Sorry for short info.
That was auto correct problem by mobile.
I am using this addon at Indian location and IP.
Not using any VPN. Because don't need it.
I am using on amalogic box. With openelec and kodi Jarvis.
All movies plays fine.
But whenever I try to play any episode of any serial. It dosent work.
When inspect log file it mentions some URL then stream not available.
(2016-03-12, 20:29)amanker Wrote: [ -> ]Sorry for short info.
Yea log files won't help much, but this can be fixed. As you know, I don't have VPN. So, can one of you get me some fiddler log by playing some links under website OR mobile.
Most of the time I use mobile. If you please tell me how can I take log of hotstar app.
(2016-03-12, 20:33)amanker Wrote: [ -> ]Most of the time I use mobile. If you please tell me how can I take log of hotstar app.
Ok, you'll need windows machine where Fiddler can be installed.
here is the link for capturing from Mobile device, BUT if you're using windows machine then might as well just open in browser first. Just make sure fiddler is running first, then you simply browse to website and navigate and play whatever you need. JUST one advice, try not to extend video play as fiddler log can become huge(i mean in megabytes). Also, if you want to minimize log then filter by json requests and f4m(video) request, and get rid of rest of the junk.
https://blogs.esri.com/esri/supportcenter/2011/12/06/configuring-fiddler-to-capture-web-traffic-from-an-iphone-ipad-device/
Thanks Dhaval. question regarding live games working on mobile but not in shield, which country are you in? Also, they work in browser for you?
[/quote]
- norway
- I am not sure about live matches in browser but I will check and tell ylu tomorrow.
(2016-03-12, 22:42)dhavalmp Wrote: [ -> ] (2016-03-12, 20:28)yocoldrain Wrote: [ -> ]
- norway
[/quote]
and no VPN, right?
Most of the movies are working ( not all ) but NONE of the tv shows are working.
I am based out of India so it shouldn't be an IP issue. Same shows which don't play in Kodi play properly on hotstar.com / laptop / hotstar app on mobile etc ( same wifi connection => same IP )
Getting below errors in log
Quote:10:39:53 T:5564 WARNING: XFILE::CFileFactory::CreateLoader - unsupported protocol(plugin) in plugin://plugin.video.hotstar-rain/?mode=9&name=133+-+A+video+footage+of+Payal%27s+rape&url=http%3A%2F%2Fgetcdn.hotstar.com%2FAVS%2Fbesc%3Faction%3DGetCDN%26asJson%3DY%26channel%3DPCTV%26id%3D1000025791%26type%3DVOD&image=http%3A%2F%2Fmedia0-starag.startv.in%2Fr1%2Fthumbs%2FPCTV%2F91%2F1000025791%2FPCTV-1000025791-hs.jpg
Quote:10:39:19 T:2828 ERROR: C:\Users\xyz\AppData\Roaming\Kodi\addons\script.module.requests\lib\requests\packages\urllib3\connectionpool.py:791: InsecureRequestWarning: Unverified HTTPS request is being made. Adding certificate verification is strongly advised. See: https://urllib3.readthedocs.org/en/latest/security.html
InsecureRequestWarning)
10:39:21 T:2828 ERROR: Previous line repeats 1 times.
10:39:21 T:2828 ERROR: EXCEPTION Thrown (PythonToCppException) : -->Python callback/script returned the following error<--
Error Type: <type 'exceptions.IndexError'>
Error Contents: list index out of range
File "C:\Users\xyz\AppData\Roaming\Kodi\addons\plugin.video.hotstar-rain\default.py", line 493, in <module>
get_video_url()
File "C:\Users\xyz\AppData\Roaming\Kodi\addons\plugin.video.hotstar-rain\default.py", line 363, in get_video_url
raw3_start = videos[0][1]
IndexError: list index out of range
10:39:21 T:8036 ERROR: Playlist Player: skipping unplayable item: 0, path [plugin://plugin.video.hotstar-rain/?mode=9&name=125+-+In+search+of+the+missing+pages&url=http%3A%2F%2Fgetcdn.hotstar.com%2FAVS%2Fbesc%3Faction%3DGetCDN%26asJson%3DY%26channel%3DPCTV%26id%3D1000025783%26type%3DVOD&image=http%3A%2F%2Fmedia0-starag.startv.in%2Fr1%2Fthumbs%2FPCTV%2F83%2F1000025783%2FPCTV-1000025783-hs.jpg]
Thanks again for the wonderful plugin[/code]
Hi
Currently watching live match between Ireland vs Netherlands
- On web, Google Chrome, on pc, mobile and tablet: live stream works
- Kodi on Android (Oneplus One) : Live stream works
- Kodi on android (Shield Tablet) : not working - <one or more items failed to play. Check log for more information about this message>
- Kodi on Nvidia shield tv : not working
so, it seems its completely blocked from USA. Tried Norway IP but no luck. Dhaval when you say Kodi on Android, are you going through this addon or actual App that works? Also, are you using IP under addon settings? And is it same Kodi version installed everywhere, because this may matter.
Many of the live streams, movies and TV shows are geo blocked through f4m. The add-on needs to be linked up with f4m tester to work them out in Kodi. I am in India and I have tried to snoop the streams from the website as well as the add-on. It can work on the mobile website of hotstar as they use m3u8 playlists for mobile, both on hotstar and star sports website.
(2016-03-14, 06:13)Ninaad Wrote: [ -> ]Many of the live streams, movies and TV shows are geo blocked through f4m. The add-on needs to be linked up with f4m tester to work them out in Kodi. I am in India and I have tried to snoop the streams from the website as well as the add-on. It can work on the mobile website of hotstar as they use m3u8 playlists for mobile, both on hotstar and star sports website.
Only reason this addon exists from beginning is because of m3u8 not f4m.
(2016-03-13, 17:25)yocoldrain Wrote: [ -> ]so, it seems its completely blocked from USA. Tried Norway IP but no luck. Dhaval when you say Kodi on Android, are you going through this addon or actual App that works? Also, are you using IP under addon settings? And is it same Kodi version installed everywhere, because this may matter.
- By 'Kodi on Android' I mean using this addon on Kodi installed on my phone.
- Yes I am using Indian IP
- Kodi Jarvis is installed everywhere
