Full Version: ts.-Files not played since V14.0
Pages: 1 2
Hi everybody,
Couldnt find anything for this problem:
Some Video Files (ts.) that are played in V 13.2 Gotham aren't played since Version 14.0 (even not up to V15.1).
mpg2-Files are played as well as vob-Files, so in generally Kodi works. This is on Win7 as well as on a QNAP HS 251, so I don't think it is a Problem of Hardware or OS.
What has changed between 13.2. und 14.0 Huh What can I do to play them with a newer Version of Kodi?
This is a sample file, but its not the only one:
Allgemein
Vollständiger Name : D:\temp\Kodi Backup\Test\El Cid (1961)\El Cid (1961).ts
Format : MPEG-TS
Format-Profil : No PAT/PMT
Dateigröße : 12,9 GiB
Dauer : 2h 51min
Gesamte Bitrate : 10,8 Mbps
Video
Format : AVC
Format/Info : Advanced Video Codec
Format-Profil : High@L4
Format-Einstellungen für CABAC : Ja
Format-Einstellungen für ReFrames : 4 frames
Dauer : 2h 51min
Bitrate : 9 405 Kbps
Breite : 1 280 Pixel
Höhe : 720 Pixel
Bildseitenverhältnis : 16:9
Bildwiederholungsrate : 50,000 FPS
ColorSpace : YUV
ChromaSubsampling : 4:2:0
BitDepth/String : 8 bits
Scantyp : progressiv
Bits/(Pixel*Frame) : 0.204
Stream-Größe : 11,3 GiB (87%)
Audio #1
Format : MPEG Audio
Format-Version : Version 1
Format-Profil : Layer 2
Dauer : 2h 51min
Bitraten-Modus : konstant
Bitrate : 192 Kbps
Kanäle : 2 Kanäle
Samplingrate : 48,0 KHz
Video Verzögerung : -1s 136ms
Stream-Größe : 236 MiB (2%)
Audio #2
Format : MPEG Audio
Dauer : 2h 51min
Bitrate : 192 Kbps
Kanäle : 2 Kanäle
Audio #3
Format : AC-3
Format/Info : Audio Coding 3
Format_Settings_ModeExtension : CM (complete main)
Format-Einstellungen für Endianess : Big
Dauer : 2h 51min
Bitrate : 448 Kbps
Kanäle : 6 Kanäle
Kanal-Positionen : Front: L C R, Side: L R, LFE
Video Verzögerung : -1s 98ms
Stream-Größe : 550 MiB (4%)
Thx for any advice
Chris
I don't have any of these types of files, so I can't check. But according to the format support in the wiki http://kodi.wiki/view/Supported_File_For...at_support, it isn't supported. You may have to remux to MKV or similar.
I play .ts all the time in v14.x through 15.x mainly from pvr recorded live tv. You may want to post a debug log.
the thing is: xbmc 13.2 does play these files, kodi 14 (and newer) does not. I bought a qnap nas especially as a media center, but if I update it to a newer version (and is it recommendet to update) , I won't be able to play my files any longer ... :-(
I will try to post a debug log. is there anything to pay attention to create a log?
Rehi,
can this help?
20:40:09 T:3268 NOTICE: CDVDVideoCodecFFmpeg::Open() Using codec: H.264 / AVC / MPEG-4 AVC / MPEG-4 part 10
20:40:15 T:1996 NOTICE: DVDPlayer: Opening: D:\temp\Kodi Backup\Test\El Cid (1961)\El Cid (1961).ts
20:40:15 T:1996 WARNING: CDVDMessageQueue(player):Tongueut MSGQ_NOT_INITIALIZED
20:40:15 T:6344 NOTICE: Thread DVDPlayer start, auto delete: false
20:40:15 T:6344 NOTICE: Creating InputStream
20:40:15 T:6344 NOTICE: Creating Demuxer
20:40:15 T:6344 ERROR: CSelectionStreams::Get - failed to get stream
20:40:15 T:6344 WARNING: CDVDMessageQueue(audio):Tongueut MSGQ_NOT_INITIALIZED
20:40:15 T:6344 WARNING: CDVDMessageQueue(video):Tongueut MSGQ_NOT_INITIALIZED
20:40:15 T:8828 NOTICE: Thread BackgroundLoader start, auto delete: false
20:40:40 T:1996 NOTICE: CDVDPlayer::CloseFile()
http://kodi.wiki/view/Debug_log
Can you play them on any other player, like VLC, Wmp, etc?
No, XBMC 13.2. is the only player, which plays these files. they were exported by a technisat digicorder pvr.
