13:59:00 T:11856 NOTICE: special://profile/ is mapped to: special://masterprofile/
13:59:00 T:11856 NOTICE: -----------------------------------------------------------------------
13:59:00 T:11856 NOTICE: Starting Kodi (16.0 Git:20160220-a5f3a99). Platform: Windows NT x86 32-bit
13:59:00 T:11856 NOTICE: Using Release Kodi x32 build
13:59:00 T:11856 NOTICE: Kodi compiled Feb 20 2016 by MSVC 180030723 for Windows NT x86 32-bit version 6.0 (0x06000000)
13:59:00 T:11856 NOTICE: Running on Hewlett-Packard HP Compaq dx2400 Microtower with Windows 7, kernel: Windows NT x86 64-bit version 6.1
13:59:00 T:11856 NOTICE: Host CPU: Intel(R) Core(TM)2 Duo CPU E7400 @ 2.80GHz, 2 cores available
13:59:00 T:11856 NOTICE: Desktop Resolution: 1920x1080 32Bit at 60Hz
13:59:00 T:11856 NOTICE: Running with restricted rights
13:59:00 T:11856 NOTICE: Aero is enabled
13:59:00 T:11856 NOTICE: special://xbmc/ is mapped to: C:\Program Files (x86)\Kodi
13:59:00 T:11856 NOTICE: special://xbmcbin/ is mapped to: C:\Program Files (x86)\Kodi
13:59:00 T:11856 NOTICE: special://masterprofile/ is mapped to: C:\Users\Wheelzi\AppData\Roaming\Kodi\userdata
13:59:00 T:11856 NOTICE: special://home/ is mapped to: C:\Users\Wheelzi\AppData\Roaming\Kodi\
13:59:00 T:11856 NOTICE: special://temp/ is mapped to: C:\Users\Wheelzi\AppData\Roaming\Kodi\cache
13:59:00 T:11856 NOTICE: The executable running is: C:\Program Files (x86)\Kodi\Kodi.exe
13:59:00 T:11856 NOTICE: Local hostname: DESKTOP-T02M5NT
13:59:00 T:11856 NOTICE: Log File is located: C:\Users\Wheelzi\AppData\Roaming\Kodi\kodi.log
13:59:00 T:11856 NOTICE: load settings...
13:59:00 T:11856 WARNING: CSettingString: unknown options filler "timezonecountries" of "locale.timezonecountry"
13:59:00 T:11856 WARNING: CSettingString: unknown options filler "timezones" of "locale.timezone"
13:59:00 T:11856 NOTICE: No settings file to load (special://xbmc/system/advancedsettings.xml)
13:59:00 T:11856 NOTICE: No settings file to load (special://masterprofile/advancedsettings.xml)
13:59:00 T:11856 NOTICE: Default DVD Player: dvdplayer
13:59:00 T:11856 NOTICE: Default Video Player: dvdplayer
13:59:00 T:11856 NOTICE: Default Audio Player: paplayer
13:59:00 T:11856 NOTICE: Disabled debug logging due to GUI setting. Level 0.
13:59:00 T:11856 NOTICE: Log level changed to "LOG_LEVEL_NORMAL"
13:59:00 T:11856 NOTICE: CMediaSourceSettings: loading media sources from special://masterprofile/sources.xml
13:59:00 T:11856 NOTICE: Loading player core factory settings from special://xbmc/system/playercorefactory.xml.
13:59:00 T:11856 NOTICE: Loaded playercorefactory configuration
13:59:00 T:11856 NOTICE: Loading player core factory settings from special://masterprofile/playercorefactory.xml.
13:59:00 T:11856 NOTICE: special://masterprofile/playercorefactory.xml does not exist. Skipping.
13:59:00 T:11720 NOTICE: CAESinkWASAPI::EnumerateDevicesEx: data format "AE_FMT_DTSHD" on device "1 - SAMSUNG (AMD High Definition Audio Device)" seems to be not supported.
