Full Version: Error loading studio resource images from textures
For some reason my studio images will not load (latest windows jarvis nightly) and I can see the following in the log
13:47:38 T:520   ERROR: CImageLoader::DoWork - Direct texture file loading failed for resource://resource.images.studios.coloured/
Any ideas on what's going wrong here.
is that the exact error in your log?
if so, it looks like you didn't specify the studio filename...
I have this too.
I noticed if I loaded an older skin first [arctic zephyr: exploded] which installed all the repos itself then it worked with subsequent skins ok.
If I installed them manually, then it fails with exact same error above. And I could never get them to work even by installing older skin. [And note both skins use exact same call code to get image].
I had to manually remove all traces of kodi, and completely start from scratch making sure I only installed older skin to install the repos.
Strangely enough that worked, so when the resource image pack is installed as a requirement by the skin there is no errors but if you install the resource pack manually I then get the errors reported above. Very strange...
i can't reproduce... i've created a fresh kodi profile and manually unzipped the coloured studio logos resource addon.
it works right out of the box.
could you provide a full Debug Log of the issue?
Yes sure, I'll get one posted later on today.
I reproduced it in the following log with debug enabled: http://pastebin.com/hBCZRRnw
Having a look I couldn't spot anything of significance
(2015-09-27, 17:50)im85288 Wrote: [ -> ]I reproduced it in the following log with debug enabled: http://pastebin.com/hBCZRRnw
i see the error only once in your Debug Log and that one is most likely because the '..' item was focused in the movielist.
there are no errors anymore when you start browsing through your movielist.
so, there error seems unrelated to the issue you're having i guess.
just to rule out it's a skin issue, is the skin you're using available for download somewhere?
well, that was embarassing /runhides
Just to clarify for anyone reading the problem was in the skin and not the resource images. Thanks Ronie for finding the issue.
I'm getting this same error on Jarvis 16.1 and my skin is Transparency. Kodi becomes unresponsive for a few seconds and Windows wants to shut it down, but if I wait it usually becomes responsive again. Do I need a skin fix? This is in my log:
01:36:25 T:4604 ERROR: CImageLoader:Big GrinoWork - Direct texture file loading failed for resource://resource.images.studios.white/Cristaldifilm.png
01:36:30 T:4176 ERROR: CImageLoader:Big GrinoWork - Direct texture file loading failed for resource://resource.images.studios.white/Annapurna Pictures.png
01:36:30 T:4604 ERROR: CImageLoader:Big GrinoWork - Direct texture file loading failed for resource://resource.images.studios.white/Chernin Entertainment.png
01:36:31 T:4604 ERROR: CImageLoader:Big GrinoWork - Direct texture file loading failed for resource://resource.images.studios.white/Annapurna Pictures.png
01:36:39 T:4604 ERROR: CImageLoader:Big GrinoWork - Direct texture file loading failed for resource://resource.images.studios.white/Pure Flix Productions.png
01:36:48 T:4844 ERROR: CImageLoader:Big GrinoWork - Direct texture file loading failed for resource://resource.images.studios.white/Flight 33 Productions.png
01:36:49 T:4176 ERROR: CImageLoader:Big GrinoWork - Direct texture file loading failed for resource://resource.images.studios.white/Headmon Entertainment & Productions.png
01:36:50 T:4844 ERROR: CImageLoader:Big GrinoWork - Direct texture file loading failed for resource://resource.images.studios.white/CNN Films.png
01:36:51 T:4176 ERROR: CImageLoader:Big GrinoWork - Direct texture file loading failed for resource://resource.images.studios.white/Universal Pictures UK.png
01:36:52 T:4856 ERROR: CImageLoader:Big GrinoWork - Direct texture file loading failed for resource://resource.images.studios.white/Partizan Films.png
01:36:52 T:4844 ERROR: CImageLoader:Big GrinoWork - Direct texture file loading failed for resource://resource.images.studios.white/evolvee..png
01:36:52 T:4856 ERROR: CImageLoader:Big GrinoWork - Direct texture file loading failed for resource://resource.images.studios.white/Cross Creek Pictures.png
01:36:52 T:4856 ERROR: CImageLoader:Big GrinoWork - Direct texture file loading failed for resource://resource.images.studios.white/Pt. Merantau Films.png
01:36:52 T:4176 ERROR: CImageLoader:Big GrinoWork - Direct texture file loading failed for resource://resource.images.studios.white/British Film Institute (BFI) / Pinewood Studios / British Film Company.png
01:36:52 T:4604 ERROR: CImageLoader:Big GrinoWork - Direct texture file loading failed for resource://resource.images.studios.white/Annapurna Pictures.png
01:36:53 T:4856 ERROR: CImageLoader:Big GrinoWork - Direct texture file loading failed for resource://resource.images.studios.white/Harpo Films / Cloud Eight Films / Celador Films.png
01:37:53 T:4900 ERROR: XFILE::CDirectory::GetDirectory - Error getting resource://resource.images.weathericons.animated/
01:39:40 T:5012 ERROR: Previous line repeats 1 times.
I didn't want to start a new thread so I figured I would just ask my question here if that's ok.
I keep seeing these errors in my log file and I am just curious as to why, especially the resource images. The texture file does indeed exists. The other erros I just can't seem to narrow down either.