Now I switched on debugging and here is the complete result:
10:11:21 T:5164 NOTICE: special://profile/ is mapped to: special://masterprofile/
10:11:21 T:5164 NOTICE: -----------------------------------------------------------------------
10:11:21 T:5164 NOTICE: Starting Kodi (15.1 Git:20150816-f4dda26). Platform: Windows NT x86 32-bit
10:11:21 T:5164 NOTICE: Using Release Kodi x32 build
10:11:21 T:5164 NOTICE: Kodi compiled Aug 16 2015 by MSVC 180030723 for Windows NT x86 32-bit version 6.0 (0x06000000)
10:11:21 T:5164 NOTICE: Running on Acer Aspire 5742G with Windows 7 SP1, kernel: Windows NT x86 64-bit version 6.1
10:11:21 T:5164 NOTICE: Host CPU: Intel® Core™ i5 CPU M 480 @ 2.67GHz, 4 cores available
10:11:21 T:5164 NOTICE: Desktop Resolution: 1366x768 32Bit at 60Hz
10:11:21 T:5164 NOTICE: Running with restricted rights
10:11:21 T:5164 NOTICE: Aero is disabled
10:11:21 T:5164 NOTICE: special://xbmc/ is mapped to: C:\Program Files (x86)\Kodi
10:11:21 T:5164 NOTICE: special://xbmcbin/ is mapped to: C:\Program Files (x86)\Kodi
10:11:21 T:5164 NOTICE: special://masterprofile/ is mapped to: C:\Users\xxxxx\AppData\Roaming\Kodi\userdata
10:11:21 T:5164 NOTICE: special://home/ is mapped to: C:\Users\xxxxx\AppData\Roaming\Kodi\
10:11:21 T:5164 NOTICE: special://temp/ is mapped to: C:\Users\xxxxxx\AppData\Roaming\Kodi\cache
10:11:21 T:5164 NOTICE: The executable running is: C:\Program Files (x86)\Kodi\Kodi.exe
10:11:21 T:5164 NOTICE: Local hostname: xxxxx
10:11:21 T:5164 NOTICE: Log File is located: C:\Users\xxxxx\AppData\Roaming\Kodi\kodi.log
10:11:21 T:5164 NOTICE: load settings...
10:11:21 T:5164 WARNING: CSettingString: unknown options filler "timezonecountries" of "locale.timezonecountry"
10:11:21 T:5164 WARNING: CSettingString: unknown options filler "timezones" of "locale.timezone"
10:11:21 T:5164 NOTICE: No settings file to load (special://xbmc/system/advancedsettings.xml)
10:11:21 T:5164 NOTICE: No settings file to load (special://masterprofile/advancedsettings.xml)
10:11:21 T:5164 NOTICE: Default DVD Player: dvdplayer
10:11:21 T:5164 NOTICE: Default Video Player: dvdplayer
10:11:21 T:5164 NOTICE: Default Audio Player: paplayer
10:11:21 T:5164 NOTICE: Disabled debug logging due to GUI setting. Level 0.
10:11:21 T:5164 NOTICE: Log level changed to "LOG_LEVEL_NORMAL"
10:11:21 T:5164 NOTICE: CMediaSourceSettings: loading media sources from special://masterprofile/sources.xml
10:11:21 T:5164 NOTICE: Loading player core factory settings from special://xbmc/system/playercorefactory.xml.
10:11:21 T:5164 NOTICE: Loaded playercorefactory configuration
10:11:21 T:5164 NOTICE: Loading player core factory settings from special://masterprofile/playercorefactory.xml.
10:11:21 T:5164 NOTICE: special://masterprofile/playercorefactory.xml does not exist. Skipping.
10:11:21 T:296 NOTICE: Thread ActiveAE start, auto delete: false
10:11:21 T:168 NOTICE: Thread AESink start, auto delete: false
10:11:21 T:296 NOTICE: Found 2 Lists of Devices
10:11:21 T:296 NOTICE: Enumerated DIRECTSOUND devices:
10:11:21 T:296 NOTICE: Device 1
10:11:21 T:296 NOTICE: m_deviceName : {C94E7857-4BBF-429A-B9D6-CFACD97EE521}
10:11:21 T:296 NOTICE: m_displayName : Speakers - Lautsprecher (Realtek High Definition Audio)
10:11:21 T:296 NOTICE: m_displayNameExtra: DIRECTSOUND: Lautsprecher (Realtek High Definition Audio)
10:11:21 T:296 NOTICE: m_deviceType : AE_DEVTYPE_PCM
10:11:21 T:296 NOTICE: m_channels : FL,FR
10:11:21 T:296 NOTICE: m_sampleRates : 48000
10:11:21 T:296 NOTICE: m_dataFormats : AE_FMT_FLOAT
10:11:21 T:296 NOTICE: Device 2
10:11:21 T:296 NOTICE: m_deviceName : default
10:11:21 T:296 NOTICE: m_displayName : default
10:11:21 T:296 NOTICE: Enumerated WASAPI devices:
10:11:21 T:296 NOTICE: m_displayNameExtra: WASAPI: Lautsprecher (Realtek High Definition Audio)
10:11:21 T:296 NOTICE: m_sampleRates : 192000,96000,48000,44100
10:11:21 T:296 NOTICE: m_dataFormats : AE_FMT_S24NE4MSB,AE_FMT_S16NE,AE_FMT_S16LE,AE_FMT_S16BE
10:11:21 T:5164 NOTICE: Running database version Addons19
10:11:24 T:5164 NOTICE: ADDONS: Using repository repository.xbmc.org
10:11:24 T:5768 NOTICE: Thread PeripBusCEC start, auto delete: false
10:11:24 T:5964 NOTICE: Thread PeripBusUSB start, auto delete: false
10:11:24 T:5960 NOTICE: Thread RemoteControl start, auto delete: false
10:11:24 T:5164 NOTICE: Found screen: PnP-Monitor (Standard) on Intel® HD Graphics, adapter 0.
10:11:24 T:5164 NOTICE: Primary mode: 1366x768@ 60.00 - Full Screen
10:11:24 T:5164 NOTICE: Additional mode: 320x200@ 60.00 - Full Screen
10:11:24 T:5164 NOTICE: Previous line repeats 2 times.
