Full Version: Hotstar-Rain Indian movies/tv shows/sports
Pages: 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32
Releasing, Hotstar-Rain, addon for Indian movies, tv shows, sports (live if playing), search.
NOTE - This may only work on Kodi 15 and above.
what I've done,
- Added Movies, TV Shows, Sports (LIVE if playing), Search, Movie Collections
- Added settings for above categories based on language
- Added some sorting options for TV shows and Movies
- Video Quality Selection
- Added number of movies per page ( I recommend lower number for smooth operations)
whats required on your part before posting a question
- insert Indian IP address in settings (if you're in India then dont worry about it, or if you're using indian vpn)
- I haven't tested Live sports as they are time based
- IF you're not in India, then regardless of above Indian IP address input, you may not have most of the TV shows working (they are geo-blocked)
- I havent worked much for proper error handling but you shouldn't run into it.
- If you find something not working then verify on website whether its working.
- Do not discuss any other addons.
here is the link, you shouldn't run into any trouble installing it, Good Luck.
https://github.com/YoColdRain/Hotstar-Ra...p?raw=true
--Coffee/Tea welcome.
Changes -
1.0.0 - Initial Release
1.0.1 - added Highest[1080p if available], and 'Let me choose'(720p or lower) options.
1.0.2 - Fixed Empty directory load on play, and instead stay on current directory. Video Resume should work now.
1.0.3 - Video fixes caused by 1.0.2, in fact these bugs may be present in previous versions as well. So this is recommended version at this point.
1.0.4 - Added some Folder fixes, and TV shows structure changes.
1.0.5 - website change fixes, added images/fanart
1.0.6 - missing TV shows fix, and added Verify=False for requests
1.0.7 - removed ip address dependecy by default. fixed movie collections.
1.0.8 - 720p sports links (must use Let Me Choose quality option). subtitles integration (must NOT use Let Me choose quality, choose highest or others).
1.0.9 - fixed tvshows.
1.0.10 - fixed Search(got broken at some point), and added TV Channels category.
1.0.11 - fixed live sports (they work only if not geo blocked, and you need to choose Highest quality or Let me Choose under settings)
1.0.12 - added debug mode, all live sports links will auto default to "let me choose" quality option. Everything else will play with select quality option under settings.
1.0.13 - trigger change for live - fix.
1.0.14 - multi language selection option added under settings. Please note, your default language may have been replaced to hindi so go to settings and make necessary changes. Also, if none of the languages are selected then its considered as ALL, and results will be for all languages.
1.0.15 - added playback fix made by Gujal
Thanks for the release
Can u add metadata for movies such as posters and backgroung as it will make the addon look nice and good. Right now there is no poster for any movies. Thanks for a great addon
Awesomee... Been waiting for this since ages.
Thanks to both of you.. Appreciate your hard work : D
Thanks a lot bro : )
(2015-10-07, 06:26)binder420 Wrote: [ -> ]Can u add metadata for movies such as posters and backgroung as it will make the addon look nice and good. Right now there is no poster for any movies. Thanks for a great addon
Yea, I really want images as well, but its not easier as the site is very dynamic and loads same image from different servers. planning to look in to this.
(2015-10-07, 15:43)yocoldrain Wrote: [ -> ]
no problem thanks for looking in still love the addon
also any one have interest in 1080p?
(2015-10-07, 21:03)yocoldrain Wrote: [ -> ]also any one have interest in 1080p?
yes i do. I wanted to ask you about that too. i have fast internet and bandwidth and would love 1080p
Tried this with a DNS solution and got to play most everything except the Sports on demand videos. I can't play the sports highlights even on browser though, even with Indian VPN. Anyone able to play the highlights?
(2015-10-07, 21:19)siuside Wrote: [ -> ]Tried this with a DNS solution and got to play most everything except the Sports on demand videos. I can't play the sports highlights even on browser though, even with Indian VPN. Anyone able to play the highlights?
then they may be simply not working, unless they do on starsports. If you like to test there and tell us the results, it'd be great!
(2015-10-07, 21:22)yocoldrain Wrote: [ -> ]
works for me with indian ip inserted into the addon. just tested it again to make sure and all the clips are working in the sports section.
Thanks for confirming. Confirmed working with a valid IP.
Oddly enough they seem to be blocking an IP obtained via a VPN provider.
New Addition, Added Highest[1080p if avaialble for video] and "Let me Choose"(720p or lower) user selection.
Make note that choosing Highest option MAY take longer to fetch videos. 720p is recommended. 1080p is only helpful if you're sitting 10 feet away or more from your device and device actually has 1080p. Otherwise you wont notice a thing.
I tired with Indian IP (working on my laptop with Chrome added on) but no luck.. after selecting movie it shows nothing..
error stack
1:17:58 T:1693874632   ERROR: /storage/emulated/0/Android/data/org.xbmc.kodi/files/.kodi/addons/script.module.requests/lib/requests/packages/urllib3/util/ssl_.py:90: InsecurePlatformWarning: A true SSLContext object is not available. This prevents urllib3 from configuring SSL appropriately and may cause certain SSL connections to fail. For more information, see https://urllib3.readthedocs.org/en/latest/security.html#insecureplatformwarning.
21:18:06 T:1681239024  NOTICE: Thread BackgroundLoader start, auto delete: false
21:18:08 T:1494383592  NOTICE: DVDPlayer: Opening: https://staragvod-vh.akamaihd.net/i/videos/movies/londonparisnewyork/1000007134_,400,800,1300,2000,_STAR.mp4.csmil/index_3_av.m3u8?null=&id=AgAY8kZiYAcpFljSFVaeMbFw20oadIfno+o8negqy1aFmAPyR%2f3LLY9kA9urVghcdaWUKoBEfHAbvQ%3d%3d|Cookie=beID=BE03;hdntl=exp=1444357080~acl=%2f*~data=hdntl~hmac=b704b70810bd724b0a217d1ba704deb0a5948c21867c6b1b1dcf8252667acaf7;_alid_=kp2t2v1W198hDpV9MdHXFQ==;AWSELB=A9F1B52B1E9521250CD3A1ACE8F83E14747C27B9288FB47E925F16805E994AA9ACE6BA27B7EFB736556201E054EC2E9ADEDFCABDCD842196597DC98792278B634DB0A56F1B;JSESSIONID=3QAkGaQiN6jwpU4nKBIPK5Ws;&X-Forwarded-For=27.54.161.34
21:18:08 T:1494383592 WARNING: CDVDMessageQueue(player)::Put MSGQ_NOT_INITIALIZED
