Full Version: Start Playback at Bookmark?
Hello All,
I've spent about two hours searching and haven't found what I'm looking for...help would be appreciated...
I'm looking to set up a method by which I can play four or five movie sections in sequence from multiple files. Each of these sections are mid-movie. I am using this as a way to demo my system with what I consider to be the most impressive scenes so people can see what the system is capable of rendering.
The big question...how do I start playing a file from a specific point in time? Let's say, as an example, I wanted a clip from Iron Man. I know how to kick the file off in a Python script...
xbmc.executebuiltin("PlayMedia(\\var\\media\\KINGSTON\\IronMan.mkv)")
What do I add if I want it to automatically, consistently start playing Iron Man at the 15:32 mark, without prompting, for some reason?
Thanks for any insight you can provide.
Lookup the seekTime() method on the xbmc.Player class
eg
class MyPlayer (xbmc.Player):
    def onPlayBackStarted(self):
        try:
            self.seekTime(float(932))
        except:
            pass
Note - seekTime is in seconds, must pass as a float
http://paste.ubuntu.com/12698323/ examplifies a better way.
EDIT: reason i say it's better is that the player is told up front, and won't start decoding from the start of the file, then immediately being told to seek.
I was never able to get it to work that way, not sure what I was missing
Though I was using the ResumeTime property instead of StartPercent
listitem.setProperty('ResumeTime', '932')
Edit - well StartPercent works.. still can't figure out why ResumeTime doesn't for me
Edit edit - StartOffset works well, giving it the # of seconds to start at
Edit edit edit - Where can one find a list of valid properties? I only find these by chance, never spotted these documented anywhere
dunno, i always check the code..
(2015-10-06, 19:11)Eldorado Wrote: [ -> ]Lookup the seekTime() method on the xbmc.Player class
Are you sure SeekTime needs a float?
I use in in my addon and it works while I use an int.
What I have working so far is the following...
addon = xbmcaddon.Addon()
addonname = addon.getAddonInfo('name')
xbmc.Player().play("\\storage\\movies\\Animal House (1978)\\Animal House.mkv")
xbmc.Player().seekTime(932)
time.sleep(60)
However, I'm running into two follow-on issues.
First, I run into problems with the next line failing...
xbmc.Player().stop
For some reason, the "stop" command is being ignored. No error message, just no positive response to the stop. I'm thinking that I'll avoid this by running a playlist where I play to the end of the last file in the list, though it would be nice if "stop" actually worked.
Second, the entire time that the script is "sleeping," I get the "working" prompt in the top-center of the screen/skin while viewing content. Does anyone know a way to temporarily make Kodi run Python scripts in "silent mode?"
Thanks again for all of the input.
(2015-10-07, 12:39)Wimpie Wrote: [ -> ]
Nope, not sure at all Smile
Sounds like either way will work depending on how much precision you want
I'm a fool...missed minor syntax add...the () after "stop"...now I'll be good as soon as I can get rid of the "working" prompt and have the script run "silently"
