Full Version: Nebula 4.x for Kodi 16.x Jarvis
Pages: 1 2 3 4
Thanks for the fixes.
I found another one.
I have readded "Last added Episodes" and "Last added Movies" to the HomeScreen.
Last added Movies looks like before but Episodes looks like this: https://imgur.com/NOYMQDE
In the old Version it has show the Series Cover for the Episodes.
(2016-03-02, 21:00)semool Wrote: [ -> ]Last added Movies looks like before but Episodes looks like this: https://imgur.com/NOYMQDE
Which addon are you using?
With the latest episodes from Kodi Library everything is ok.
Tgx
Hmmm i dont have any other addon installed for this.
Just use this:
Select Widget 1 -> Default Widgets -> Recent episodes.
Tgx
Yes thats it. I not using the widget from the default Section.
With the latest GIT Versions of the Skin its horrible slowed down.
When i first enter the Movies or Series Category i see 4-6 seconds only the Background Wallpaper and then he render all the Thumbs.
Going Back to Home Screen and enter Movie/series again it goes faster.
Same thing when i enter the Addon Browser or the Settings.
In the log i see alot of python errors from skin.helper.service
I have totaly reset my Firetv an reinstalled Kodi 16 and only the Skin. Same thing.
When i switch to Confluence Skin all is fast again without any wait times.
I turned on Debug Log.
When i first open the Programs Window:
16:23:24 T:18446744072505684184 DEBUG: Activating window ID: 10001
16:23:24 T:18446744072505684184 DEBUG: ------ Window Deinit (Home.xml) ------
16:23:24 T:18446744072505684184 DEBUG: CAndroidAppDirectory::GetDirectory: apps
16:23:24 T:18446744072505684184 DEBUG: ------ Window Init (MyPrograms.xml) ------
16:23:24 T:18446744072505684184 INFO: Loading skin file: MyPrograms.xml, load type: KEEP_IN_MEMORY <---- At this line the Log stops for ~4 seconds and the GUI shows only Background
16:23:31 T:18446744072505684184 DEBUG: CAndroidAppDirectory::GetDirectory: apps
16:23:31 T:18446744072505684184 DEBUG: CGUIMediaWindow::GetDirectory (addons://sources/executable/)
16:23:31 T:18446744072505684184 DEBUG: ParentPath = [addons://sources/executable/]
Second open a little bit later without lag:
16:24:00 T:18446744072505684184 DEBUG: Activating window ID: 10001
16:24:01 T:18446744072505684184 DEBUG: ------ Window Deinit (Home.xml) ------
16:24:01 T:18446744072505684184 DEBUG: ------ Window Init (MyPrograms.xml) ------
16:24:01 T:18446744072505684184 DEBUG: CGUIMediaWindow::GetDirectory (addons://sources/executable)
16:24:01 T:18446744072505684184 DEBUG: ParentPath = [addons://sources/executable/]
After some time when i open again the first message with KEEP_IN_MEMORY comes back with lag.
Same behavior at all other Windows.
The MYSQL and NFS queries are fast, i think this is not the Problem:
int CVideoDatabase::RunQuery(const string&) took 71 ms for 338 items query: select * from movie_view
virtual bool CImageLoader:Big GrinoWork() - took 129 ms to load special://masterprofile/Thumbnails/3/3b85fa5b.jpg
Probably something is going wrong with the skin.helper.service. Where are those errors?
This are errors directly after Kodi start but i think they only have effects on Music?
I have deletet all data in skin.helper.service userdata dir so he must recreate them, but the errors are still the same.
17:57:53 T:18446744072519747368  NOTICE: Skin Helper Service --> Kodi_Monitor: onDatabaseUpdated: video
17:57:53 T:18446744072519747368  NOTICE: Skin Helper Service --> Video database changed - type: unknown - resetAll: True, refreshing widgets....