10:11:24 T:5164 NOTICE: Additional mode: 320x240@ 60.00 - Full Screen
10:11:24 T:5164 NOTICE: Additional mode: 400x300@ 60.00 - Full Screen
10:11:24 T:5164 NOTICE: Additional mode: 512x384@ 60.00 - Full Screen
10:11:24 T:5164 NOTICE: Additional mode: 640x400@ 60.00 - Full Screen
10:11:24 T:5164 NOTICE: Additional mode: 640x480@ 60.00 - Full Screen
10:11:24 T:5164 NOTICE: Additional mode: 800x600@ 60.00 - Full Screen
10:11:24 T:5164 NOTICE: Additional mode: 1024x768@ 60.00 - Full Screen
10:11:24 T:5164 NOTICE: Additional mode: 1280x600@ 60.00 - Full Screen
10:11:24 T:5164 NOTICE: Additional mode: 1280x720@ 60.00 - Full Screen
10:11:24 T:5164 NOTICE: Additional mode: 1280x768@ 60.00 - Full Screen
10:11:24 T:5164 NOTICE: Additional mode: 1360x768@ 60.00 - Full Screen
10:11:24 T:5164 NOTICE: Additional mode: 1366x768@ 60.00 - Full Screen
10:11:24 T:5164 NOTICE: Checking resolution 16
10:11:26 T:5164 NOTICE: Running database version Addons19
10:11:26 T:5164 NOTICE: Running database version ViewModes6
10:11:26 T:5164 NOTICE: Running database version Textures13
10:11:26 T:5164 NOTICE: Running database version MyMusic52
10:11:26 T:5164 NOTICE: Running database version MyVideos93
10:11:26 T:5164 NOTICE: Running database version TV29
10:11:26 T:5164 NOTICE: Running database version Epg10
10:11:28 T:5164 WARNING: JSONRPC: Could not parse type "PVR.Details.Channel"
10:11:28 T:5164 WARNING: JSONRPC: Could not parse type "PVR.Details.ChannelGroup.Extended"
10:11:28 T:5164 WARNING: JSONRPC: Could not parse type "GUI.Property.Value"
10:11:28 T:5164 WARNING: JSONRPC: Could not parse type "Setting.Details.SettingList"
10:11:28 T:5948 NOTICE: Thread LanguageInvoker start, auto delete: false
10:11:28 T:5164 NOTICE: Previous line repeats 4 times.
10:11:28 T:5164 NOTICE: initialize done
10:11:28 T:6052 NOTICE: Thread LanguageInvoker start, auto delete: false
10:11:28 T:5164 NOTICE: Running the application...
10:11:28 T:5992 NOTICE: Thread JobWorker start, auto delete: true
10:11:29 T:5164 NOTICE: starting upnp client
10:11:29 T:5988 NOTICE: Thread JobWorker start, auto delete: true
10:11:29 T:5164 NOTICE: ES: Starting event server
10:11:29 T:6124 NOTICE: Thread EventServer start, auto delete: false
10:11:29 T:5880 NOTICE: Thread TCPServer start, auto delete: false
10:11:29 T:6124 NOTICE: ES: Starting UDP Event server on 0.0.0.0:9777
10:11:29 T:6124 NOTICE: UDP: Listening on port 9777
10:11:29 T:5948 NOTICE: -->Python Interpreter Initialized<--
10:11:29 T:6148 NOTICE: Thread RSSReader start, auto delete: false
10:11:29 T:3632 NOTICE: -->Python Interpreter Initialized<--
10:11:31 T:3636 NOTICE: Previous line repeats 4 times.
10:11:31 T:3636 NOTICE: script.tv.show.next.aired: ### TV Show - Next Aired starting background proc (6.0.14)
10:11:31 T:3636 NOTICE: script.tv.show.next.aired: ### no prior data found
10:11:31 T:3596 NOTICE: script.grab.fanart: Grab Fanart Service Started
10:11:31 T:3628 NOTICE: StorageServer Module loaded RUN
10:11:31 T:3628 NOTICE: StorageClient-2.5.4 Starting server
10:11:33 T:3636 NOTICE: script.tv.show.next.aired: ### starting data update
10:12:49 T:5068 NOTICE: Thread JobWorker start, auto delete: true
10:13:29 T:5164 ERROR: XFILE::CDirectory::GetDirectory - Error getting C:\Users\xxxxx\AppData\Roaming\Kodi\media\Fonts\
10:13:29 T:5164 ERROR: XFILE::CDirectory::GetDirectory - Error getting special://home/media/Fonts/
10:13:45 T:5952 NOTICE: Thread JobWorker start, auto delete: true
10:14:35 T:5164 NOTICE: Previous line repeats 1 times.
10:14:35 T:5164 ERROR: XFILE::CDirectory::GetDirectory - Error getting C:\Users\xxxxx\AppData\Roaming\Kodi\media\Fonts\
10:14:35 T:5164 ERROR: XFILE::CDirectory::GetDirectory - Error getting special://home/media/Fonts/
10:15:48 T:5164 ERROR: XFILE::CDirectory::GetDirectory - Error getting C:\Users\xxxxx\AppData\Roaming\Kodi\media\Fonts\
10:15:48 T:5164 ERROR: XFILE::CDirectory::GetDirectory - Error getting special://home/media/Fonts/
10:16:05 T:5164 ERROR: XFILE::CDirectory::GetDirectory - Error getting C:\Users\xxxxx\AppData\Roaming\Kodi\media\Fonts\
10:16:05 T:5164 ERROR: XFILE::CDirectory::GetDirectory - Error getting special://home/media/Fonts/
10:16:08 T:1068 NOTICE: Thread JobWorker start, auto delete: true
10:16:31 T:3636 NOTICE: script.tv.show.next.aired: ### no prior data found
10:16:33 T:3636 NOTICE: script.tv.show.next.aired: ### starting data update
10:16:40 T:8644 NOTICE: Thread JobWorker start, auto delete: true
10:16:51 T:6196 NOTICE: Thread BackgroundLoader start, auto delete: false
10:16:56 T:9604 NOTICE: Previous line repeats 1 times.
