If I replace moviex.mkv at 960 x 720 with a file with the exact same name at 1920 x 1080, is there a process to update MyVideos93.streamdetails table for that file?
I think if you just play the file it will update the stream details with the new information.
or reload/refresh info from the movie info screen.
I guess my question is really, is there a way to rebuild streamdetails? I've updated a bunch of movies and wouldn't be sure which ones aren't correct.
An update should look after this, but basically as kyle84 mentioned, first play will update the res.