13:59:00 T:11720 NOTICE: CAESinkWASAPI::EnumerateDevicesEx: data format "AE_FMT_TRUEHD" on device "1 - SAMSUNG (AMD High Definition Audio Device)" seems to be not supported.
13:59:00 T:11720 NOTICE: CAESinkWASAPI::EnumerateDevicesEx: data format "AE_FMT_EAC3" on device "1 - SAMSUNG (AMD High Definition Audio Device)" seems to be not supported.
13:59:00 T:11720 NOTICE: CAESinkWASAPI::EnumerateDevicesEx: data format "AE_FMT_DTS" on device "1 - SAMSUNG (AMD High Definition Audio Device)" seems to be not supported.
13:59:00 T:11720 NOTICE: CAESinkWASAPI::EnumerateDevicesEx: data format "AE_FMT_AC3" on device "1 - SAMSUNG (AMD High Definition Audio Device)" seems to be not supported.
13:59:00 T:11720 NOTICE: CAESinkWASAPI::EnumerateDevicesEx: sample rate 192khz on device "1 - SAMSUNG (AMD High Definition Audio Device)" seems to be not supported.
13:59:00 T:11720 NOTICE: CAESinkWASAPI::EnumerateDevicesEx: data format "AE_FMT_LPCM" on device "1 - SAMSUNG (AMD High Definition Audio Device)" seems to be not supported.
13:59:00 T:11720 NOTICE: Found 2 Lists of Devices
13:59:00 T:11720 NOTICE: Enumerated DIRECTSOUND devices:
13:59:00 T:11720 NOTICE: Device 1
13:59:00 T:11720 NOTICE: m_deviceName : {0451C31B-6512-4483-907B-8DFDBC3C5840}
13:59:00 T:11720 NOTICE: m_displayName : HDMI - 1 - SAMSUNG (AMD High Definition Audio Device)
13:59:00 T:11720 NOTICE: m_displayNameExtra: DIRECTSOUND: 1 - SAMSUNG (AMD High Definition Audio Device)
13:59:00 T:11720 NOTICE: m_deviceType : AE_DEVTYPE_HDMI
13:59:00 T:11720 NOTICE: m_channels : FL,FR
13:59:00 T:11720 NOTICE: m_sampleRates : 48000
13:59:00 T:11720 NOTICE: m_dataFormats : AE_FMT_FLOAT,AE_FMT_AC3,AE_FMT_DTS
13:59:00 T:11720 NOTICE: Device 2
13:59:00 T:11720 NOTICE: m_deviceName : default
13:59:00 T:11720 NOTICE: m_displayName : default
13:59:00 T:11720 NOTICE: Device 3
13:59:00 T:11720 NOTICE: m_deviceName : {579260F5-BEF5-4B16-9E90-337512B62F3E}
13:59:00 T:11720 NOTICE: m_displayName : Speakers - Speakers (Realtek High Definition Audio)
13:59:00 T:11720 NOTICE: m_displayNameExtra: DIRECTSOUND: Speakers (Realtek High Definition Audio)
13:59:00 T:11720 NOTICE: m_deviceType : AE_DEVTYPE_PCM
13:59:00 T:11720 NOTICE: Enumerated WASAPI devices:
13:59:00 T:11720 NOTICE: m_displayNameExtra: WASAPI: 1 - SAMSUNG (AMD High Definition Audio Device)
13:59:00 T:11720 NOTICE: m_sampleRates : 192000,48000,44100,32000
13:59:00 T:11720 NOTICE: m_dataFormats : AE_FMT_DTSHD,AE_FMT_TRUEHD,AE_FMT_EAC3,AE_FMT_DTS,AE_FMT_AC3,AE_FMT_S24NE4MSB,AE_FMT_S16NE,AE_FMT_S16LE,AE_FMT_S16BE,AE_FMT_LPCM
13:59:00 T:11720 NOTICE: m_displayNameExtra: WASAPI: Speakers (Realtek High Definition Audio)
13:59:00 T:11720 NOTICE: m_sampleRates : 192000,96000,48000,44100
