Pages: 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18
Missing i think it cauled Media Flags ain't sure, like in first picture Post: #178, i like to see these information like movie quality sound info etc..., anyone an idea HOW?
(2016-10-27, 16:46)esperocd Wrote: [ -> ]Missing i think it cauled Media Flags ain't sure, like in first picture Post: #178, i like to see these information like movie quality sound info etc..., anyone an idea HOW?
Hi esperocd and welcome to the forums.
Media flags are enabled in the skin settings and most of them are enabled by default. Go to Skin Settings > Media > Media Flagging to enable / disable.
You should be aware that enabling all media flags could break the layout, as it would cause too many flags at the same time.
Maybe you haven't scraped your movies or tv shows into the library?
http://kodi.wiki/view/Sources
http://kodi.wiki/view/Set_content_and_scan
Hi Gade, Media Flags already enabled, change skinn to standard no solution
i only see sometimes only one flag like pg13, distributor and I have this problem with kodi 16.1 with Rapier 9.5.12 on windows 10 pc and Android Kodi box!
(2016-10-28, 14:13)esperocd Wrote: [ -> ]Hi Gade, Media Flags already enabled, change skinn to standard no solution
Your content needs to be stored locally or on your network. Follow the 2 links I posted above.
If you stream content, you will see no media flags.
ok, i understand now, i did NEVER read this before!!! Thanks man, i already try many ours to solve this!
It's pitty that it not work for stream media!
I have more questions about this skin, i will ask it in a new post
Just did a fresh install of LibreELEC 7.0.2 on my RPi2. Any idea why Rapier is now listed as "incompatible"?
UPDATE: Rapier 9.5.14 is available through the official Kodi repository!
This update is installed automatically.
If this is not the case, you can download it here.
The highlights are:
- The login screen has been updated and adjusted.
- Clicking the path label in the video / music information window will open up the text viewer dialog with the info (useful for long paths if you don't want to wait for the text scrolling).
- Skin Settings > Supported Add-ons has been changed into two sections:
Automatic installation from Kodi add-on repository: will feature all supported add-ons from the official repository. Clicking the add-ons will either prompt you to install them or open up the settings dialog.
Manual installation: will feature all supported add-ons not in the official repository. Manual installation from zip is required.
- Paused and Buffering labels has been added to the fullscreen music window with a skin setting to enable/disable. Screenshot below.
- A PVR guide / search window View Option has been added to show the channel icons instead of channel labels. Screenshot below.
- A context menu button has been added to activate player controls dialog when playing media (disabled by default in the skin settings).
Skin Settings > Configure Menus > Context Menu > Open player controls
- Noto Sans font has been added, which is a very nice looking, modern font.
FULL CHANGELOG
9.5.14 (19-October-16)
- Added Noto Sans font.
- Added context menu button to activate player controls dialog when playing media (disabled by default in the skin settings).
- Update of slideshow window.
- Added PVR guide / search window View Option to show channel icons instead of channel labels.
- Added new fallback image in Favourites dialog.
- Update of Skin Settings > Supported add-ons section with "Manual installation" section.
- Updated login screen.
- PVR radio improvements and updates.
- Clicking the path label in video / music information window, will open up text viewer dialog with the info.
- Home screen weather category will take you to weather settings if no weather add-on is installed.
- Added support for LibreELEC settings (home screen System category submenu).
- Fullscreen video window Paused label will now also show buffering.
- Added Paused / Buffering labels to fullscreen music window.
ENJOY!
hi i am trying your skin again , how do i add more categorys to the main menu and how many will the main menu allow, and allthough i have installed your lastest update 9.5.14 i keep getting a error from my picture database i have installed everything needed for this skin thanks for your advice
(2016-12-01, 19:41)flowerpot Wrote: [ -> ]hi i am trying your skin again , how do i add more categorys to the main menu and how many will the main menu allow
You can add up to 16 custom categories.
It's all described here:
http://kodi.wiki/view/Add-on:Rapier#Crea...m_category
(2016-12-01, 19:41)flowerpot Wrote: [ -> ]allthough i have installed your lastest update 9.5.14 i keep getting a error from my picture database i have installed everything needed for this skin thanks for your advice
I get an error in the home screen as well with plugin.image.mypicsdb if that's what you mean.
You'll have to ask about it in the add-on thread:
http://forum.kodi.tv/showthread.php?tid=133905
many thanks for your reply with the 16 custom categories how many submenu items can you have , also i have put on some movies from my hard drive after it finished i had what looks like widgets on the screen above movies can i switch them of or make them smaller thanks
(2016-12-01, 22:11)flowerpot Wrote: [ -> ]many thanks for your reply with the 16 custom categories how many submenu items can you have
I really think you should read the wiki, as it's all described there (and that's why I wrote it).
You can have up to 7 submenus for each category:
http://kodi.wiki/view/Add-on:Rapier#Addi...g_submenus
(2016-12-01, 22:11)flowerpot Wrote: [ -> ]i have put on some movies from my hard drive after it finished i had what looks like widgets on the screen above movies can i switch them of or make them smaller thanks
To disable widgets for regular categories, go to Skin Settings > Home > Info Widget.
There you'll find all widgets for the main categories, and you can disable or enable them to your needs.
The widgets for the main Movies category are "Recently Added" and "In Progress".
Be aware that disabling those widgets will disable "Recently Added" and "In Progress / Random" widgets for all main categories using those widgets.
For custom categories, look for Step 6 in the below link: that explains most about widgets for custom categories.
You can disable the widgets as well if you like.
Hey Gade. I had to take a 7 month break from my Kodi setup and forums. Was shocked to finally log back on here and see Rob and all of his add-ons were banned. What?!? His add-ons were so useful. Still have no clue what happened there.
Is Video Extras still available from an outside repository or did you have to pull support for it altogether? (I won't have my HTPC up and running for a few more weeks and can't check it myself.) I did find a GitHub page for it, but I'm not sure if that means it is still supported or not.
The new version of Rapier is looking really nice. Can't wait to try it out soon.
