HI
When i click on movie info, there is a tab that says trailer, i believe it should play the movie trailer i am selecting.
When i click on the tab, nothing happens. Can someone please tell me what am i missing or doing wrong
Your help is appreciated.
anyone out there that can help ?
I got it to work, and thanks for the help
If you anyone faces the same problem let me know and i would gladly help, i believe this is the main reason for having this forum
So why don't you actually post how you fixed this? Do you think people just ignore you? I, for one, don't know this off hand. I'm think it looks for a local trailer, and if there is none, then it searches YouTube for a trailer. Sometimes nothing is found. Since you apparently know, why not just say it and not beat around the bush?
I have also the problem, that trailers are not played.
I tested it with 15.2 (Google Play Store) on Nexus 7 2013 and 16 (kodi-20151030-8c37498-master-armeabi-v7a) on SHIELD TV.
For a second, it shows the UI at the bottom for loading the player, but then nothing happens.
Here is the log:
http://pastebin.com/h3cC0nts
I also tried using the youtube app for playing youtube streams, but that doesn't work either:
http://pastebin.com/7G46Zxy5
It turns out, my college who complaint about this in the first place talked bulls**t.
The trailers did never work, because I have the normal http url inside the nfo files.
After changing the settings of media elch to use youtube plugin url and rescraping the trailers for every movie, it now works.
