 start 1084 end 1094 total 1125 clock 59.94Hz
1920x1080 (0xf3) 74.176MHz +HSync +VSync
v: height 1080 start 1084 end 1089 total 1125 clock 29.97Hz
1920x1080 (0xf4) 74.176MHz +HSync +VSync
h: width 1920 start 2558 end 2602 total 2750 skew 0 clock 26.97KHz
v: height 1080 start 1084 end 1089 total 1125 clock 23.98Hz
1680x1050 (0xf5) 119.000MHz +HSync -VSync
h: width 1680 start 1728 end 1760 total 1840 skew 0 clock 64.67KHz
v: height 1050 start 1053 end 1059 total 1080 clock 59.88Hz
1600x900 (0xf6) 118.963MHz -HSync +VSync
h: width 1600 start 1696 end 1864 total 2128 skew 0 clock 55.90KHz
v: height 900 start 901 end 904 total 932 clock 59.98Hz
1280x1024 (0xf7) 108.000MHz +HSync +VSync
h: width 1280 start 1328 end 1440 total 1688 skew 0 clock 63.98KHz
v: height 1024 start 1025 end 1028 total 1066 clock 60.02Hz
1152x864 (0xf8) 108.000MHz +HSync +VSync
h: width 1152 start 1216 end 1344 total 1600 skew 0 clock 67.50KHz
v: height 864 start 865 end 868 total 900 clock 75.00Hz
1280x720 (0xf9) 74.250MHz +HSync +VSync
h: width 1280 start 1390 end 1430 total 1650 skew 0 clock 45.00KHz
v: height 720 start 725 end 730 total 750 clock 60.00Hz
1280x720 (0xfa) 74.250MHz +HSync +VSync
h: width 1280 start 1720 end 1760 total 1980 skew 0 clock 37.50KHz
v: height 720 start 725 end 730 total 750 clock 50.00Hz
1280x720 (0xfb) 74.176MHz +HSync +VSync
h: width 1280 start 1390 end 1430 total 1650 skew 0 clock 44.96KHz
v: height 720 start 725 end 730 total 750 clock 59.94Hz
1024x768 (0xfc) 65.000MHz -HSync -VSync
h: width 1024 start 1048 end 1184 total 1344 skew 0 clock 48.36KHz
v: height 768 start 771 end 777 total 806 clock 60.00Hz
800x600 (0xfd) 40.000MHz +HSync +VSync
h: width 800 start 840 end 968 total 1056 skew 0 clock 37.88KHz
v: height 600 start 601 end 605 total 628 clock 60.32Hz
720x576 (0xfe) 27.000MHz -HSync -VSync
h: width 720 start 732 end 796 total 864 skew 0 clock 31.25KHz
v: height 576 start 581 end 586 total 625 clock 50.00Hz
720x576i (0xff) 13.500MHz -HSync -VSync Interlace
h: width 720 start 732 end 795 total 864 skew 0 clock 15.62KHz
v: height 576 start 580 end 586 total 625 clock 50.00Hz
720x480 (0x100) 27.027MHz -HSync -VSync
h: width 720 start 736 end 798 total 858 skew 0 clock 31.50KHz
v: height 480 start 489 end 495 total 525 clock 60.00Hz
720x480 (0x101) 27.000MHz -HSync -VSync
h: width 720 start 736 end 798 total 858 skew 0 clock 31.47KHz
v: height 480 start 489 end 495 total 525 clock 59.94Hz
720x480i (0x102) 13.513MHz -HSync -VSync Interlace
h: width 720 start 739 end 801 total 858 skew 0 clock 15.75KHz
v: height 480 start 488 end 494 total 525 clock 60.00Hz
720x480i (0x103) 13.500MHz -HSync -VSync Interlace
h: width 720 start 739 end 801 total 858 skew 0 clock 15.73KHz
v: height 480 start 488 end 494 total 525 clock 59.94Hz
640x480 (0x104) 25.200MHz -HSync -VSync
h: width 640 start 656 end 752 total 800 skew 0 clock 31.50KHz
v: height 480 start 490 end 492 total 525 clock 60.00Hz
640x480 (0x105) 25.175MHz -HSync -VSync
h: width 640 start 656 end 752 total 800 skew 0 clock 31.47KHz
v: height 480 start 490 end 492 total 525 clock 59.94Hz
VIRTUAL1 disconnected (normal left inverted right x axis y axis)
Identifier: 0x47
Subpixel: no subpixels
Clones:
CRTCs: 3
filter:
Hopefully this helps figure out why sync display to video is not working for my Haswell Mac Mini.
One thing I notice is that when selecting an HDMI output in Kodi for bit streaming, my TV appears connected to HDMI1. When looking at xrandr --verbose, the TV is connected to HDMI2. Not sure if this is just a difference in enumeration of the outputs, or a sign of an issue.