17:57:53 T:18446744072544449160   ERROR: Skin Helper Service --> MusicBrainz ERROR (servers busy?) - temporary disabling musicbrainz lookups (fallback to theaudiodb)
17:57:53 T:18446744072544449160   ERROR: Traceback (most recent call last):
17:57:53 T:18446744072544449160   ERROR:   File "/storage/emulated/0/Android/data/org.xbmc.kodi/files/.kodi/addons/script.skin.helper.service/resources/lib/ArtworkUtils.py", line 689, in getMusicBrainzId
17:57:53 T:18446744072544449160   ERROR:     MBalbums = m.search_release_groups(query=single_urlencode(try_encode(album)),limit=1,offset=None, strict=False, artist=single_urlencode(try_encode(artist)))
17:57:53 T:18446744072544449160   ERROR:   File "/storage/emulated/0/Android/data/org.xbmc.kodi/files/.kodi/addons/script.skin.helper.service/resources/lib/musicbrainzngs/musicbrainz.py", line 954, in search_release_groups
17:57:53 T:18446744072544449160   ERROR:     return _do_mb_search('release-group', query, fields, limit, offset, strict)
17:57:53 T:18446744072544449160   ERROR:   File "/storage/emulated/0/Android/data/org.xbmc.kodi/files/.kodi/addons/script.skin.helper.service/resources/lib/musicbrainzngs/musicbrainz.py", line 718, in _do_mb_search
17:57:53 T:18446744072544449160   ERROR:     clean_query = util._unicode(query)
17:57:53 T:18446744072544449160   ERROR:   File "/storage/emulated/0/Android/data/org.xbmc.kodi/files/.kodi/addons/script.skin.helper.service/resources/lib/musicbrainzngs/util.py", line 25, in _unicode
17:57:53 T:18446744072544449160   ERROR:     unicode_string = string.decode(encoding, "ignore")
17:57:53 T:18446744072544449160   ERROR: TypeError: decode() argument 1 must be string, not None
17:58:55 T:18446744072544449160   ERROR: Skin Helper Service --> ERROR in getArtworkFromCacheFile special://profile/addon_data/script.skin.helper.service/musicart/Der kleine Nils.xml  --> no element found: line 1, column 0
17:58:55 T:18446744072544449160   ERROR: Traceback (most recent call last):
17:58:55 T:18446744072544449160   ERROR:   File "/storage/emulated/0/Android/data/org.xbmc.kodi/files/.kodi/addons/script.skin.helper.service/resources/lib/ArtworkUtils.py", line 501, in getArtworkFromCacheFile
17:58:55 T:18446744072544449160   ERROR:     root = xmltree.fromstring(f.read())
17:58:55 T:18446744072544449160   ERROR:   File "/home/jenkins/workspace/Android-ARM/tools/depends/xbmc-depends/arm-linux-androideabi-android-17/lib/python2.6/xml/etree/ElementTree.py", line 964, in XML
17:58:55 T:18446744072544449160   ERROR:   File "/home/jenkins/workspace/Android-ARM/tools/depends/xbmc-depends/arm-linux-androideabi-android-17/lib/python2.6/xml/etree/ElementTree.py", line 1254, in close
17:58:55 T:18446744072544449160   ERROR: ExpatError: no element found: line 1, column 0
17:59:19 T:18446744072544449160   ERROR: Skin Helper Service --> ERROR in createNFO --> cannot serialize [u'ba0d6274-db14-4ef5-b28d-657ebde1a396'] (type list)
17:59:19 T:18446744072544449160   ERROR: Traceback (most recent call last):
17:59:19 T:18446744072544449160   ERROR:   File "/storage/emulated/0/Android/data/org.xbmc.kodi/files/.kodi/addons/script.skin.helper.service/resources/lib/ArtworkUtils.py", line 489, in createNFO
17:59:19 T:18446744072544449160   ERROR:     xmlstring = xmltree.tostring(tree.getroot(), encoding="utf-8")
17:59:19 T:18446744072544449160   ERROR:   File "/home/jenkins/workspace/Android-ARM/tools/depends/xbmc-depends/arm-linux-androideabi-android-17/lib/python2.6/xml/etree/ElementTree.py", line 1009, in tostring
