is there a way to make the size of thumbnails bigger card view ?
2x or 4x the size
or can you please add more view types thank you
Any plans for this to be released for (compatible with) Kodi 17?
helloo after last update of skin shortcuts i cannot change any sub menue using nebula
i cannot edit or add
this has ruiend my build
please update fix or go back to v11 and leave it at that
(2016-11-28, 20:32)londonshore Wrote: [ -> ]helloo after last update of skin shortcuts i cannot change any sub menue using nebula
Fix is
awaiting approval to be updated on the repo.
was able to fix the skin lastnight by installing the marcelveldt's beta repository "titanian skin"
his repo was able to fix Nebula skin im sure he fixed the skin shortcuts glitch for kodi 16.1
will still wait on the update
thanks
Hi Tgx,
Is there anyway, we can have the loading KODI Symbol like the Chroma skin has? With Nebula, you only see it saying loading but not sure where anything is happening. With the Chroma skin the Kodi symbol rotates so you know its doing something.....
George
Nebula 4.10.0 is out!
Tgx
In the actual Version the new two Line Topbar overlays the Extended Video Info.
(2017-02-04, 13:42)semool Wrote: [ -> ]In the actual Version the new two Line Topbar overlays the Extended Video Info.
Can you please make a screenshot?
Tgx
Sure
This is an unwanted bug. Cannot fix it for Jarvis.
Krypton instead has a new system for Video extended info and this issue does not appear.
Tgx
Is it not possible to change the display order? That when the extended info will switch on it cover the bar?
