Here is the Log output. When I try to invoke the externlal player it fails because the pathsubstitution did not work.....The log dis load the advancedsettings.xml though??
Thanks for looking
Regards Alfred
18:38:22 T:2052 NOTICE: special://profile/ is mapped to: special://masterprofile/
18:38:22 T:2052 NOTICE: -----------------------------------------------------------------------
18:38:22 T:2052 NOTICE: Starting Kodi (15.1 Git:20150816-f4dda26). Platform: Windows NT x86 32-bit
18:38:22 T:2052 NOTICE: Using Release Kodi x32 build
18:38:22 T:2052 NOTICE: Kodi compiled Aug 16 2015 by MSVC 180030723 for Windows NT x86 32-bit version 6.0 (0x06000000)
18:38:22 T:2052 NOTICE: Running on Gigabyte Technology Co., Ltd. GA-880G-UD3H with Windows 8.1, kernel: Windows NT x86 64-bit version 6.3
18:38:22 T:2052 NOTICE: Host CPU: AMD Athlon II X2 255 Processor, 2 cores available
18:38:22 T:2052 NOTICE: Desktop Resolution: 1920x1080 32Bit at 23Hz
18:38:22 T:2052 NOTICE: Running with administrator rights
18:38:22 T:2052 NOTICE: Aero is enabled
18:38:22 T:2052 NOTICE: special://xbmc/ is mapped to: C:\Program Files (x86)\Kodi
18:38:22 T:2052 NOTICE: special://xbmcbin/ is mapped to: C:\Program Files (x86)\Kodi
18:38:22 T:2052 NOTICE: special://masterprofile/ is mapped to: C:\Users\root\AppData\Roaming\Kodi\userdata
18:38:22 T:2052 NOTICE: special://home/ is mapped to: C:\Users\root\AppData\Roaming\Kodi\
18:38:22 T:2052 NOTICE: special://temp/ is mapped to: C:\Users\root\AppData\Roaming\Kodi\cache
18:38:22 T:2052 NOTICE: The executable running is: C:\Program Files (x86)\Kodi\Kodi.exe
18:38:22 T:2052 NOTICE: Local hostname: CNMA
18:38:22 T:2052 NOTICE: Log File is located: C:\Users\root\AppData\Roaming\Kodi\kodi.log
18:38:22 T:2052 NOTICE: load settings...
18:38:22 T:2052 WARNING: CSettingString: unknown options filler "timezonecountries" of "locale.timezonecountry"
18:38:22 T:2052 WARNING: CSettingString: unknown options filler "timezones" of "locale.timezone"
18:38:22 T:2052 NOTICE: No settings file to load (special://xbmc/system/advancedsettings.xml)
18:38:22 T:2052 NOTICE: Loaded settings file from special://profile/advancedsettings.xml
18:38:22 T:2052 NOTICE: Contents of special://profile/advancedsettings.xml are...
<advancedsettings>
<pathsubstitution>
<substitute>
<from>nfs://172.168.1.1/mnt/Vol1/Videos/</from>
<to>X:\Videos\</to>
</substitute>
</pathsubstitution>
</advancedsettings>
18:38:22 T:2052 NOTICE: Default DVD Player: dvdplayer
18:38:22 T:2052 NOTICE: Default Video Player: dvdplayer
18:38:22 T:2052 NOTICE: Default Audio Player: paplayer
18:38:22 T:2052 NOTICE: Disabled debug logging due to GUI setting. Level 0.
18:38:22 T:2052 NOTICE: Log level changed to "LOG_LEVEL_NORMAL"
18:38:22 T:2052 NOTICE: CMediaSourceSettings: loading media sources from special://masterprofile/sources.xml
18:38:22 T:2052 NOTICE: Loading player core factory settings from special://xbmc/system/playercorefactory.xml.
18:38:22 T:2052 NOTICE: Loaded playercorefactory configuration
18:38:22 T:2052 NOTICE: Loading player core factory settings from special://profile/playercorefactory.xml.
