2007-01-06, 19:06
Hi All,
Recently "SleepyP" kicked off an initiative to determine which Python Scripts worked or didn't work. With the assistance of others, the *cleanup* made a significant difference.
I've been looking over the skins found at:
Xbox-Skins.NET
AllXboxSkins.com
Many of these are not working in all resolutions or are no longer compatible with the new version of XBMC.
Is there any value in soliciting some of the other Skin Developers out there to post their skin projects into the SourceForge project (XBMC Skinning Project)? There are some logistics/standards that would most likely need to be applied such as:
- No new projects that is a 'minor' variation on an existing skin project (ex: background, button, etc.)
- Should work at all resolutions
- Should not contain art that is copyrighted so as to avoid problems
- etc.
Thoughts/Comments?
Cheers,
KZ
Xbox-Skins.NET
AllXboxSkins.com
- etc.
Thoughts/Comments?
Cheers,
KZ