10:16:56 T:9604 NOTICE: Thread JobWorker start, auto delete: true
10:17:04 T:9304 NOTICE: Thread waiting start, auto delete: false
10:17:04 T:9308 NOTICE: Thread FileCache start, auto delete: false
10:17:04 T:8916 NOTICE: Previous line repeats 1 times.
10:17:04 T:8916 NOTICE: Thread BackgroundLoader start, auto delete: false
10:17:05 T:7432 NOTICE: Thread JobWorker start, auto delete: true
10:17:05 T:9056 NOTICE: Previous line repeats 1 times.
10:17:05 T:9056 NOTICE: Thread LanguageInvoker start, auto delete: false
10:17:06 T:9056 NOTICE: -->Python Interpreter Initialized<--
10:17:06 T:9060 NOTICE: Thread BackgroundLoader start, auto delete: false
10:18:31 T:5164 NOTICE: Previous line repeats 11 times.
10:18:31 T:5164 NOTICE: Log level changed to "LOG_LEVEL_DEBUG_FREEMEM"
10:18:31 T:5164 NOTICE: Enabled debug logging due to GUI setting. Level 2.
10:18:31 T:5164 DEBUG: ------ Window Init () ------
10:18:37 T:5164 DEBUG: CInputManager:TonguerocessMouse: trying mouse action rightclick
10:18:37 T:5164 DEBUG: CGUIWindowManager:TonguereviousWindow: Deactivate
10:18:37 T:5164 DEBUG: ------ Window Deinit (SettingsCategory.xml) ------
10:18:37 T:5164 DEBUG: CGUIWindowManager:TonguereviousWindow: Activate new
10:18:37 T:5164 DEBUG: ------ Window Init (Settings.xml) ------
10:18:37 T:9608 NOTICE: Thread JobWorker start, auto delete: true
10:18:39 T:5164 DEBUG: CInputManager:TonguerocessMouse: trying mouse action rightclick
10:18:39 T:5164 DEBUG: CGUIWindowManager:TonguereviousWindow: Deactivate
10:18:39 T:5164 DEBUG: ------ Window Deinit (Settings.xml) ------
10:18:39 T:5164 DEBUG: CGUIWindowManager:TonguereviousWindow: Activate new
10:18:39 T:5164 DEBUG: ------ Window Init (Home.xml) ------
10:18:45 T:5164 DEBUG: CInputManager:TonguerocessMouse: trying mouse action leftclick
10:18:45 T:5164 DEBUG: Activating window ID: 10025
10:18:45 T:5164 DEBUG: ------ Window Deinit (Home.xml) ------
10:18:45 T:5164 DEBUG: ------ Window Init (MyVideoNav.xml) ------
10:18:45 T:5164 INFO: Loading skin file: MyVideoNav.xml, load type: KEEP_IN_MEMORY
10:18:45 T:5164 DEBUG: CGUIMediaWindow::GetDirectory (sources://video/)
10:18:45 T:5164 DEBUG: ParentPath = [sources://video/]
10:18:45 T:5108 NOTICE: Thread BackgroundLoader start, auto delete: false
10:18:45 T:5108 DEBUG: Thread BackgroundLoader 5108 terminating
10:18:47 T:5164 DEBUG: CInputManager:TonguerocessMouse: trying mouse action leftclick
10:18:47 T:5164 DEBUG: CGUIMediaWindow::GetDirectory (D:\temp\Kodi Backup\Test\)
10:18:47 T:5164 DEBUG: ParentPath = [sources://video/]
10:18:47 T:5164 DEBUG: CVideoDatabase::RunQuery took 1 ms for 0 items query: select * from movie_view WHERE c23=2227
10:18:47 T:8008 NOTICE: Thread BackgroundLoader start, auto delete: false
10:18:47 T:8008 DEBUG: Thread BackgroundLoader 8008 terminating
10:18:49 T:5164 DEBUG: CInputManager:TonguerocessMouse: trying mouse action leftclick
10:18:49 T:5164 DEBUG: CGUIMediaWindow::GetDirectory (D:\temp\Kodi Backup\Test\El Cid (1961)\)
10:18:49 T:5164 DEBUG: ParentPath = [D:\temp\Kodi Backup\Test\]
10:18:49 T:5164 DEBUG: CVideoDatabase::RunQuery took 0 ms for 0 items query: select * from movie_view WHERE c23=2228
10:18:49 T:5164 DEBUG: CVideoDatabase::RunQuery took 1 ms for 1 items query: SELECT files.strFilename, files.playCount, bookmark.timeInSeconds, bookmark.totalTimeInSeconds FROM files LEFT JOIN bookmark ON files.idFile = bookmark.idFile AND bookmark.type = 1 WHERE files.idPath=2228
10:18:49 T:8364 NOTICE: Thread BackgroundLoader start, auto delete: false
10:18:49 T:8364 DEBUG: Thread BackgroundLoader 8364 terminating
10:18:51 T:5164 DEBUG: CInputManager:TonguerocessMouse: trying mouse action leftclick
10:18:51 T:5164 DEBUG: CGUIWindowVideoBase::OnPlayMedia D:\temp\Kodi Backup\Test\El Cid (1961)\El Cid (1961).ts