13:59:00 T:11720 NOTICE: m_dataFormats : AE_FMT_S24NE4MSB,AE_FMT_S16NE,AE_FMT_S16LE,AE_FMT_S16BE
13:59:05 T:11856 NOTICE: ADDONS: Using repository repository.exodus
13:59:05 T:11856 NOTICE: ADDONS: Using repository repository.tknorris.beta
13:59:05 T:11856 NOTICE: ADDONS: Using repository repository.podgod
13:59:05 T:11856 NOTICE: ADDONS: Using repository repository.xbmchub
13:59:05 T:11856 NOTICE: ADDONS: Using repository repository.mdrepo
13:59:05 T:11856 NOTICE: ADDONS: Using repository repository.xbmc.org
13:59:05 T:11856 NOTICE: ADDONS: Using repository repository.metalkettle
13:59:05 T:11856 NOTICE: ADDONS: Using repository repository.OperationRobocop
13:59:05 T:11856 NOTICE: Found screen: Generic PnP Monitor on AMD Radeon R7 200 Series, adapter 0.
13:59:05 T:11856 NOTICE: Primary mode: 1920x1080@ 60.00 - Full Screen
13:59:05 T:11856 NOTICE: Additional mode: 640x480@ 75.00 - Full Screen
13:59:05 T:11856 NOTICE: Additional mode: 640x480@ 72.00 - Full Screen
13:59:05 T:11856 NOTICE: Additional mode: 640x480@ 67.00 - Full Screen
13:59:05 T:11856 NOTICE: Additional mode: 640x480@ 60.00 - Full Screen
13:59:05 T:11856 NOTICE: Additional mode: 640x480@ 59.94 - Full Screen
13:59:05 T:11856 NOTICE: Additional mode: 720x480@ 59.94 - Full Screen
13:59:05 T:11856 NOTICE: Additional mode: 720x480@ 60.00 - Full Screen
13:59:05 T:11856 NOTICE: Additional mode: 720x576@ 59.94 - Full Screen
13:59:05 T:11856 NOTICE: Additional mode: 720x576@ 60.00 - Full Screen
13:59:05 T:11856 NOTICE: Additional mode: 720x576@ 50.00 - Full Screen
13:59:05 T:11856 NOTICE: Additional mode: 800x600@ 75.00 - Full Screen
13:59:05 T:11856 NOTICE: Additional mode: 800x600@ 72.00 - Full Screen
13:59:05 T:11856 NOTICE: Additional mode: 800x600@ 60.00 - Full Screen
13:59:05 T:11856 NOTICE: Additional mode: 1024x768@ 75.00 - Full Screen
13:59:05 T:11856 NOTICE: Additional mode: 1024x768@ 70.00 - Full Screen
13:59:05 T:11856 NOTICE: Additional mode: 1024x768@ 60.00 - Full Screen
13:59:05 T:11856 NOTICE: Additional mode: 1152x648@ 59.94 - Full Screen
13:59:05 T:11856 NOTICE: Additional mode: 1152x648@ 60.00 - Full Screen
13:59:05 T:11856 NOTICE: Additional mode: 1152x648@ 50.00 - Full Screen
13:59:05 T:11856 NOTICE: Additional mode: 1152x864@ 75.00 - Full Screen
13:59:05 T:11856 NOTICE: Additional mode: 1152x864@ 59.94 - Full Screen
13:59:05 T:11856 NOTICE: Additional mode: 1152x864@ 60.00 - Full Screen
13:59:05 T:11856 NOTICE: Additional mode: 1280x720@ 59.94 - Full Screen
13:59:05 T:11856 NOTICE: Additional mode: 1280x720@ 60.00 - Full Screen
13:59:05 T:11856 NOTICE: Additional mode: 1280x720@ 50.00 - Full Screen
13:59:05 T:11856 NOTICE: Additional mode: 1280x768@ 60.00 - Full Screen
13:59:05 T:11856 NOTICE: Previous line repeats 2 times.