Do I need to post a full log?
Small snippet of log:
2019-04-27 14:21:26.377 T:139783930111744 WARNING: Repository add-on repository.lunatixz uses plain HTTP for add-on downloads in path http://raw.github.com/Lunatixz/KODI_Addons/master/zips - this is insecure and will make your Kodi installation vulnerable to attacks if enabled!
2019-04-27 14:21:28.200 T:139782931871488   ERROR: NEWADDON Unknown Video Info Key "progress"
2019-04-27 14:21:29.358 T:139785312757504   ERROR: Previous line repeats 29 times.
2019-04-27 14:21:29.358 T:139785312757504   ERROR: CTextureBundleXBT: failed to decompress frame with 172142 unpacked bytes to 1048576 bytes
2019-04-27 14:21:29.358 T:139785312757504   ERROR: DoWork - Direct texture file loading failed for resource://resource.images.weathericons.hd.animated/11/11_05.png
2019-04-27 14:21:32.813 T:139782423066368 WARNING: Repository add-on repository.lunatixz uses plain HTTP for add-on downloads in path http://raw.github.com/Lunatixz/KODI_Addons/master/zips - this is insecure and will make your Kodi installation vulnerable to attacks if enabled!
2019-04-27 14:21:54.424 T:139782266656512 WARNING: Previous line repeats 4 times.
2019-04-27 14:21:54.425 T:139782266656512   ERROR: NEWADDON Unknown Video Info Key "progress"
2019-04-27 14:21:56.371 T:139784198547200   ERROR: Previous line repeats 5 times.
2019-04-27 14:21:56.371 T:139784198547200   ERROR: DoWork - Direct texture file loading failed for resource://resource.images.studios.coloured/
2019-04-27 14:21:59.188 T:139782249871104   ERROR: NEWADDON Unknown Video Info Key "progress"
2019-04-27 14:21:59.314 T:139783024125696   ERROR: Previous line repeats 29 times.
2019-04-27 14:21:59.314 T:139783024125696   ERROR: DoWork - Direct texture file loading failed for resource://resource.images.studios.coloured/
2019-04-27 14:22:02.964 T:139782216300288   ERROR: NEWADDON Unknown Video Info Key "progress"
2019-04-27 14:22:04.806 T:139785657968768   ERROR: Previous line repeats 29 times.
2019-04-27 14:22:04.806 T:139785657968768 WARNING: Skin has invalid include: InvisibleButton
2019-04-27 14:22:04.822 T:139785657968768 WARNING: Skin has invalid include: Animation_ViewsCDart
2019-04-27 14:22:05.384 T:139784198547200 WARNING: Previous line repeats 1 times.
2019-04-27 14:22:05.384 T:139784198547200   ERROR: DoWork - Direct texture file loading failed for resource://resource.images.extras.color/8bit.png
2019-04-27 14:22:05.392 T:139785312757504   ERROR: DoWork - Direct texture file loading failed for resource://resource.images.extras.color/sdr.png
2019-04-27 14:22:06.084 T:139785312757504   ERROR: DoWork - Direct texture file loading failed for resource://resource.images.studios.coloured/30WEST.png
2019-04-27 14:22:06.846 T:139785657968768 WARNING: Repository add-on repository.lunatixz uses plain HTTP for add-on downloads in path http://raw.github.com/Lunatixz/KODI_Addons/master/zips - this is insecure and will make your Kodi installation vulnerable to attacks if enabled!
2019-04-27 14:22:22.465 T:139785657968768 WARNING: CGUIWindowManager - HandleAction - ignoring action 92, because topmost modal dialog closing animation is running
2019-04-27 14:22:23.596 T:139784198547200 WARNING: Previous line repeats 2 times.
2019-04-27 14:22:23.596 T:139784198547200   ERROR: DoWork - Direct texture file loading failed for resource://resource.images.studios.coloured/Deja Vu.png
2019-04-27 14:22:23.599 T:139784198547200   ERROR: DoWork - Direct texture file loading failed for resource://resource.images.recordlabels.white/
2019-04-27 14:22:25.708 T:139784198547200   ERROR: DoWork - Direct texture file loading failed for resource://resource.images.studios.coloured/
2019-04-27 14:22:25.709 T:139784198547200   ERROR: DoWork - Direct texture file loading failed for resource://resource.images.resolution.color/
2019-04-27 14:22:25.709 T:139784198547200   ERROR: DoWork - Direct texture file loading failed for resource://resource.images.aspectratio.color/
2019-04-27 14:22:25.710 T:139784198547200   ERROR: DoWork - Direct texture file loading failed for resource://resource.images.audiocodec.color/
2019-04-27 14:22:27.252 T:139785657968768 WARNING: Skin has invalid include: Animation_ViewsCDart
2019-04-27 14:22:27.350 T:139784198547200 WARNING: Previous line repeats 1 times.
2019-04-27 14:22:27.350 T:139784198547200   ERROR: DoWork - Direct texture file loading failed for resource://resource.images.studios.coloured/
2019-04-27 14:22:27.367 T:139781893682944   ERROR: NEWADDON Unknown Video Info Key "progress"
Thanks,
Shedrock
