Full Version: Simple folders rather than playlists
Hi All,
I have been using smart playlists for some time and although it is a great feature it can become difficult to view all the content from that folder in one playlist. For example, I have a playlist called Hindi movies then filter for all foreign and country India. It doesn't show all content, instead if the movie was made in London it will only appear in the English move playlist. Is there an easier way to make this work seamlessly or perhaps i can simply create my own folder structure and copy the movies i want and the skin to just point to that folder? Please help.Thanks
Anybody?
You can drop all your Hindi movies in 1 folder and then either use a smart playlist that points at that folder or use video nodes (assuming the skin supports them, I imagine it does).
Hi Troggy, it seems i did not know i could use the smart playlist feature to a specified path. All working now,. Many thanks.