10:18:51 T:5164 DEBUG: CVideoDatabase::GetMovieId (D:\temp\Kodi Backup\Test\El Cid (1961)\El Cid (1961).ts), query = select idMovie from movie where idFile=329
10:18:51 T:5164 DEBUG: CVideoDatabase::GetEpisodeId (D:\temp\Kodi Backup\Test\El Cid (1961)\El Cid (1961).ts), query = select idEpisode from episode where idFile=329
10:18:51 T:5164 DEBUG: CVideoDatabase::GetMusicVideoId (D:\temp\Kodi Backup\Test\El Cid (1961)\El Cid (1961).ts), query = select idMVideo from musicvideo where idFile=329
10:18:51 T:5164 DEBUG: CAnnouncementManager - Announcement: OnAdd from xbmc
10:18:51 T:5164 DEBUG: GOT ANNOUNCEMENT, type: 2, from xbmc, message OnAdd
10:18:51 T:5164 DEBUG: Loading settings for D:\temp\Kodi Backup\Test\El Cid (1961)\El Cid (1961).ts
10:18:51 T:5164 DEBUG: CPlayerCoreFactory::GetPlayers(D:\temp\Kodi Backup\Test\El Cid (1961)\El Cid (1961).ts)
10:18:51 T:5164 DEBUG: CPlayerSelectionRule::GetPlayers: considering rule: system rules
10:18:51 T:5164 DEBUG: CPlayerSelectionRule::GetPlayers: matches rule: system rules
10:18:51 T:5164 DEBUG: CPlayerSelectionRule::GetPlayers: considering rule: hdhomerun/mms/udp
10:18:51 T:5164 DEBUG: CPlayerSelectionRule::GetPlayers: considering rule: lastfm/shout
10:18:51 T:5164 DEBUG: CPlayerSelectionRule::GetPlayers: considering rule: rtmp
10:18:51 T:5164 DEBUG: CPlayerSelectionRule::GetPlayers: considering rule: rtsp
10:18:51 T:5164 DEBUG: CPlayerSelectionRule::GetPlayers: considering rule: streams
10:18:51 T:5164 DEBUG: CPlayerSelectionRule::GetPlayers: considering rule: dvd
10:18:51 T:5164 DEBUG: CPlayerSelectionRule::GetPlayers: considering rule: dvdimage
10:18:51 T:5164 DEBUG: CPlayerSelectionRule::GetPlayers: considering rule: sdp/asf
10:18:51 T:5164 DEBUG: CPlayerSelectionRule::GetPlayers: considering rule: nsv
10:18:51 T:5164 DEBUG: CPlayerSelectionRule::GetPlayers: considering rule: radio
10:18:51 T:5164 DEBUG: CPlayerCoreFactory::GetPlayers: matched 0 rules with players
10:18:51 T:5164 DEBUG: CPlayerCoreFactory::GetPlayers: adding videodefaultplayer (1)
10:18:51 T:5164 DEBUG: CPlayerCoreFactory::GetPlayers: for video=1, audio=0
10:18:51 T:5164 DEBUG: CPlayerCoreFactory::GetPlayers: for video=1, audio=1
10:18:51 T:5164 DEBUG: CPlayerCoreFactory::GetPlayers: adding player: DVDPlayer (1)
10:18:51 T:5164 DEBUG: CPlayerCoreFactory::GetPlayers: added 1 players
10:18:51 T:5164 NOTICE: DVDPlayer: Opening: D:\temp\Kodi Backup\Test\El Cid (1961)\El Cid (1961).ts
10:18:51 T:5164 WARNING: CDVDMessageQueue(player):Tongueut MSGQ_NOT_INITIALIZED
10:18:51 T:5164 DEBUG: CRenderManager::UpdateDisplayLatency - Latency set to 0 msec
10:18:51 T:6248 NOTICE: Thread DVDPlayer start, auto delete: false
10:18:51 T:6248 NOTICE: Creating InputStream
10:18:51 T:6248 DEBUG: CUtil::ScanForExternalSubtitles: Searching for subtitles...
10:18:51 T:6248 DEBUG: CUtil::ScanForExternalSubtitles: END (total time: 0 ms)
10:18:51 T:6248 NOTICE: Creating Demuxer
10:18:52 T:6248 DEBUG: CDVDDemuxFFmpeg::Open - avformat_find_stream_info starting
10:18:52 T:6248 ERROR: ffmpeg[1868]: [mp3] Header missing
10:18:52 T:6248 ERROR: Previous line repeats 2 times.
10:18:52 T:6248 ERROR: ffmpeg[1868]: [NULL] non-existing PPS 0 referenced
10:18:52 T:6248 ERROR: ffmpeg[1868]: [h264] non-existing PPS 0 referenced
10:18:52 T:6248 ERROR: ffmpeg[1868]: [h264] decode_slice_header error
10:18:52 T:6248 ERROR: ffmpeg[1868]: [h264] no frame!
10:18:52 T:6248 ERROR: Previous line repeats 1 times.
10:18:52 T:6248 ERROR: Previous line repeats 4 times.
10:18:52 T:6248 ERROR: Previous line repeats 22 times.
10:18:52 T:6248 DEBUG: ffmpeg[1868]: [mpegts] max_analyze_duration 500000 reached at 504000 microseconds
10:18:52 T:6248 INFO: ffmpeg[1868]: [mpegts] decoding for stream 0 failed
10:18:52 T:6248 DEBUG: ffmpeg[1868]: [mpegts] PES packet size mismatch
10:18:52 T:6248 DEBUG: Previous line repeats 2 times.
