I'm interested in using a 8bitdo controller with Openelec. But as I don't own one I don't really want to buy one until someone confirms they work with Openelec
Seems other distros needed a udev rule created. I guess you could try adding the correct rule to /storage/.config/udev.rules.d
As I said above I have no idea if this will work for you, so try at your own risk. It you do get it working can you let us know.
# Add the ID_INPUT_JOYSTICK attribute to the device so software picks up on it
# 8Bitdo FC30 1P GamePad Bluetooth mode(START) mode(START+R)
SUBSYSTEM=="input", ATTRS{name}=="8Bitdo FC30 GamePad", MODE="0666", ENV{ID_INPUT_JOYSTICK}="1"
# 8Bitdo FC30 2P GamePad Bluetooth mode(START)
SUBSYSTEM=="input", ATTRS{name}=="8Bitdo FC30 II", MODE="0666", ENV{ID_INPUT_JOYSTICK}="1"
# 8Bitdo FC30 2P GamePad Bluetooth mode(START+R)
SUBSYSTEM=="input", ATTRS{name}=="8Bitdo FC30 II Joystick", MODE="0666", ENV{ID_INPUT_JOYSTICK}="1"
# 8Bitdo SFC30 GamePad Bluetooth mode(START)
SUBSYSTEM=="input", ATTRS{name}=="8Bitdo SFC30 GamePad", MODE="0666", ENV{ID_INPUT_JOYSTICK}="1"
# 8Bitdo SFC30 GamePad Bluetooth mode(START+R)
SUBSYSTEM=="input", ATTRS{name}=="8Bitdo SFC30 GamePad Joystick", MODE="0666", ENV{ID_INPUT_JOYSTICK}="1"
# 8Bitdo NES30 GamePad Bluetooth mode(START)
SUBSYSTEM=="input", ATTRS{name}=="8Bitdo NES30 GamePad", MODE="0666", ENV{ID_INPUT_JOYSTICK}="1"
# 8Bitdo NES30 GamePad Bluetooth mode(START+R)
SUBSYSTEM=="input", ATTRS{name}=="8Bitdo NES30 GamePad Joystick", MODE="0666", ENV{ID_INPUT_JOYSTICK}="1"
# 8Bitdo SNES30 GamePad Bluetooth mode(START)
SUBSYSTEM=="input", ATTRS{name}=="8Bitdo SNES30 GamePad", MODE="0666", ENV{ID_INPUT_JOYSTICK}="1"
# 8Bitdo SNES30 GamePad Bluetooth mode(START+R)
SUBSYSTEM=="input", ATTRS{name}=="8Bitdo SNES30 GamePad Joystick", MODE="0666", ENV{ID_INPUT_JOYSTICK}="1"
# 8Bitdo FC30 Pro GamePad Bluetooth mode(POWER) mode(POWER+R1)
SUBSYSTEM=="input", ATTRS{name}=="8Bitdo FC30 Pro", MODE="0666", ENV{ID_INPUT_JOYSTICK}="1"
# 8Bitdo NES30 Pro GamePad Bluetooth mode(POWER)
SUBSYSTEM=="input", ATTRS{name}=="8Bitdo NES30 Pro", MODE="0666", ENV{ID_INPUT_JOYSTICK}="1"
# 8Bitdo NES30 Pro GamePad Bluetooth mode(POWER+R1)
SUBSYSTEM=="input", ATTRS{name}=="8Bitdo NES30 Pro Joystick", MODE="0666", ENV{ID_INPUT_JOYSTICK}="1"
# 8Bitdo FC30 Arcade Joystick Bluetooth mode(HOME)
SUBSYSTEM=="input", ATTRS{name}=="8Bitdo Joy", MODE="0666", ENV{ID_INPUT_JOYSTICK}="1"
# 8Bitdo Zero GamePad Bluetooth mode(START) mode(START+R)
SUBSYSTEM=="input", ATTRS{name}=="8Bitdo Zero GamePad", MODE="0666", ENV{ID_INPUT_JOYSTICK}="1"