18:38:22 T:6400 NOTICE: Thread ActiveAE start, auto delete: false
18:38:22 T:5284 NOTICE: Thread AESink start, auto delete: false
18:38:22 T:6400 NOTICE: Found 2 Lists of Devices
18:38:22 T:6400 NOTICE: Enumerated DIRECTSOUND devices:
18:38:22 T:6400 NOTICE: Device 1
18:38:22 T:6400 NOTICE: m_deviceName : {24E493F5-8BB9-42D4-A849-A7B37E36A68B}
18:38:22 T:6400 NOTICE: m_displayName : SPDIF - Digital Audio (S/PDIF) (2- High Definition Audio Device)
18:38:22 T:6400 NOTICE: m_displayNameExtra: DIRECTSOUND: Digital Audio (S/PDIF) (2- High Definition Audio Device)
18:38:22 T:6400 NOTICE: m_deviceType : AE_DEVTYPE_IEC958
18:38:22 T:6400 NOTICE: m_channels : FL,FR
18:38:22 T:6400 NOTICE: m_sampleRates : 44100
18:38:22 T:6400 NOTICE: m_dataFormats : AE_FMT_FLOAT,AE_FMT_AC3,AE_FMT_DTS
18:38:22 T:6400 NOTICE: Device 2
18:38:22 T:6400 NOTICE: m_deviceName : {C14ED8D2-F936-4B60-8757-70BDE4C1A4B6}
18:38:22 T:6400 NOTICE: Device 3
18:38:22 T:6400 NOTICE: m_deviceName : {C9A6BEAD-7A07-4E03-B165-9DB77246D48E}
18:38:22 T:6400 NOTICE: m_displayName : SPDIF - Digital Audio (S/PDIF) (2- Sound Blaster X-Fi Xtreme Audio)
18:38:22 T:6400 NOTICE: m_displayNameExtra: DIRECTSOUND: Digital Audio (S/PDIF) (2- Sound Blaster X-Fi Xtreme Audio)
18:38:22 T:6400 NOTICE: m_sampleRates : 48000
18:38:22 T:6400 NOTICE: Device 4
18:38:22 T:6400 NOTICE: m_deviceName : default
18:38:22 T:6400 NOTICE: m_displayName : default
18:38:22 T:6400 NOTICE: Enumerated WASAPI devices:
18:38:22 T:6400 NOTICE: m_displayNameExtra: WASAPI: Digital Audio (S/PDIF) (2- High Definition Audio Device)
18:38:22 T:6400 NOTICE: m_sampleRates : 192000,96000,88200,48000,44100,32000
18:38:22 T:6400 NOTICE: m_dataFormats : AE_FMT_DTS,AE_FMT_AC3,AE_FMT_S24NE4MSB,AE_FMT_S16NE,AE_FMT_S16LE,AE_FMT_S16BE
18:38:22 T:6400 NOTICE: m_displayNameExtra: WASAPI: Digital Audio (S/PDIF) (2- Sound Blaster X-Fi Xtreme Audio)
18:38:22 T:6400 NOTICE: m_sampleRates : 96000,48000,44100
18:38:22 T:2052 NOTICE: Running database version Addons19
18:38:22 T:2052 NOTICE: ADDONS: Using repository repository.xbmc.org
18:38:22 T:2052 NOTICE: ADDONS: Using repository repository.emby.kodi
18:38:22 T:2052 NOTICE: ADDONS: Using repository repository.aeon-mq5-mod-isengard
18:38:22 T:7136 NOTICE: Thread PeripBusCEC start, auto delete: false
18:38:22 T:6624 NOTICE: Thread RemoteControl start, auto delete: false
18:38:22 T:3808 NOTICE: Thread PeripBusUSB start, auto delete: false
18:38:22 T:7116 NOTICE: Thread JobWorker start, auto delete: true
18:38:22 T:2052 NOTICE: Found screen: Generic PnP Monitor on NVIDIA GeForce GTX 650 Ti BOOST, adapter 0.
18:38:22 T:2052 NOTICE: Primary mode: 1920x1080@ 23.98 - Full Screen
18:38:22 T:2052 NOTICE: Additional mode: 640x480@ 59.94 - Full Screen
18:38:22 T:2052 NOTICE: Additional mode: 640x480@ 60.00 - Full Screen
18:38:22 T:2052 NOTICE: Additional mode: 640x480@ 120.00 - Full Screen
18:38:22 T:2052 NOTICE: Previous line repeats 2 times.
