2015-09-24, 20:31
this is a how to mod and add multiple IPTV Simple Clients on a mac os x system.
there my be a better way but i could not find one. maybe this will give someone who knows more than i do some inspration.
i found this thread http://forum.kodi.tv/showthread.php?tid=232576
however the files did not work on mac.
so after some digging i found a way.
step one:
go to your applications folder
control click the Kodi.app
select: Show Pagkage Contents
open: Contents/Resources/Kodi/addons
scroll down and copy the pvr.iptvsimple folder to your desktop (or other)
step two:
open the pvr.iptvsimple folder you copied to your desktop
open the add-on.xml file
change the top of the file to this
id="pvr.iptvsimple2"
version="1.11.5"
name="PVR IPTV Simple Client2"
provider-name="nightik">
save and close the file
step three:
change the name of the pvr.iptvsimple folder on your desktop to pvr.iptvsimple2
move this folder into the lodi user folder
users/user name/library/application support/kodi/addons
step four:
start kodi
go to system/addons/My add-ons/PVR clients/PVR IPTV Simple Client
control click, configure and enable.
relaunch kodi
go to system/addons/My add-ons/PVR clients/PVR IPTV Simple Client2
relaunch kodi
that should be it.
if you have problems let me know i will try my best to help.
good luck
step one:
step two:
version="1.11.5"
step three:
step four:
start kodi
relaunch kodi
relaunch kodi
that should be it.
good luck
