Full Version: Which file to download for the latest Kodi install?
I have an Xtreamer Ultra HTPC (http://www.xtreamer.net/ultra/) which had OpenElec Frodo installed but I wanted to install the latest version of Kodi so I downloaded this file (http://archive.openelec.tv/OpenELEC-Gene...5.95.2.tar) and copied the SYSTEM & KERNEL files to the Update folder via the network from my Windows notebook and when the system restarted, I saw the splash screen OK, however I've got the error "failed to start xorg. Is your GPU supported?"
So I was wondering, which file do I download in order to get the latest Kodi installation? Would I assume that there is already an OS loaded on the internal HDD?
The internal HDD has Ubuntu, Windows7 and Boxee preloaded.
Here are the hardware specs:
Product Name :
Xtreamer Ultra
Memory :
Samsung 4GB DDR3 (SO-DIMM/204pin/DDR3-1333/PC3-10600) Included
Hard Disk : Supports 1 x 2.5-inch SATA 3.0 Gb/s HDD/SSD up to 12 mm
CPU :
Intel® Atom® D525 (dual-core, 1.8 GHz)
GPU :
NVIDIA® GT218-ION Graphics, NVIDIA® 3DTV Play Capable
Chipset IO :
NM10, NCT5577D
Video Memory :
512MB DDR3
Display Options :
HDMI1.4a (w/audio), DVI-I, VGA (with included adapter)
SATA :
eSATA 3.0 Gb/s port
Gigabit LAN Ethernet :
10/100/1000Mbps (RTL8111E)
WiFi :
External USB Antenna 802.11n WiFi (Optional)
USB Ports :
6 USB 2.0 (4 on back panel, 2 on front panel)
Audio :
Onboard analog stereo high-definition audio (ALC892), 7.1-Chan
nel LPCM digital audio (HDMI), Optical Digital S/PDIF audio out
put
Form factor :
mini-ITX
Mini-PCI Express slot :
SATA Mini2 PCIe
IR port :
IRDA 1.0
DirectX® Support :
DirectX® 10.1 with Shader Model 4.1
Other Features :
OpenCL compliant, OpenGL® 3.2 compatible, NVIDIA®, PhysX® ready, NVIDIA® CUDA™ ready, NVIDIA® PureVideo™ HD technology
HDCP :
Ye s
Software Features :
nView® Multi-Display, Aiwi (for Win7), nVidia 3DTV Play trial (for Win7), Camtrax Windows Controller App
HTPC Capability :
Windows® 7 with Aero® user interface and DirectCompute compatible, Boxee, XBMC, MediaPortal Compatible, Linux Pre-Compiled, Optimized and Configured for the
Ultra is inside the USB Stick ready for booting
Optional Accessories :
USB WIFI 802.11n, USB BluRay Combo, USB LifeCam, USB HDD Docking Station, USB TV Tuner
Size :
5.35 cm(W) x 21.3 cm(H) x 14.2 cm(D)
Power :
DC IN 19V
You need a build with legacy nvidia support.
Does that mean I'm stuck with Frodo?
No, just with a legacy driver for your nvidia GPU as it isn't supported in newer drivers. There's a download for isengrad on the opwnelec website.