10:18:52 T:6248 DEBUG: ffmpeg[1868]: [mpegts] Could not find codec parameters for stream 0 (Audio: mp3, 0 channels, s16p): unspecified frame size
10:18:52 T:6248 DEBUG: ffmpeg[1868]: [mpegts] Consider increasing the value for the 'analyzeduration' and 'probesize' options
10:18:52 T:6248 DEBUG: CDVDDemuxFFmpeg::Open - av_find_stream_info finished
10:18:52 T:6248 INFO: ffmpeg[1868]: Input #0, mpegts, from 'D:\temp\Kodi Backup\Test\El Cid (1961)\El Cid (1961).ts':
10:18:52 T:6248 INFO: ffmpeg[1868]: Duration: 02:51:46.86, start: 45835.751656, bitrate: 10776 kb/s
10:18:52 T:6248 INFO: ffmpeg[1868]: Stream #0:0[0x13fa]: Audio: mp3, 0 channels, s16p
10:18:52 T:6248 INFO: ffmpeg[1868]: Stream #0:1[0x13f8]: Audio: mp2, 48000 Hz, stereo, s16p, 192 kb/s
10:18:52 T:6248 INFO: ffmpeg[1868]: Stream #0:2[0x13f9]: Audio: mp2, 48000 Hz, stereo, s16p, 192 kb/s
10:18:52 T:6248 INFO: ffmpeg[1868]: Stream #0:3[0x13f7]: Video: h264 (High), yuv420p, 50 fps, 50 tbr, 90k tbn, 100 tbc
10:18:52 T:6248 INFO: ffmpeg[1868]: Stream #0:4[0x13fc]: Audio: ac3, 48000 Hz, 5.1(side), fltp, 448 kb/s
10:18:52 T:6248 ERROR: CSelectionStreams::Get - failed to get stream
10:18:52 T:6248 DEBUG: CApplication::OnPlayBackStarted: play state was 1, starting 1
10:18:52 T:6248 DEBUG: CDVDPlayer::SetCaching - caching state 3
10:18:52 T:6248 WARNING: CDVDMessageQueue(audio):Tongueut MSGQ_NOT_INITIALIZED
10:18:52 T:6248 WARNING: CDVDMessageQueue(video):Tongueut MSGQ_NOT_INITIALIZED
10:18:52 T:6248 DEBUG: CDVDPlayer::SetCaching - caching state 0
10:18:52 T:5164 DEBUG: CApplication:TonguelayFile: OpenFile succeed, play state 2
10:18:52 T:5164 DEBUG: CApplication::OnPlayBackStarted: play state was 2, starting 0
10:18:52 T:6248 DEBUG: CDVDDemuxFFmpeg::Read() fetching extradata, extradata_size(149)
10:18:52 T:9536 NOTICE: Thread BackgroundLoader start, auto delete: false
10:18:52 T:9536 DEBUG: Thread BackgroundLoader 9536 terminating
10:18:52 T:5164 DEBUG: CGUIInfoManager::SetCurrentMovie(D:\temp\Kodi Backup\Test\El Cid (1961)\El Cid (1961).ts)
10:18:52 T:5164 DEBUG: CVideoDatabase::GetMovieId (D:\temp\Kodi Backup\Test\El Cid (1961)\El Cid (1961).ts), query = select idMovie from movie where idFile=329
10:18:52 T:5164 DEBUG: CVideoDatabase::GetEpisodeId (D:\temp\Kodi Backup\Test\El Cid (1961)\El Cid (1961).ts), query = select idEpisode from episode where idFile=329
10:18:52 T:5164 DEBUG: CVideoDatabase::GetMusicVideoId (D:\temp\Kodi Backup\Test\El Cid (1961)\El Cid (1961).ts), query = select idMVideo from musicvideo where idFile=329
10:18:52 T:5164 DEBUG: CAnnouncementManager - Announcement: OnPlay from xbmc
10:18:52 T:5164 DEBUG: GOT ANNOUNCEMENT, type: 1, from xbmc, message OnPlay
10:18:56 T:5164 DEBUG: ------ Window Deinit (Pointer.xml) ------
10:19:22 T:9608 DEBUG: Thread JobWorker 9608 terminating (autodelete)
10:21:08 T:5164 DEBUG: ------ Window Init (Pointer.xml) ------
10:21:10 T:5164 DEBUG: CInputManager:TonguerocessMouse: trying mouse action leftclick
10:21:10 T:5164 DEBUG: Activating window ID: 10114
10:21:10 T:5164 DEBUG: ------ Window Init (PlayerControls.xml) ------
10:21:10 T:5164 INFO: Loading skin file: PlayerControls.xml, load type: KEEP_IN_MEMORY
10:21:15 T:5164 DEBUG: CInputManager:TonguerocessMouse: trying mouse action leftclick
10:21:21 T:5164 DEBUG: Previous line repeats 1 times.
