Full Version: MHEG Decoding
Does anyone know whether VDR supports MHEG decoding for XBMC? If not what is the suitable tool for this for XBMC?
Thank you in advance!
/T
I don't think Kodi support this, but on the other hand vdr support this with vdr-redbutton plugin
I think you better make future request @ https://github.com/FernetMenta
Thanks decaturguy
"MHEG"? Is that a video container/stream or?
Anyway, Kodi uses FFmpeg both to demux video containers/streams and decode the encoded video/audio content.
Alternativly you could ask the VDR backend/server developers to add a transcoder/demuxer on their server-side.
(2015-11-04, 11:54)RockerC Wrote: [ -> ]Anyway, Kodi uses FFmpeg both to demux video containers/streams and decode the encoded video/audio content.
This is not fully correct. vnsi has its own demuxer for live tv.
(2015-11-04, 12:05)FernetMenta Wrote: [ -> ]
Isn't that what I wrote above as an alterative solution: Alternativly you could ask the VDR backend/server developers to add a transcoder/demuxer on their server-side.
You said that kodi uses ffmeg demuxer but this is not the case for vnsi.
