Full Version: Help ! :)... BBC iPlayer and also ITV iPlayer /PIA (Private Internet Access)
Im using 14.2 Kodi on a Pi (newest) and also a VPN, and Ive got a UK IP Address....
On itv im getting a Sorry Can not play in your region.....
But ive VERIFIED under connections that I DO INDEED have a UK England IP... Ive got Two choices of UK Southampton or also London ive tried both... I Used to be able to connect (using a different sdmicro card).....
Im using PIA for my VPN....
thanks in advance....
p.s.. $20 to whoever can help me get it REWORKING....Wink
As I said works on my OLD SDMicro Card (but that card is slow (a 4) and not a 10 speed card...(class) thanks again
I had the same issue. I talked with support and they gave my ip 77.92.76.250
Use that instead of your uk-london.privateinternetaccess.com or uk-southampton.privateinternetaccess.com
Works great!
(note i connect using openvpn on my router im not sure how you specify an IP using any of the apps etc)
