OK, this add-on now has a bug in kodi. In xbmc, I had a hot key setup to run the script and it would work fine. Now, in kodi, I need to have the mouse pointer visible on the screen while pressing my hot key. Just pressing "I" for on screen info doesn't do it, the cursor needs to be there.
Any thoughts?
(2015-10-02, 14:17)music_lover Wrote: [ -> ]OK, this add-on now has a bug in kodi. In xbmc, I had a hot key setup to run the script and it would work fine. Now, in kodi, I need to have the mouse pointer visible on the screen while pressing my hot key. Just pressing "I" for on screen info doesn't do it, the cursor needs to be there.
Any thoughts?
For developers our there, I don't think this behavior would be specific to this add-on. It's gotta be something in the move from Gotham to lesengard.
