Please, please change the seek bar. It's way to big, it covers almost the whole screen so you miss parts of whatever video your watching.
Also, it shows up when you hit menu and covers half of the OSD.
And it shows up when you bring the Video info up as well.
It's very annoying..
Maybe move the seek bar all the way to the top of the screen and get rid of the "Seek bar" text and borders.. Or at the very least, make it see through.
Other then that, great work!
+stealth+ Wrote:Have noticed that went playing an mp3 from an album then returning to the main menu and entering the "My Videos" it skips onto the next track and likewise once selecting a video and accessing the Video_TS folder... and then exiting...
It also skips when it enters and exits the visulaisation mode when in "My Videos"
Have not experinced this on any of the earlier builds... can anyone else get theirs to do this.. SVN272.
I believe thats fixed in one of the latest XBMC SVN builds.. This happend to be a few days ago, but stopped now. (And I do daily builds..)
Hey, first I like your work. But for a great result we need to fix a few things.
I have the current xbmc and clearity svn!
Obviously you don't have the latest version of them both.
This was posted 6 posts up...
Smokehead Wrote:Please ppl, start reading next time before you make any obsolete posts about stuff that is already been fixed ..kthx ,and this was also answered by some others.. you need a newer XBMC build, cause this is not a skin issue but a XBMC (on xbox) issue.
also check this:
http://forum.xbmc.org/showthread.php?tid=24201
Thanks to jmarshall for fixing
/Tomas
XBMC-SVN_2007-01-09_rev7554-T3CH-PROPER
and Clearity rev. 272
empty Wrote:XBMC-SVN_2007-01-09_rev7554-T3CH-PROPER
Yup, thats the latest Clearity build, but XBMC is at SVN revision 7654
...tadaaa and todays date is what?
Read the post. lots of things have been altered since 2007/01/09.
/Tomas
I'm so sorry!. It's definitly my fault.
Can I get the svn's before the release on *****?
I need them compiled
empty Wrote:Can I get the svn's before the release on *****?
If you'r talking about a compiled XBMC build, you'll have to wait till T3CH releases a newer version, or you'll have to compile it yourself.
lol, and look there here it is
XBMC-SVN_2007-01-16_rev7667-T3CH
Smoke,
As always your skinning skills are beyond compare
just wanted to let you know, you still cannot focus the "OK" button when adding a network source via the dialog menus (file list>context menu>add source>browse>add network location) you can fill in the data for the server listing, but it will not allow you to ok out of it.
Also wanted to let you know that the seek bar overwrites the OSD menu for videos (I know you're redesigning that) but it covers over the dialogs that can be chosen from the OSD.. They have focus but you cant really see what your doing because the seek bar is in the foreground..
Thanks for providing us with beauty in our living rooms
Vashie
Vashie Wrote:Smoke, just wanted to let you know, you still cannot focus the "OK" button when adding a network source via the dialog menus (file list>context menu>add source>browse>add network location) you can fill in the data for the server listing, but it will not allow you to ok out of it.
This one should be fixed now ....
I also changed the viewmodes a bit, cause people didn't always find it obvious wich item had focus in list/panels so i diffused the nonfocus items a bit, hope this is better .. they stand out better now imo... The small 5 item wraplist now has info labels that show information depending in what media section you are.
Common View Types:
WrapList Info:
Is there a direct download link that does not need tortoise?