18:38:22 T:2052 NOTICE: Additional mode: 640x480@ 75.00 - Full Screen
18:38:22 T:2052 NOTICE: Additional mode: 640x480@ 72.00 - Full Screen
18:38:22 T:2052 NOTICE: Additional mode: 720x480@ 59.94 - Full Screen
18:38:22 T:2052 NOTICE: Additional mode: 720x480@ 60.00 - Full Screen
18:38:22 T:2052 NOTICE: Additional mode: 720x480@ 120.00 - Full Screen
18:38:22 T:2052 NOTICE: Additional mode: 720x576@ 50.00 - Full Screen
18:38:22 T:2052 NOTICE: Additional mode: 720x576@ 120.00 - Full Screen
18:38:22 T:2052 NOTICE: Additional mode: 800x600@ 120.00 - Full Screen
18:38:22 T:2052 NOTICE: Additional mode: 800x600@ 75.00 - Full Screen
18:38:22 T:2052 NOTICE: Additional mode: 800x600@ 56.00 - Full Screen
18:38:22 T:2052 NOTICE: Additional mode: 800x600@ 60.00 - Full Screen
18:38:22 T:2052 NOTICE: Additional mode: 800x600@ 72.00 - Full Screen
18:38:22 T:2052 NOTICE: Additional mode: 1024x768@ 120.00 - Full Screen
18:38:22 T:2052 NOTICE: Additional mode: 1024x768@ 60.00 - Full Screen
18:38:22 T:2052 NOTICE: Additional mode: 1024x768@ 70.00 - Full Screen
18:38:22 T:2052 NOTICE: Additional mode: 1024x768@ 75.00 - Full Screen
18:38:22 T:2052 NOTICE: Additional mode: 1152x864@ 60.00 - Full Screen
18:38:22 T:2052 NOTICE: Additional mode: 1152x864@ 75.00 - Full Screen
18:38:22 T:2052 NOTICE: Additional mode: 1176x664@ 50.00 - Full Screen
18:38:22 T:2052 NOTICE: Additional mode: 1176x664@ 59.94 - Full Screen
18:38:22 T:2052 NOTICE: Additional mode: 1176x664@ 60.00 - Full Screen
18:38:22 T:2052 NOTICE: Additional mode: 1280x720@ 59.94 - Full Screen
18:38:22 T:2052 NOTICE: Additional mode: 1280x720@ 50.00 - Full Screen
18:38:22 T:2052 NOTICE: Additional mode: 1280x720@ 60.00 - Full Screen
18:38:22 T:2052 NOTICE: Additional mode: 1280x720@ 120.00 - Full Screen
18:38:22 T:2052 NOTICE: Additional mode: 1280x768@ 60.00 - Full Screen
18:38:22 T:2052 NOTICE: Additional mode: 1280x800@ 60.00 - Full Screen
18:38:22 T:2052 NOTICE: Additional mode: 1280x960@ 60.00 - Full Screen
18:38:22 T:2052 NOTICE: Additional mode: 1280x960@ 75.00 - Full Screen
18:38:22 T:2052 NOTICE: Additional mode: 1280x1024@ 60.00 - Full Screen
18:38:22 T:2052 NOTICE: Additional mode: 1280x1024@ 75.00 - Full Screen
18:38:22 T:2052 NOTICE: Additional mode: 1360x768@ 60.00 - Full Screen
18:38:22 T:2052 NOTICE: Additional mode: 1366x768@ 60.00 - Full Screen
18:38:22 T:2052 NOTICE: Additional mode: 1600x900@ 59.94 - Full Screen
18:38:22 T:2052 NOTICE: Additional mode: 1600x900@ 60.00 - Full Screen
18:38:22 T:2052 NOTICE: Additional mode: 1600x1024@ 59.94 - Full Screen