10:21:21 T:5164 NOTICE: CDVDPlayer::CloseFile()
10:21:21 T:5164 NOTICE: DVDPlayer: waiting for threads to exit
10:21:21 T:6248 NOTICE: CDVDPlayer::OnExit()
10:21:21 T:6248 DEBUG: CApplication::OnPlayBackStopped: play state was 2, starting 0
10:21:21 T:6248 DEBUG: CAnnouncementManager - Announcement: OnStop from xbmc
10:21:21 T:6248 DEBUG: GOT ANNOUNCEMENT, type: 1, from xbmc, message OnStop
10:21:21 T:5164 NOTICE: DVDPlayer: finished waiting
10:21:21 T:6248 DEBUG: Thread DVDPlayer 6248 terminating
10:21:21 T:6768 NOTICE: Thread JobWorker start, auto delete: true
10:21:21 T:6768 DEBUG: CSaveFileStateJob:Big GrinoWork - Saving file state for video item D:\temp\Kodi Backup\Test\El Cid (1961)\El Cid (1961).ts
10:21:21 T:5164 DEBUG: ------ Window Deinit (PlayerControls.xml) ------
10:21:26 T:5164 DEBUG: ------ Window Deinit (Pointer.xml) ------
10:21:30 T:5164 DEBUG: ------ Window Init (Pointer.xml) ------
10:21:32 T:5164 DEBUG: CInputManager:TonguerocessMouse: trying mouse action rightclick
10:21:32 T:5164 DEBUG: CGUIWindowManager:TonguereviousWindow: Deactivate
10:21:32 T:5164 DEBUG: ------ Window Deinit (MyVideoNav.xml) ------
10:21:32 T:5164 DEBUG: CGUIWindowManager:TonguereviousWindow: Activate new
10:21:32 T:5164 DEBUG: ------ Window Init (Home.xml) ------
10:21:37 T:3632 DEBUG: CVideoDatabase::RunQuery took 80 ms for 49 items query: select * from movie_view WHERE ((movie_view.playCount IS NULL OR movie_view.playCount < 1))
10:21:37 T:3632 DEBUG: CVideoDatabase::RunQuery took 1 ms for 0 items query: select * from episode_view WHERE ((episode_view.playCount IS NULL OR episode_view.playCount < 1))
10:21:37 T:3632 DEBUG: CVideoDatabase::RunQuery took 1 ms for 0 items query: select * from musicvideo_view
10:21:37 T:3632 DEBUG: CMusicDatabase::GetAlbumsByWhere query: SELECT albumview.* FROM albumview WHERE albumview.strReleaseType = 'album'
10:21:37 T:3632 DEBUG: CMusicDatabase::GetAlbumsByWhere - query took 35 ms
10:21:37 T:3632 DEBUG: CMusicDatabase::GetArtistsByWhere query: SELECT artistview.* FROM artistview WHERE (artistview.idArtist IN (SELECT song_artist.idArtist FROM song_artist) OR artistview.idArtist IN (SELECT album_artist.idArtist FROM album_artist)) and artistview.strArtist != '' and artistview.strArtist <> 'Verschiedene Interpreten'
10:21:37 T:3632 DEBUG: Time to retrieve artists from dataset = 55
10:21:37 T:3632 DEBUG: CMusicDatabase::GetSongsByWhere query = SELECT songview.* FROM songview WHERE ((CAST(songview.iTimesPlayed as DECIMAL(5,1)) < 1))
10:21:37 T:3632 DEBUG: CMusicDatabase::GetSongsByWhere() - took 38 ms
10:21:38 T:5164 DEBUG: CInputManager:TonguerocessMouse: trying mouse action leftclick
10:21:38 T:5164 DEBUG: Activating window ID: 10004
10:21:38 T:5164 DEBUG: ------ Window Deinit (Home.xml) ------
10:21:38 T:5164 DEBUG: ------ Window Init (Settings.xml) ------
10:21:38 T:3632 DEBUG: Skin Widgets: Total time needed to request random queries: 0:00:01.255000
10:21:40 T:5164 DEBUG: CInputManager:TonguerocessMouse: trying mouse action leftclick
10:21:40 T:5164 DEBUG: Activating window ID: 10016
10:21:40 T:5164 DEBUG: ------ Window Deinit (Settings.xml) ------
10:21:40 T:5164 DEBUG: ------ Window Init (SettingsCategory.xml) ------
10:21:43 T:5164 DEBUG: CInputManager:TonguerocessMouse: trying mouse action leftclick
10:21:46 T:5164 DEBUG: Previous line repeats 1 times.
10:21:46 T:5164 NOTICE: Disabled debug logging due to GUI setting. Level 0.
10:21:46 T:5164 NOTICE: Log level changed to "LOG_LEVEL_NORMAL"
10:22:16 T:7860 NOTICE: Thread BackgroundLoader start, auto delete: false
10:22:17 T:6044 NOTICE: Thread JobWorker start, auto delete: true
10:22:42 T:6332 NOTICE: Previous line repeats 2 times.
10:22:42 T:6332 NOTICE: Thread BackgroundLoader start, auto delete: false
10:22:59 T:3184 NOTICE: Previous line repeats 4 times.
10:22:59 T:3184 NOTICE: Thread LanguageInvoker start, auto delete: false
10:23:00 T:3184 NOTICE: -->Python Interpreter Initialized<--
10:23:05 T:3184 NOTICE: script.xbmcbackup-1.0.6: Starte
10:23:05 T:3184 NOTICE: script.xbmcbackup-1.0.6: Lokales Verzeichnis: C:/Users/xxxxx/AppData/Roaming/Kodi/
10:23:05 T:3184 NOTICE: script.xbmcbackup-1.0.6: Entferntes Verzeichnis: D:/temp/Kodi Backup/xxxxxxx/201510181023/
10:23:05 T:3184 NOTICE: script.xbmcbackup-1.0.6: Modus - Sichern
10:23:05 T:3184 ERROR: XFILE::CDirectory::Create - Error creating D:\
10:23:05 T:3184 NOTICE: script.xbmcbackup-1.0.6: Dateiliste wird erzeugt
10:23:09 T:3184 NOTICE: script.xbmcbackup-1.0.6: Writing files to: D:/temp/Kodi Backup/xxxxxxx/201510181023/
10:23:09 T:3184 NOTICE: script.xbmcbackup-1.0.6: Source: C:/Users/xxxxx/AppData/Roaming/Kodi/
10:23:09 T:3184 ERROR: XFILE::CDirectory::Create - Error creating D:\
10:26:09 T:8088 ERROR: Previous line repeats 6139 times.
