Full Version: TV kodi
My Kodi TV is not playing some channels since i did the upgrade from 14.2 to 15.2 rc2. I have created channel list.m3u with my favorite channels which i "call" it remotely(web) from PVR iptv stream
Now some of the channels are not playing some works, when i tried the non working channels with external player ( XMTV Player - ANDROID) they work properly, which means the stream links are ok.
No idea how to fix it!
ANY SOLUTION Huh
Regards,
Diego Antoneli
debug log (wiki)
Hello Negge.
Sorry for the late reply, here is my the kodi log
http://pastebin.com/tz5w3yJ0
The problem i have is that the same m3u url doesnt work in 2 different pc's. The logs i am sending you is from non-working pc.
Hope you can help me with the problem.
Regards
You need to enable debug logging.
I have a "smart tv box" and it only has two Portuguese channels and I would like to know how to get more channels for my smart tv and if u can send me any codes/links for the smart tv box and to update it, thank you.
@paulino matos you can't ask for stuff like that on these forums. And please don't hijack other peoples threads either.