18:38:22 T:2052 NOTICE: Additional mode: 1600x1024@ 60.00 - Full Screen
18:38:22 T:2052 NOTICE: Additional mode: 1600x1200@ 60.00 - Full Screen
18:38:22 T:2052 NOTICE: Additional mode: 1680x1050@ 59.94 - Full Screen
18:38:22 T:2052 NOTICE: Additional mode: 1680x1050@ 60.00 - Full Screen
18:38:22 T:2052 NOTICE: Additional mode: 1768x992@ 25.00i - Full Screen
18:38:22 T:2052 NOTICE: Additional mode: 1768x992@ 29.97i - Full Screen
18:38:22 T:2052 NOTICE: Additional mode: 1768x992@ 30.00i - Full Screen
18:38:22 T:2052 NOTICE: Additional mode: 1920x1080@ 59.94 - Full Screen
18:38:22 T:2052 NOTICE: Additional mode: 1920x1080@ 60.00 - Full Screen
18:38:22 T:2052 NOTICE: Additional mode: 1920x1080@ 29.97i - Full Screen
18:38:22 T:2052 NOTICE: Additional mode: 1920x1080@ 30.00i - Full Screen
18:38:22 T:2052 NOTICE: Additional mode: 1920x1080@ 23.98 - Full Screen
18:38:22 T:2052 NOTICE: Additional mode: 1920x1080@ 24.00 - Full Screen
18:38:22 T:2052 NOTICE: Additional mode: 1920x1080@ 25.00i - Full Screen
18:38:22 T:2052 NOTICE: Additional mode: 1920x1080@ 50.00 - Full Screen
18:38:22 T:2052 NOTICE: Additional mode: 1440x576@ 59.94 - Full Screen
18:38:22 T:2052 NOTICE: Additional mode: 1440x576@ 60.00 - Full Screen
18:38:22 T:2052 NOTICE: Additional mode: 1400x1050@ 60.00 - Full Screen
18:38:22 T:2052 NOTICE: Checking resolution 16
18:38:23 T:2052 NOTICE: Running database version Addons19
18:38:23 T:2052 NOTICE: Running database version ViewModes6
18:38:23 T:2052 NOTICE: Running database version Textures13
18:38:23 T:2052 NOTICE: Running database version MyMusic52
18:38:23 T:2052 NOTICE: Running database version MyVideos93
18:38:23 T:2052 NOTICE: Running database version TV29
18:38:23 T:2052 NOTICE: Running database version Epg10
18:38:24 T:2052 WARNING: JSONRPC: Could not parse type "PVR.Details.Channel"
18:38:24 T:2052 WARNING: JSONRPC: Could not parse type "PVR.Details.ChannelGroup.Extended"
18:38:24 T:2052 WARNING: JSONRPC: Could not parse type "GUI.Property.Value"
18:38:24 T:2052 WARNING: JSONRPC: Could not parse type "Setting.Details.SettingList"
18:38:24 T:2052 NOTICE: initialize done
18:38:24 T:2272 NOTICE: Thread LanguageInvoker start, auto delete: false
18:38:24 T:2052 NOTICE: Running the application...
18:38:24 T:6720 NOTICE: Thread LanguageInvoker start, auto delete: false
18:38:24 T:2272 NOTICE: Previous line repeats 5 times.
18:38:24 T:2272 NOTICE: -->Python Interpreter Initialized<--
18:38:24 T:2052 NOTICE: Previous line repeats 6 times.
18:38:24 T:2052 NOTICE: Webserver: Starting...