13:59:05 T:11856 NOTICE: Additional mode: 1280x800@ 60.00 - Full Screen
13:59:05 T:11856 NOTICE: Additional mode: 1280x960@ 60.00 - Full Screen
13:59:05 T:11856 NOTICE: Additional mode: 1280x1024@ 75.00 - Full Screen
13:59:05 T:11856 NOTICE: Additional mode: 1280x1024@ 60.00 - Full Screen
13:59:05 T:11856 NOTICE: Additional mode: 1360x768@ 60.00 - Full Screen
13:59:05 T:11856 NOTICE: Additional mode: 1366x768@ 75.00 - Full Screen
13:59:05 T:11856 NOTICE: Additional mode: 1366x768@ 60.00 - Full Screen
13:59:05 T:11856 NOTICE: Additional mode: 1440x900@ 75.00 - Full Screen
13:59:05 T:11856 NOTICE: Additional mode: 1440x900@ 60.00 - Full Screen
13:59:05 T:11856 NOTICE: Additional mode: 1600x900@ 60.00 - Full Screen
13:59:05 T:11856 NOTICE: Additional mode: 1600x1200@ 60.00 - Full Screen
13:59:05 T:11856 NOTICE: Additional mode: 1680x1050@ 60.00 - Full Screen
13:59:05 T:11856 NOTICE: Additional mode: 1776x1000@ 59.94 - Full Screen
13:59:05 T:11856 NOTICE: Additional mode: 1776x1000@ 60.00 - Full Screen
13:59:05 T:11856 NOTICE: Additional mode: 1776x1000@ 50.00 - Full Screen
13:59:05 T:11856 NOTICE: Additional mode: 1776x1000@ 29.97 - Full Screen
13:59:05 T:11856 NOTICE: Additional mode: 1776x1000@ 30.00 - Full Screen
13:59:05 T:11856 NOTICE: Additional mode: 1776x1000@ 29.97i - Full Screen
13:59:05 T:11856 NOTICE: Additional mode: 1776x1000@ 30.00i - Full Screen
13:59:05 T:11856 NOTICE: Additional mode: 1776x1000@ 25.00 - Full Screen
13:59:05 T:11856 NOTICE: Additional mode: 1776x1000@ 25.00i - Full Screen
13:59:05 T:11856 NOTICE: Additional mode: 1776x1000@ 24.00 - Full Screen
13:59:05 T:11856 NOTICE: Additional mode: 1920x1080@ 59.94 - Full Screen
13:59:05 T:11856 NOTICE: Additional mode: 1920x1080@ 60.00 - Full Screen
13:59:05 T:11856 NOTICE: Additional mode: 1920x1080@ 50.00 - Full Screen
13:59:05 T:11856 NOTICE: Additional mode: 1920x1080@ 29.97 - Full Screen
13:59:05 T:11856 NOTICE: Additional mode: 1920x1080@ 30.00 - Full Screen
13:59:05 T:11856 NOTICE: Additional mode: 1920x1080@ 29.97i - Full Screen
13:59:05 T:11856 NOTICE: Additional mode: 1920x1080@ 30.00i - Full Screen
13:59:05 T:11856 NOTICE: Additional mode: 1920x1080@ 25.00 - Full Screen
13:59:05 T:11856 NOTICE: Additional mode: 1920x1080@ 25.00i - Full Screen
13:59:05 T:11856 NOTICE: Additional mode: 1920x1080@ 23.98 - Full Screen
13:59:05 T:11856 NOTICE: Additional mode: 1920x1080@ 24.00 - Full Screen
13:59:05 T:11856 NOTICE: Checking resolution 16
13:59:06 T:11856 NOTICE: Running database version Addons20
13:59:06 T:11856 NOTICE: Running database version ViewModes6
13:59:06 T:11856 NOTICE: Running database version MyMusic56
13:59:06 T:11856 NOTICE: Running database version MyVideos99
13:59:06 T:11856 NOTICE: Running database version TV29
13:59:06 T:11856 NOTICE: Running database version Epg11
13:59:07 T:11856 WARNING: JSONRPC: Could not parse type "Setting.Details.SettingList"
13:59:07 T:11856 NOTICE: ActiveAE DSP - starting
13:59:07 T:11856 NOTICE: initialize done
13:59:07 T:11856 NOTICE: Running the application...
