There is a new official raspbian distro with Debian Jessie (2015-09-24):
https://www.raspberrypi.org/downloads/raspbian/ but the kodi package is missing, the kodi package was included in the previous version Wheezy.
root@rpi:/etc/apt# apt-get install kodi
Reading package lists... Done
Building dependency tree
Reading state information... Done
E: Unable to locate package kodi
According to Kodi Wiki:
Raspbian - Up-to-date versions of Kodi are now on the default Raspbian repositories
Is it pending ? Should I ask in raspbian forum instead ?
Hmm
I just bought the new touchscreen to run kodi as a music player, cuz I can't get Pi-Jukebox to work.
Tho I need latest version Jessie to use the touch part.
Then use
OSMC instead: it's based on Debian Jessie and is running Kodi 15.2 atm.
If you search their
Forum, you will see that work on that touchscreen has already started.
We have some preliminary touchscreen support in OSMC's September update. Some more improvements will follow in the October update
Cheers
Sam
(2015-10-05, 19:45)Fry7 Wrote: [ -> ]Then use OSMC instead: it's based on Debian Jessie and is running Kodi 15.2 atm.
If you search their Forum, you will see that work on that touchscreen has already started.
I tried the last OSMC release and It's quite close to what I need, however I found a bit annoying issue, I want the rpi2 to startup in console mode, no X-Windows, so I disabled the mediacente.service but then the osmc shows a splash screen forever :-(
How can I configure it to run in console mode and launch the mediacenter on demand ?
Thanks in advance.
UPDATE: I changed the runlevel with the command:
ln -s /lib/systemd/system/multi-user.target /etc/systemd/system/default.target
But the splash screen still appears, however I can access to the console changing the tty: ALT_KEY+F2, F3, F4, ...
So, the current status is Ok for me but I'm curious about how to remove the OSMC splash and boot directly in tty1 with the prompt for login.
(2015-10-12, 20:04)Sam.Nazarko Wrote: [ -> ]Then sudo systemctl enable getty@tty1. If you want no splash screen, even on boot, remove 'quiet' from /boot/cmdline.txt
It worked like a charm
Thank you.
BTW, It was not necessary to change the runlevel, so I deleted the file /etc/systemd/system/default.target that I created previously
The Wiki still says that the jessie repository does not contain kodi.
I just installed kodi using "sudo apt-get install kodi".
But there are two issues.
1. It is "only" 15.1
2. It seems there are no PVR-addons in the repository. Why?
I want to use the Vu+-addon.
Yes, I know there are special distributions like OpenELEC and OSMC.
