Full Version: Issue with one of Kodi mirrors for last couple of days
I've been trying to setup a new Kodi install for the last couple of days and it seems like one of Kodi's mirrors is not functioning, resulting in various download and add-on update errors. Even the Kodi repository itself could not load/update on a new install because of this.
The mirror which does not seem to work is http://ftp.cc.uoc.gr/
Does anyone else have this kind of issue?
For example, you can try to download Kodi from this mirror at http://ftp.cc.uoc.gr/mirrors/xbmc/releas...engard.exe (this is one of the redirects I get when trying to access http://mirrors.kodi.tv/releases/win32/ko...engard.exe). For me, this download attempt keeps failing.
I appreciate any help.
Thanks for posting, i came here to ask the same question. I can download 15.1 but then all add on downloads and updates fail because that site seems to be offline.
So, aside from using a vpn to make some other mirror 'closer' is there a way to either define a better mirror or block one that doesn't work?
There is another report about this mirror having issues.
We will contact them and (temporarily) remove them from the rotation until they fix the issue.
I have disabled the university of Crete mirror.
I originally posted in the wrong forum so unfortunately I didn't see the other report. Only after the thread was moved I saw it...
I'll know better next time.
Thanks a lot for the help!!
Don't worry about it Smile
no problem, thanks for identifying the issue.