13:59:07 T:11856 NOTICE: starting upnp client
13:59:07 T:7596 NOTICE: ES: Starting UDP Event server on 0.0.0.0:9777
13:59:07 T:7596 NOTICE: UDP: Listening on port 9777
13:59:10 T:12432 NOTICE: script.grab.fanart: Grab Fanart Service Started
13:59:10 T:11508 NOTICE: Stream All The Sources: Service: Installed Version: 2.0.9
13:59:11 T:11508 NOTICE: Stream All The Sources: Service: starting...
13:59:11 T:11508 NOTICE: Stream All The Sources: Service: Resetting...
13:59:21 T:11856 NOTICE: Storing total System Uptime
13:59:21 T:11856 NOTICE: Saving settings
13:59:21 T:11856 NOTICE: stop all
13:59:21 T:11856 NOTICE: stop player
13:59:21 T:11856 NOTICE: ES: Stopping event server
13:59:21 T:11856 NOTICE: stopping upnp
13:59:22 T:7596 NOTICE: ES: UDP Event server stopped
13:59:22 T:11856 NOTICE: stop sap announcement listener
13:59:22 T:11856 NOTICE: clean cached files!
13:59:22 T:11856 NOTICE: unload skin
13:59:23 T:11508 NOTICE: Stream All The Sources: Service: shutting down...
13:59:24 T:11856 NOTICE: stopped
13:59:24 T:11856 NOTICE: destroy
13:59:24 T:11856 NOTICE: closing down remote control service
13:59:24 T:11856 NOTICE: unload sections
13:59:24 T:11856 NOTICE: special://profile/ is mapped to: special://masterprofile/
13:59:25 T:11856 NOTICE: destroy
13:59:25 T:11856 WARNING: Attempted to remove window 10013 from the window manager when it didn't exist
13:59:25 T:11856 WARNING: Attempted to remove window 10014 from the window manager when it didn't exist
13:59:25 T:11856 WARNING: Attempted to remove window 10015 from the window manager when it didn't exist
13:59:25 T:11856 WARNING: Attempted to remove window 10016 from the window manager when it didn't exist
13:59:25 T:11856 WARNING: Attempted to remove window 10017 from the window manager when it didn't exist
13:59:25 T:11856 WARNING: Attempted to remove window 10018 from the window manager when it didn't exist
13:59:25 T:11856 WARNING: Attempted to remove window 10019 from the window manager when it didn't exist
13:59:25 T:11856 WARNING: Attempted to remove window 10021 from the window manager when it didn't exist
13:59:25 T:11856 WARNING: Attempted to remove window 10107 from the window manager when it didn't exist
13:59:25 T:11856 WARNING: Attempted to remove window 10115 from the window manager when it didn't exist
13:59:25 T:11856 WARNING: Attempted to remove window 10104 from the window manager when it didn't exist
13:59:25 T:11856 NOTICE: closing down remote control service
13:59:25 T:11856 NOTICE: unload sections
13:59:25 T:11856 NOTICE: application stopped...
13:59:25 T:11856 ERROR: dllFreeLibrary - Invalid hModule specified