18:38:24 T:2052 NOTICE: WebServer: Started the webserver
18:38:24 T:2052 NOTICE: starting upnp client
18:38:24 T:6912 NOTICE: Thread LanguageInvoker start, auto delete: false
18:38:24 T:2052 NOTICE: starting upnp server
18:38:24 T:2052 NOTICE: starting upnp controller
18:38:24 T:2052 NOTICE: starting upnp renderer
18:38:24 T:2052 NOTICE: ES: Starting event server
18:38:24 T:6604 NOTICE: Thread EventServer start, auto delete: false
18:38:24 T:6604 NOTICE: ES: Starting UDP Event server on 0.0.0.0:9777
18:38:24 T:6604 NOTICE: UDP: Listening on port 9777
18:38:24 T:1916 NOTICE: Thread TCPServer start, auto delete: false
18:38:24 T:6120 NOTICE: Thread JobWorker start, auto delete: true
18:38:24 T:7116 NOTICE: PVRManager - starting up
18:38:24 T:3292 NOTICE: Thread PVRManager start, auto delete: false
18:38:24 T:6108 NOTICE: Thread PVRClient start, auto delete: false
18:38:24 T:6884 NOTICE: script.tv.show.next.aired: ### TV Show - Next Aired starting background proc (6.0.14)
18:38:25 T:3184 NOTICE: RCB Service: Start
18:38:25 T:3184 NOTICE: RCB Service: launch RCB on startup =
18:38:25 T:3184 NOTICE: RCB Service: scrape games on startup = false
18:38:25 T:3184 NOTICE: RCB Service: Done
18:38:25 T:6620 NOTICE: StorageServer Module loaded RUN
18:38:25 T:6620 NOTICE: StorageClient-2.5.4 Starting server
18:38:25 T:6912 NOTICE: -->Python Interpreter Initialized<--
18:38:26 T:4064 NOTICE: Thread RSSReader start, auto delete: false
18:38:31 T:7004 NOTICE: Thread BackgroundLoader start, auto delete: false
18:38:31 T:6108 NOTICE: AddOnLog: MediaPortal PVR Client: Warning: no recording share defined in the TVServerXBMC settings for card 'WinFast DTV Dongle Dual Filter'
18:38:31 T:6108 NOTICE: AddOnLog: MediaPortal PVR Client: Warning: no timeshift share defined in the TVServerXBMC settings for card 'WinFast DTV Dongle Dual Filter'
18:38:31 T:2392 NOTICE: Thread LanguageInvoker start, auto delete: false
18:38:31 T:2392 NOTICE: -->Python Interpreter Initialized<--
18:38:31 T:7116 ERROR: XFILE::CDirectory::GetDirectory - Error getting videodb://movies/extrafanart/
18:38:32 T:1584 ERROR: Previous line repeats 1 times.
18:38:32 T:1584 NOTICE: Thread JobWorker start, auto delete: true
18:38:46 T:5076 NOTICE: Previous line repeats 1 times.
18:38:46 T:5076 NOTICE: Thread LanguageInvoker start, auto delete: false
18:38:46 T:5076 NOTICE: -->Python Interpreter Initialized<--
18:38:47 T:1584 WARNING: XFILE::CDirectoryFactory::Create - unsupported protocol(image) in image://nfs%3a%2f%2f192.168.1.70%2fmnt%2fVol1%2fVideos%2f3DBD-Movies%2fSin%20City%2c%20A%20Dame%20to%20Kill%20For%20(2014)%20_.3DBD._%5bCBL%5d%20%5btt0458481%5d%2fSin%20City%2c%20A%20Dame%20to%20Kill%20For%20(2014)%20_.3DBD._%5bCBL%5d%20%5btt0458481%5d-fanart.jpg/
18:38:54 T:7116 NOTICE: VideoInfoScanner: Starting scan ..
18:38:58 T:7116 NOTICE: VideoInfoScanner: Finished scan. Scanning for video info took 00:03
18:39:00 T:6464 NOTICE: Thread PVRGUIInfo start, auto delete: false
18:39:00 T:3292 NOTICE: EPG::CEpgContainer::Start - EPG thread started
18:39:00 T:6920 NOTICE: Thread EPGUpdater start, auto delete: false
18:39:03 T:3248 NOTICE: Thread BackgroundLoader start, auto delete: false
18:39:03 T:7072 NOTICE: Thread LanguageInvoker start, auto delete: false
