Hello all,
I have a problem with my tv box, I am trying to install xbmc/kodi. I have tried many versions ,the new kodi app from GooglePlay, also your SPMC with no luck at all. I even tried contacting some of the youtube channels.
My box is hisilicon arabic iptv box.
Specs as follows:
Model unknown full AOSP Godbox
Android version 4.0.3
busybox v1.16.1 multi call binary
Build number ARD-1.1.92013-11-10. 113543
Kernal version 3.0.8hisilicon root@ubuntu#34
Chipset CPU Model Arm v7 processor rev0 (v71)
Thank you very much in advance and greatly appreciate your help.
for starters droid 4.0. android 4.2+ is required.
(2015-10-01, 08:49)Ned Scott Wrote: [ -> ]What is the problem?
Hello Ned , I am trying to install xbmc/kodi , keeps showing an error screen. Thanks
(2015-10-01, 09:16)ironic_monkey Wrote: [ -> ]for starters droid 4.0. android 4.2+ is required.
Hello, it is android 4.0.3
(2015-10-01, 18:37)abdulkareem74 Wrote: [ -> ] (2015-10-01, 09:16)ironic_monkey Wrote: [ -> ]for starters droid 4.0. android 4.2+ is required.
You need to update the box to at least Android 4.2. Your OS is too old.
(2015-10-01, 18:52)Dangelus Wrote: [ -> ] (2015-10-01, 18:37)abdulkareem74 Wrote: [ -> ] (2015-10-01, 09:16)ironic_monkey Wrote: [ -> ]for starters droid 4.0. android 4.2+ is required.
Hello, thanks . Do have any idea where I might find the upgrade for this box. Very much appreciated.
(2015-10-01, 18:55)abdulkareem74 Wrote: [ -> ] (2015-10-01, 18:52)Dangelus Wrote: [ -> ] (2015-10-01, 18:37)abdulkareem74 Wrote: [ -> ]Hello, it is android 4.0.3
Sorry, no idea. It might not even be possible. Start by asking where you got the box, they might know.
(2015-10-01, 19:02)Dangelus Wrote: [ -> ] (2015-10-01, 18:55)abdulkareem74 Wrote: [ -> ] (2015-10-01, 18:52)Dangelus Wrote: [ -> ]You need to update the box to at least Android 4.2. Your OS is too old.
Thank you Dangelus . Ironic-monkey also mentioned about the upgrade , thank you both. That actually explains the problem. As for not knowing where to get the upgrade , I also thank you. Greatly appreciated ,thanks for your help and everyone else. Wish you all the best.