17:59:19 T:18446744072544449160   ERROR:   File "/home/jenkins/workspace/Android-ARM/tools/depends/xbmc-depends/arm-linux-androideabi-android-17/lib/python2.6/xml/etree/ElementTree.py", line 663, in write
17:59:19 T:18446744072544449160   ERROR:   File "/home/jenkins/workspace/Android-ARM/tools/depends/xbmc-depends/arm-linux-androideabi-android-17/lib/python2.6/xml/etree/ElementTree.py", line 707, in _write
17:59:19 T:18446744072544449160   ERROR:   File "/home/jenkins/workspace/Android-ARM/tools/depends/xbmc-depends/arm-linux-androideabi-android-17/lib/python2.6/xml/etree/ElementTree.py", line 705, in _write
17:59:19 T:18446744072544449160   ERROR:   File "/home/jenkins/workspace/Android-ARM/tools/depends/xbmc-depends/arm-linux-androideabi-android-17/lib/python2.6/xml/etree/ElementTree.py", line 813, in _escape_cdata
17:59:19 T:18446744072544449160   ERROR:   File "/home/jenkins/workspace/Android-ARM/tools/depends/xbmc-depends/arm-linux-androideabi-android-17/lib/python2.6/xml/etree/ElementTree.py", line 777, in _raise_serialization_error
17:59:19 T:18446744072544449160   ERROR: TypeError: cannot serialize [u'ba0d6274-db14-4ef5-b28d-657ebde1a396'] (type list)
18:00:18 T:18446744072544449160   ERROR: Skin Helper Service --> ERROR in getArtworkFromCacheFile special://profile/addon_data/script.skin.helper.service/musicart/Ed Sheeran.xml  --> no element found: line 1, column 0
18:00:18 T:18446744072544449160   ERROR: Traceback (most recent call last):
18:00:18 T:18446744072544449160   ERROR:   File "/storage/emulated/0/Android/data/org.xbmc.kodi/files/.kodi/addons/script.skin.helper.service/resources/lib/ArtworkUtils.py", line 501, in getArtworkFromCacheFile
18:00:18 T:18446744072544449160   ERROR:     root = xmltree.fromstring(f.read())
18:00:18 T:18446744072544449160   ERROR:   File "/home/jenkins/workspace/Android-ARM/tools/depends/xbmc-depends/arm-linux-androideabi-android-17/lib/python2.6/xml/etree/ElementTree.py", line 964, in XML
18:00:18 T:18446744072544449160   ERROR:   File "/home/jenkins/workspace/Android-ARM/tools/depends/xbmc-depends/arm-linux-androideabi-android-17/lib/python2.6/xml/etree/ElementTree.py", line 1254, in close
18:00:18 T:18446744072544449160   ERROR: ExpatError: no element found: line 1, column 0
I have tested your Chroma Skin.
All working good and fast.
Anything in the actual Nebula Git version is wrong.
Should be fixed now.
I had to remove the custom times options for auto theme. Too much performance hit.
Tgx
Yes thats it. All is working fast again Big Grin
Thanks for the fast fix.
Can you add a skin setting for selecting Studio Icons white/colored?
It gives an coulored Version of the Logos which shows a way better than the white one: https://github.com/XBMC-Addons/resource....s.coloured
(2016-03-09, 14:32)semool Wrote: [ -> ]Can you add a skin setting for selecting Studio Icons white/colored?
It's already in my to-do list.
Tgx
Wonderful LaughCool
Hello everyone, I switched to this skin after the misadventures of Xperience with the latest updates and the bootloop on sadface. Installed last night and I must say it is very beautiful. I was wondering if there's a way to see in the home instead of the full factory of TV series and films an image of a film or a TV show that I have. Sorry for the bad English translated with Google translate
Sent from my bacon
Pages: 1 2 3 4