18:39:03 T:7072 NOTICE: -->Python Interpreter Initialized<--
18:39:16 T:2052 NOTICE: ExternalPlayer Filename: C:\Users\root\AppData\Roaming\Kodi\userdata\PlayPDVD.bat
18:39:16 T:2052 WARNING: ExternalPlayer: invalid value for warpcursor: none
18:39:16 T:2052 NOTICE: ExternalPlayer Tweaks: hideconsole (false), hidexbmc (false), islauncher (false), warpcursor (none)
18:39:16 T:2052 NOTICE: CExternalPlayer::OpenFile: nfs://192.168.1.70/mnt/Vol1/Videos/3DBD-Movies/47_Ronin_(2013)_[Unknown]_[PG-13]_[voted_6.4]_[Fantasy]/47_Ronin_(2013)_.3DBD._[CBL]_[tt1335975].iso
18:39:16 T:5432 NOTICE: Thread ExternalPlayer start, auto delete: false
18:39:16 T:5432 NOTICE: CExternalPlayer:
rocess: Player : C:\Users\root\AppData\Roaming\Kodi\userdata\PlayPDVD.bat
rocess: File : nfs://192.168.1.70/mnt/Vol1/Videos/3DBD-Movies/47_Ronin_(2013)_[Unknown]_[PG-13]_[voted_6.4]_[Fantasy]/47_Ronin_(2013)_.3DBD._[CBL]_[tt1335975].iso
rocess: Content:
rocess: Args : "{1}"
rocess: Start
rocess: Lowering Kodi window
18:39:16 T:5432 NOTICE: CExternalPlayer::ExecuteAppW32: "C:\Users\root\AppData\Roaming\Kodi\userdata\PlayPDVD.bat" "nfs://192.168.1.70/mnt/Vol1/Videos/3DBD-Movies/47_Ronin_(2013)_[Unknown]_[PG-13]_[voted_6.4]_[Fantasy]/47_Ronin_(2013)_.3DBD._[CBL]_[tt1335975].iso"
18:39:19 T:5432 NOTICE: CExternalPlayer::ExecuteAppW32: WAIT_OBJECT_0
rocess: Stop
18:39:20 T:5432 NOTICE: CExternalPlayer:
rocess: Showing Kodi window TOPMOST
18:39:20 T:6400 NOTICE: Found 2 Lists of Devices
18:39:20 T:6400 NOTICE: Enumerated DIRECTSOUND devices:
18:39:20 T:6400 NOTICE: Device 1
18:39:20 T:6400 NOTICE: m_deviceName : {24E493F5-8BB9-42D4-A849-A7B37E36A68B}
18:39:20 T:6400 NOTICE: m_displayName : SPDIF - Digital Audio (S/PDIF) (2- High Definition Audio Device)
18:39:20 T:6400 NOTICE: m_displayNameExtra: DIRECTSOUND: Digital Audio (S/PDIF) (2- High Definition Audio Device)
18:39:20 T:6400 NOTICE: m_deviceType : AE_DEVTYPE_IEC958
18:39:20 T:6400 NOTICE: m_channels : FL,FR
18:39:20 T:6400 NOTICE: m_sampleRates : 44100
18:39:20 T:6400 NOTICE: m_dataFormats : AE_FMT_FLOAT,AE_FMT_AC3,AE_FMT_DTS
18:39:20 T:6400 NOTICE: Device 2
18:39:20 T:6400 NOTICE: m_deviceName : {C14ED8D2-F936-4B60-8757-70BDE4C1A4B6}
18:39:20 T:6400 NOTICE: Device 3
18:39:20 T:6400 NOTICE: m_deviceName : {C9A6BEAD-7A07-4E03-B165-9DB77246D48E}
18:39:20 T:6400 NOTICE: m_displayName : SPDIF - Digital Audio (S/PDIF) (2- Sound Blaster X-Fi Xtreme Audio)
18:39:20 T:6400 NOTICE: m_displayNameExtra: DIRECTSOUND: Digital Audio (S/PDIF) (2- Sound Blaster X-Fi Xtreme Audio)
18:39:20 T:6400 NOTICE: m_sampleRates : 48000
18:39:20 T:6400 NOTICE: Device 4
18:39:20 T:6400 NOTICE: m_deviceName : default
18:39:20 T:6400 NOTICE: m_displayName : default
18:39:20 T:6400 NOTICE: Enumerated WASAPI devices:
18:39:20 T:6400 NOTICE: m_displayNameExtra: WASAPI: Digital Audio (S/PDIF) (2- High Definition Audio Device)
18:39:20 T:6400 NOTICE: m_sampleRates : 192000,96000,88200,48000,44100,32000
18:39:20 T:6400 NOTICE: m_dataFormats : AE_FMT_DTS,AE_FMT_AC3,AE_FMT_S24NE4MSB,AE_FMT_S16NE,AE_FMT_S16LE,AE_FMT_S16BE
18:39:20 T:6400 NOTICE: m_displayNameExtra: WASAPI: Digital Audio (S/PDIF) (2- Sound Blaster X-Fi Xtreme Audio)
18:39:20 T:6400 NOTICE: m_sampleRates : 96000,48000,44100
