2016-04-16, 13:17
Pages: 1 2
2016-04-16, 13:18
But is a good option, thanks
2016-07-29, 07:37
Hi Tgx,
Firstly great skin. I have setup some widgets but when I try to access them through the menu by pressing the up button, nothing appears. They will only start to appear after 45sec or so and that is only 2-3 of them and within 5-10sec later, all come up.
Is there something that can be done to have them appear instantly as soon as you press the up button?
By the way, it only seems to happen when you enter Kodi for the first time, ie. after a restart or power on (android device). Once they appear, the widgets are visible at all times. I can live with this....
George
George
2016-08-05, 01:50
I love this skin. I have been using Aeon MQ6 which looks good, but some of the menus are so busy that I have been looking for something simpler, but still with a very cool look. You have succeeded wonderfully.
One item that I would respectfully request: For the Quit menu (something that I use quite a lot by depressing the S key, which opens the Quit menu), it would be GREAT if we could add our own menu items. For example, to get to Favourites from anywhere in Kodi, I would like to be able to add Favourites (or any other standard Kodi menu item, for that matter).
Of course I have no idea just how difficult this would be to achieve. But if it's not too tricky, I for one would really appreciate this feature.
In any case, Tgx, keep up the fantastic work!
2016-08-06, 10:42
(2016-07-29, 07:37)yioryos467 Wrote: [ -> ]Hi Tgx,
This is normal. Kodi needs time to collect data at startup for the smartplaylists used for widgets.
I'm not aware of any method which could speed up the process.
Tgx
2016-08-06, 10:43
(2016-08-05, 01:50)DenmanGuy Wrote: [ -> ]One item that I would respectfully request: For the Quit menu (something that I use quite a lot by depressing the S key, which opens the Quit menu), it would be GREAT if we could add our own menu items. For example, to get to Favourites from anywhere in Kodi, I would like to be able to add Favourites (or any other standard Kodi menu item, for that matter).
Yes, i'll add this option for the next release.
Tgx
2016-08-18, 20:07
Is there a way to make the startup page stay a certain time in the actual code and not just in the settings?
2016-09-10, 14:43
You need to analyze the "Startup.xml" file and look for the line
<onload>AlarmClock(StartupDelay,SetFocus(12),$VAR[StartupDelay],silent)</onload>
Tgx
Tgx
2016-09-10, 20:34
Thank you very much.
2017-02-03, 13:56
Chroma 2.10.0 is out!
Tgx
Tgx
Pages: 1 2
