Hello everybody
it's possible use more than only one m3u list on live tv? I have 4 m3u chennel list and I would like to use all of them.
Thank I've done. But how can I switch from list1 to list2?
i am very new to iptv and simple client, so i make no claims that my advice is good.
if you install two instances of simple client the list placed in each are merged into the first client.
unfortunately they are blended together not one followed by the other. as far as i know.
you can go into system/live tv/channel manager and group manager to create groups for list 1 and list 2. then in simple client switch groups.
hope this helps.
fyi: i am happy to have helped, however a quick search would give you this info.
many here are also happy to help but searching first is greatly encouraged.
you will find that answers and help comes faster if your thread title is direct and clear and if the question shows that you have searched prior to posting.
i had to learn this the long hard way, hope this helps you get the most out of this amazing forum and kodi.
good luck