10:26:09 T:8088 NOTICE: Thread JobWorker start, auto delete: true
10:26:17 T:5164 NOTICE: Previous line repeats 2 times.
10:26:17 T:5164 NOTICE: Storing total System Uptime
10:26:17 T:5164 NOTICE: Saving settings
10:26:17 T:5164 NOTICE: stop all
10:26:17 T:5164 NOTICE: stop player
10:26:17 T:5164 NOTICE: ES: Stopping event server
10:26:17 T:5164 NOTICE: stopping upnp
10:26:17 T:6124 NOTICE: ES: UDP Event server stopped
10:26:17 T:5164 NOTICE: stop sap announcement listener
10:26:17 T:5164 NOTICE: clean cached files!
10:26:17 T:5164 NOTICE: unload skin
10:26:17 T:3632 WARNING: CPythonInvoker(1, C:\Users\xxxxx\AppData\Roaming\Kodi\addons\service.skin.widgets\default.py): the python script "C:\Users\xxxxxx\AppData\Roaming\Kodi\addons\service.skin.widgets\default.py" has left several classes in memory that we couldn't clean up. The classes include: class XBMCAddon::xbmcgui::Window,class PythonBindings::XBMCAddon_xbmc_Player_Director,class PythonBindings::XBMCAddon_xbmc_Monitor_Director
10:26:18 T:3628 NOTICE: StorageServer-2.5.4 Closed down
10:26:18 T:3636 NOTICE: script.tv.show.next.aired: ### abort requested -- stopping background processing
10:26:18 T:5164 NOTICE: stopped
10:26:18 T:5164 NOTICE: destroy
10:26:18 T:5164 NOTICE: closing down remote control service
10:26:18 T:5164 NOTICE: unload sections
10:26:18 T:5164 NOTICE: special://profile/ is mapped to: special://masterprofile/
10:26:18 T:5164 WARNING: Attempted to remove window 10013 from the window manager when it didn't exist
10:26:18 T:5164 WARNING: Attempted to remove window 10014 from the window manager when it didn't exist
10:26:18 T:5164 WARNING: Attempted to remove window 10015 from the window manager when it didn't exist
10:26:18 T:5164 WARNING: Attempted to remove window 10016 from the window manager when it didn't exist
10:26:18 T:5164 WARNING: Attempted to remove window 10017 from the window manager when it didn't exist
10:26:18 T:5164 WARNING: Attempted to remove window 10018 from the window manager when it didn't exist
10:26:18 T:5164 WARNING: Attempted to remove window 10019 from the window manager when it didn't exist
10:26:18 T:5164 WARNING: Attempted to remove window 10021 from the window manager when it didn't exist
10:26:18 T:5164 WARNING: Attempted to remove window 10107 from the window manager when it didn't exist
10:26:18 T:5164 WARNING: Attempted to remove window 10115 from the window manager when it didn't exist
10:26:18 T:5164 WARNING: Attempted to remove window 10104 from the window manager when it didn't exist
10:26:18 T:5164 NOTICE: application stopped...
10:26:18 T:5164 ERROR: dllFreeLibrary - Invalid hModule specified
Ok, if they don't play on anything else, but Kodi 13, including standard players and the like, then your only option here is to either re encode to a proper .ts format, or another container,
The easiest, user freindly program to do this with is handbrake.
As a quick cheat, have you tried changing the file extension to .mp2 or .mp4 to see if that's enough to nudge KODI into working?
I used to get lots of .ts files from a digital TV recorder and my preferred editor \ converter was VideoRedo. Still like it as it is quick and simple. It isn't free, but a demo is available to test it out. Less geeky that Handbrake and IMHO well worth the cash. http://www.videoredo.com/en/index.htm
Handbrake isn't geeky, pudding. The CLI is, but the gui is pretty self explanatory and user friendly
And free. Smile especially if you aren't do that much conversion, or other
(2015-10-18, 16:07)Redwingsfansfc Wrote: [ -> ]Handbrake isn't geeky, pudding. The CLI is, but the gui is pretty self explanatory and user friendly
As a geek myself I do realise Handbrake is very usable. And very free. But if you met some of my clients you would understand how terrified they would be if they saw all that plain grey and options everywhere. Some people prefer a simplified prettified GUI.
Also as my .ts files were from a TV source I often needed to top n tail them and trim adverts.
I always believe in having many tools in a toolbox.
(I now head off an have a play with Handbrake... Big Grin)
can you share a short sample?
(2015-10-18, 16:17)BatterPudding Wrote: [ -> ]
Lol, and I agree with you. The main reason why I point people that way, because out of the 1trillion options, and most of them spam, Trojan, or otherwise filled with crap... Handbrake isn't. So for first timers, Atleast I know they can figure it out, and not hate me for the bs overload. Big Grin
Thx for your advices, but I don't like to have much trouble like converting for just viewing films. So if there is no option to view them with a newer version of kodi: maybe I can install the old xbmc 13.2 on my NAS, but: where can I get the qpkg for my QNAP HS-251 (Linux)? Any idea?
Pages: 1 2
