Full Version: Higher encryption certificate for FTPS, SSL/TLS
Hey,
Regarding FTPS, SSL/TLS.
It would be awesome to be able to use a higher encryption certificate than 2048 bits.
When testing, it works great with 2048 or lower certificates. But when going above 2048 it just won't initiate SSL/TLS.
How ever if you have an active session on a 4096 certificate in another client like filezilla ftp client, Kodi will connect just fine!
Thanks for an awesome media center Smile
Yes, would be great.
I also cannot connect with my FTPES-Server (I cannot config it, so it has to be FTPES - it's the webserver on my Modem/USBStick). The data i put in is right, but KODI is not able to handle it, so I dont get access to my files... Undecided
