So i am a cord cutter for about 1 year now. I have Netflix, Hulu & Sling TV combo. I supplement with Kodi as well. Sling TV has been really crappy as of late. anytime fear the walking dead or a big game is on, sling crashes or just cuts out.
Does anyone have any recommendations as to a reliable IPTV that i can pay for and set up on Kodi?
I have no suggestion for a reliable IPTV provider, and instead suggest you get a physical tv-tuner USB-adapter (or network-attached tuner like HDHomeRun) for recieving basic-cable package or over-the-air television signals with a good antenna for best receptions and channel selection in your area, then setup a minimum PVR backend server using just a Raspberry Pi, see
http://kodi.wiki/view/PVR and
http://kodi.wiki/view/PVR_backend . The PVR backend server software you install on that backend will also be capable of recieving IPTV as well if you want it to, recommend to use Tvheadend or VDR.
If you're in the States, Qwest has slowly been rolling out their Prism IPTV service in some areas too.
